Launching different versions of Mame
DBrown67
I managed to get hold of an old version of Mame where the Cave shooters were working. So I want to add this to my Hyperspin setup. Obviosuly I don't want to ruin my existing setup. I know I need to add extra lines to the Mame.xml files to tell Hyperspin where to go for those specific titles. This has been done. The roms are in the same folder as the existing mame setup. So I have 2 different .exes and 2 different .inis.
Seems like it should work but Hyperspin keeps saying "cannot find mame64.ini". I called the new addition mame64. I even made a CreateConfig.bat file in Notepad to make the mame.ini file, and it's there. And Hyperspin can not find it.
But if I launch mame64.exe direct from within that folder it all works and I can run the new games. What is wrong please?
Cave sh3 games works on MAME arcade64 0.206, you can download it in donwload section. Timings are a bit off but there is no way to have perfect timings in MAME, you can try shmups MAME but it is no more manteined. You can try also DEMUL, it supports sh3 games.
Mapping games to different emulator is really important as in some cases there is not an emulator that can run them all, the best solution is to implement RocketLauncher as it has roms mapping feature, as example you can use a mixed demul/mame wheel with games mapped to the correct emulator. You can also map retroarch cores, as example some ps1 games don't work with mednafen core but they works in pcsx reloaded core.
