TheManuel Posted December 4, 2018 Posted December 4, 2018 Sorry to post here but I can't seem to get any help in the AHK forum itself, and there are some members of the HS community that are pretty knowledgeable with AHK. I am trying to create a simple GUI where I add an image, then overlay another image with a transparent background over it. Essentially, the second image just says "Loading" on top of the original one. I've tried the code below but the "Loading" image simply places itself over the other one with a white background and completely obscures it. If I swap the order in which GUI 1 and 2 appear, then the same problem happens but with the "Nightmare" image blocking the other one. Gui, 1: -Caption +ToolWindow Gui, 1: Add, Picture, h%A_ScreenHeight% w%A_ScreenWidth% AltSubmit BackgroundTrans, D:\FrontEnd\HyperSpin\Splash Images\Loading.png Gui, 2: -Caption +ToolWindow Gui, 2: Add, Picture, h%A_ScreenHeight% w%A_ScreenWidth%, D:\FrontEnd\HyperSpin\Splash Images\SC2 Nightmare.jpg Gui, 2: Show, x-10 y-7 h%A_ScreenHeight% w%A_ScreenWidth% Sleep, 1000 Gui, 1: Show, x-10 y-7 h%A_ScreenHeight% w%A_ScreenWidth% I tried also adding both images within the same GUI command, with and without the AltSubmit parameter. Also, I am certain the image has a transparent background, as I've verified it with other applications. Any help would be appreciated.
albert Posted December 5, 2018 Posted December 5, 2018 10 hours ago, TheManuel said: Sorry to post here but I can't seem to get any help in the AHK forum itself, and there are some members of the HS community that are pretty knowledgeable with AHK. I am trying to create a simple GUI where I add an image, then overlay another image with a transparent background over it. Essentially, the second image just says "Loading" on top of the original one. I've tried the code below but the "Loading" image simply places itself over the other one with a white background and completely obscures it. If I swap the order in which GUI 1 and 2 appear, then the same problem happens but with the "Nightmare" image blocking the other one. Gui, 1: -Caption +ToolWindow Gui, 1: Add, Picture, h%A_ScreenHeight% w%A_ScreenWidth% AltSubmit BackgroundTrans, D:\FrontEnd\HyperSpin\Splash Images\Loading.png Gui, 2: -Caption +ToolWindow Gui, 2: Add, Picture, h%A_ScreenHeight% w%A_ScreenWidth%, D:\FrontEnd\HyperSpin\Splash Images\SC2 Nightmare.jpg Gui, 2: Show, x-10 y-7 h%A_ScreenHeight% w%A_ScreenWidth% Sleep, 1000 Gui, 1: Show, x-10 y-7 h%A_ScreenHeight% w%A_ScreenWidth% I tried also adding both images within the same GUI command, with and without the AltSubmit parameter. Also, I am certain the image has a transparent background, as I've verified it with other applications. Any help would be appreciated. Gui, 1: Add, Picture, h%A_ScreenHeight% w%A_ScreenWidth% +BackgroundTrans, D:\FrontEnd\HyperSpin\Splash Images\Loading,png
TheManuel Posted December 5, 2018 Author Posted December 5, 2018 Thanks for the tip. I was able to get it working last night with the code below, following some advice from someone on the AHK reddit. However, I will check out your suggestion of adding "+" before "BackgroundTrans" as it would be a more elegant solution if it works. It will be sad if all I was missing was a plus sign, but unsurprising in the world of coding. Gui, 1: -Caption +ToolWindow +LastFound Gui, 1: Color, 000001 Gui, 1: Add, Picture, w800 h200, D:\FrontEnd\HyperSpin\Splash Images\Loading.png Gui, 2: -Caption +ToolWindow Gui, 2: Add, Picture, w%A_ScreenWidth% h%A_ScreenHeight%, D:\FrontEnd\HyperSpin\Splash Images\SC2 Nightmare.jpg Gui, 2: Show, x-10 y-7 w%A_ScreenWidth% h%A_ScreenHeight% Gui, 1: Show, x700 y700 w800 h200 WinSet, TransColor, 000001
TheManuel Posted December 5, 2018 Author Posted December 5, 2018 I tried adding +BackgroundTrans but it did not work in my case, so I have stick with the TransColor workaround. It was worth a try.
