Taito Type X/X2
psychopath
Hello guys, can someone explain me wich amulator do i need for this system? i read about a loader, but kinda difficult to understand all the steps coz the site i found its in portuguese and the other one in french, also, do you guys know how can i find the list of games to DL? i already got atomiswave working with demul and my next goal is this system and all the games. thx a lot.
  On 9/5/2018 at 3:16 PM, gigapig said:
I can't tell you where to get the games but you can watch my old but still quite relevant video about set up.
Expand
nice, thx! i was able to find the games, kinda dificult to understand rigth away, but u have taught me that i have to search and read, and that there are not shorcuts or easy way. :D  so far i have programmed 6 system and i feel happy about it, kinda worried about configuring the joystick and bottons. thx giga
You should have a "pad_config" with each game for setting controls or you will need to use a key mapper.
OH and you need to use the PCLauncher module for TTX.
  On 9/7/2018 at 8:09 PM, psychopath said:
Well i made a video about the problem im having with Taito Type X, SORRY FOR MY ENGLISH!
Expand
If you downloaded from Game Loader from the 'official' place it has details on what files are required for each game including the file you are missing. You'll also find the instructions per game in the 'Readme.txt' of Game Loader.
Below are my settings you can set it however you want.
https://mega.nz/#!Z0hUkABA!eJii8CsF-L_CcI3Xi5UFSrxkTeejE4K0L2veqRJk1Pk
Expand
Your English is great psychopath.
Do you have 2 monitors attached to that pc? Sometimes that can cause problems.
Expand
Wow! thx a lot this is awesome, i found the readme file :P even if i know a bit of japanesse cant figure out, but i will try, this video was really helpfull.
Expand
just One Giga, im doing this in my workplace :P lol so i have one monitor with work and other with Hyperspin. but thx for the tip, in this case if i want to use another monitor for the marquee u think will cause problems?
  On 9/10/2018 at 4:19 PM, psychopath said:
Here is the video :D thx in advance Wallmachine!
Expand
resolution should be 1280 x 720.
As per the following try running the game again.
"***** On Windows 10, after starting the OS, black screen may be displayed at the first execution of each game or the screen may not be displayed correctly. *****"
As you are on a work computer make sure you have the following installed:
"*************************** Minimum requirement ***************************
.NET 1.1
.NET 4.5 or higher
DirectX Offline Installer | http://www.mediafire.com/file/lth3858phaaw7xk/Direct_X_Offline_Installer.rar
VC++ 2005, 2008, 2010, 2012, 2013, 2015, 2017 Redistribution Package (x86)"
You don't need to have all the VC++ installed.
.NET 1.1
.NET 4.5 or higher
Expand
Done all that, no luck. :(
000008.jpg.f8a3f2dd726283c03065c44651d39baa.jpg000007.jpg.b672fcc73129feb0f433fa332961f4a2.jpg000006.jpg.cb23bc07932540846ce63077659d6f85.jpg000005.jpg.7107eabc424968fed5ad7271ac5508c3.jpg000004.jpg.706e49d80744c28c73812ed27c3c6106.jpg000003.jpg.87763fa0e6b7d274c6bd4f652355c327.jpg000002.jpg.3a1bed5f03c7f5f8f15cfe9aaa15dbbd.jpg000001.jpg.5552eaf1ad317d19d1a89d6ce20c8d88.jpg000011.jpg.410640574a37f35eb157d1493a140861.jpg000010.jpg.3fa7391e5fc87dd4a7ab8f9d9f247c2e.jpg000009.jpg.e9b6ac3cff3770bd623113859d6dfff0.jpg
https://sites.google.com/view/magoarcade/software/typextra
Use TypeXtra a third party program.
3 step setup provided you have the base compatible rom files to begin with. Program downloads any missing files and configs automatically for each game to make it run.
Then you run each game in RL using PC launcher module through a shortcut the TypeXtra program creates for you.
Setup video here:
Setup video here:
Expand
wow, i will check it out! i readed about this emulator but ddnt knew it can be used with HS
Setup video here:
Expand
Looks like an updated version of Arcade Pc Loader.
Setup video here
Expand
well tried already, some games run now, few of them run in low motion, and some even if everything says its ok, dont run. for example nitro
when i hit run i got this screen nothing else happen.
