Ipac 4 setup
ness150176
Hello
I'm pretty new to hyperspin and having some troubles setting up my ipac4
I've gone into notepad and tried all the movements to see if there all registering but obviously some of them won't show anything depending on what key there allocated.
I set player 1 to use the arrow keys for movement and space and enter for start select, but they aren't all working on the menu wheel
My understanding was if the button wasn't wired correctly the led light would flash on the ipac?
Can anyone offer any advice as I just keep banging my head against the wall, going round in circles
when I used a keyboard encoder I used this utility to check my buttons
it will display all the keys pressed including space and enter or any other service key
double check that you have everything set up correctly
download keyhook.zip
downloads -->  utilities --> half way down the page
http://arcadecontrols.com/arcade.htm
Quote
  • Keyhook is a utility that displays the keystroke on your screen as you make the connection on the keyboard interface - useful for mapping out your keyboard matrix.  Written by David and given to us to share with everyone.  Thanks David!
14 hours ago, ness150176 said:
Hello
Andy over at Ultimarc had me use this tool when I was having a issue with the buttons acting like they were sticking so give it a try http://www.passmark.com/ftp/keytest.exe. Report back with what you find out and Ill try and help you out :) It will show you if its working or not and we can go from there.
