mikea213 Posted September 28, 2018 Posted September 28, 2018 Does anyone no the code that hyperspin uses to log into windows or shut down the pc when ESC is pressed? I want to build a script and wheel to do just that not sure how to? I want my esc key left to just going back in the menus and exiting systems. I already have a shut down wheel ready to do. Thanks
dark13 Posted September 28, 2018 Posted September 28, 2018 step1: shelling HS Search "gpedit.msc" from windows start and run it, administrative templates->System->Custom user interface set hyperspin as shell (don't works on HOME editions) Shelling HS from group policies is better than shelling it from system registry as if you ctrl+alt+canc, open the task manager and run "explorer.exe" the original windows GUI will start, if you shell from the registry it will just open an explorer window. step2: automatic login https://www.cnet.com/how-to/automatically-log-in-to-your-windows-10-pc/ step3: turning off the computer from HS https://www.computerhope.com/issues/ch000321.htm Just launch the created link from HS (make a "shutdown" wheel) Or set HS to launch the link when HS close) Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
mikea213 Posted October 1, 2018 Author Posted October 1, 2018 On 9/28/2018 at 4:12 AM, dark13 said: step1: shelling HS Search "gpedit.msc" from windows start and run it, administrative templates->System->Custom user interface set hyperspin as shell (don't works on HOME editions) Shelling HS from group policies is better than shelling it from system registry as if you ctrl+alt+canc, open the task manager and run "explorer.exe" the original windows GUI will start, if you shell from the registry it will just open an explorer window. step2: automatic login https://www.cnet.com/how-to/automatically-log-in-to-your-windows-10-pc/ step3: turning off the computer from HS https://www.computerhope.com/issues/ch000321.htm Just launch the created link from HS (make a "shutdown" wheel) Or set HS to launch the link when HS close) Is there a way to require a password to exit hyperspin back to windows? I have it setup now for the last 5 years that when the pc boots I get the little windows 10 crap screen and then it auto loads my hyperspin. if I press esc I get the want to exit hyperspin and if I say yes it goes to the black screen and I have to ctrl-alt-delete and then run explorer.exe. just was wonder if there is a way to build a script on that exit that makes me input a password and then will auto run the explorer so I dont have to do all the extra stuff.
dark13 Posted October 2, 2018 Posted October 2, 2018 As far as I know it is not possible to use a password to exit hyperspin, you can launch explorer.exe when HS closes (it is possibile to launch an application when HS closes, you can find the option in HyperHQ statup/exit). Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
