Mame compile Question
good morning, I have a question with the mame source code
do you know where the file in mame src for the no nag line to edit
I tried to patch with HeadKaze compiler but it just gives me a note
missing header for unified diff at line 4 of patch can't find file to patch at input line 4
any idea why this is happening?
I use my own patch. Simply edit ui.cpp, search for warn, and delete (comment out) the str two lines above that, and the if statement two lines below that. See included example.
ui.cpp
Nate67A000, No uso ese compilador, Siempre edito algunas lineas .
Código fuente de Mame >> SRC >> M
 MODIFICACIÓN DE LA PANTALLAS DE INICIO
 ELIMINACIÓN DE MENSAJES EMERGENTES
 MODIFICACIÓN DEL MENSAJE DE EXCEPCIONES
 MODIFICACIÓN DEL RENDER
RUTA DEL ARCHIVO
mame/src/frontend/mame/ui/ui.cpp
Creo que esto ya lo sabes.?
RUTA DEL ARCHIVO
mame/src/emu/render.cpp
BUSCAR ESTAS LINEAS
render_primitive *prim = list.alloc(render_primitive::QUAD);
MODIFICACIONES EL SOURCE
*NOTA: (MOD_1) , (MOD_2) NO DEBEN ESTAR EN LOS CAMBIOS SOLO ES PARA QUE VEAN DONDE ESTÁN UBICADOS LOS CAMBIOS CIRCUNFERENCIALMENTE..
(MOD_1)
ADICIONAR UNA BARRA INCLINADA (/) Y ASTERISCO(*) ANTES DEL TEXTO "render_primitive"
(MOD_2)
ADICIONAR UN ASTERISCO (*) Y BARRA INCLINADA (/) DESPUÉS DE LA PENÚLTIMA LLAVE CURVA "}".
LINEAS MODIFICADAS DEL SOURCE
(MOD_1)
/*render_primitive *prim = list.alloc(render_primitive::QUAD);
set_render_bounds_xy(&prim->bounds, 0.0f, 0.0f, (float)m_width,
(float)m_height);
set_render_color(&prim->color, 1.0f, 1.0f, 1.0f, 1.0f);
prim->texture.base = nullptr;
prim->flags = PRIMFLAG_BLENDMODE(BLENDMODE_ALPHA);
list.append(*prim);
if (m_width > 1 && m_height > 1)
set_render_bounds_xy(&prim->bounds, 1.0f, 1.0f, (float)
(m_width - 1), (float)(m_height - 1));
set_render_color(&prim->color, 1.0f, 0.0f, 0.0f, 0.0f);
list.append(*prim);
}*/ (MOD_2)
1 hour ago, nate67000 said:
 Gracias por una rápida respuesta
Le voy a dar una oportunidad
Gracias
Prueba y error por suerte hoy estaré todo el día conectado me avisas.
OK, I don't think I understand the process I know how to comment out a line
but, I'm not sure were to start to add a line to patch in render.cpp or ui.cpp
I want to have the option to turn on and off the nag screen
I guess i got some learning to do.
Thank you for your help
 Thank you For a quick response
I will give that a try
Thank you
Do u have this tutorial in english
Its hard to understand everything that is going
Thank you for the video.
