Sega causes system to freeze
Digonthathonda
I’m new to hyper spin and to this forum and it seems to be a wealth of knowledge around. I have hyperspin setup and everything worked fine. I was playing Sega genesis games the other day. I got done and turned off my PC. Now, every time I try to select a game, it freezes. It lets me get through all the way through, and freezes at the “now loading” screen. I can see the wheel at the bottom right hand corner still spinning but it does so for as long as I let it before I force close the entire program. What could have changed to cause this?
09:12:21 AM |  HyperSpin Started
09:12:22 AM |  Going FullScreen
09:12:22 AM |  Checking for updates
09:12:22 AM |  Update Check Complete
09:12:22 AM |  Startup program: HyperSpin Startup Script.exe
09:12:22 AM |  Startup params not set
09:12:22 AM |  Working directory: D:\Arcade\Utilities\Startup and Exit\
09:12:22 AM |  Window State: NORMAL
09:12:22 AM |  Launching HyperSpin Startup Script.exe
09:12:22 AM |  Command Line is HyperSpin Startup Script.exe
09:12:30 AM |  Playing intro video
09:13:04 AM |  Menu Mode is multi
09:13:04 AM |  Loading Main Menu.xml
09:13:04 AM |  Main Menu.xml successfully loaded
09:13:05 AM |  Main Menu wheel loaded successfully
09:14:57 AM |  Loading Sega Genesis.xml
09:14:57 AM |  Main Menu.xml successfully loaded
09:14:57 AM |  Sega Genesis wheel loaded successfully
09:15:14 AM |  Launching Game
09:15:14 AM |  Using HyperLaunch
09:15:14 AM |  Getting Launcher path
09:15:14 AM |  Launcher located at D:\Arcade\RocketLauncher\RocketLauncher.exe
09:15:14 AM |  Running Launcher
09:15:16 AM |  Launcher Command Line is: D:\Arcade\RocketLauncher\RocketLauncher.exe "Sega Genesis" "Sonic Classic Heroes (World) (Hack)"
I checked and nothing else is showing in task manager except hyperspin. It’s stays on the loading screen but if I hit the windows button (windows10) and hold my mouse over the HS icon, you can hear the game I was trying to load in the background
Check that Windows Defender, Firewall or anti installed anti virus is not blocking hyperspin in the background and disable/ set exclusions for them if required.
