00ashley Posted June 6, 2014 Posted June 6, 2014 Hey guys, when I try launching a rom in hyperspin nothing happens! The roms work perfectly in hyperlaunch... please help! My logs: 09:01:31 PM | HyperSpin Started 09:01:31 PM | Going FullScreen 09:01:31 PM | Checking for updates 09:01:31 PM | Update Check Complete 09:01:31 PM | Startup program unavailable 09:01:31 PM | Playing intro video 09:01:34 PM | Error intializing joysticks 09:01:34 PM | Menu Mode is multi 09:01:34 PM | Loading Main Menu.xml 09:01:34 PM | Main Menu.xml successfully loaded 09:01:34 PM | Main Menu wheel loaded successfully 09:01:35 PM | Loading MAME.xml 09:01:35 PM | Main Menu.xml successfully loaded 09:01:36 PM | MAME wheel loaded successfully 09:01:37 PM | Launching Game 09:01:37 PM | Using HyperLaunch 09:01:37 PM | Getting HyperLaunch path 09:01:37 PM | HyperLaunch located at C:\HyperSpin\HyperLaunch.exe 09:01:37 PM | Running HyperLaunch.exe 09:01:37 PM | HyperLaunch Command Line is: C:\HyperSpin\HyperLaunch.exe "MAME" "88games" 09:01:42 PM | Launching Game 09:01:42 PM | Using HyperLaunch 09:01:42 PM | Getting HyperLaunch path 09:01:42 PM | HyperLaunch located at C:\HyperSpin\HyperLaunch.exe 09:01:42 PM | Running HyperLaunch.exe 09:01:42 PM | HyperLaunch Command Line is: C:\HyperSpin\HyperLaunch.exe "MAME" "88games" 09:02:52 PM | Loading Main Menu.xml 09:02:52 PM | Main Menu.xml successfully loaded 09:02:53 PM | Main Menu wheel loaded successfully 09:02:54 PM | Exit program unavailable 09:02:54 PM | Quiting Hyperspin 09:02:54 PM | Bye!
rfancella Posted June 6, 2014 Posted June 6, 2014 Hey guys, when I try launching a rom in hyperspin nothing happens! The roms work perfectly in hyperlaunch...please help! My logs: 09:01:31 PM | HyperSpin Started 09:01:31 PM | Going FullScreen 09:01:31 PM | Checking for updates 09:01:31 PM | Update Check Complete 09:01:31 PM | Startup program unavailable 09:01:31 PM | Playing intro video 09:01:34 PM | Error intializing joysticks 09:01:34 PM | Menu Mode is multi 09:01:34 PM | Loading Main Menu.xml 09:01:34 PM | Main Menu.xml successfully loaded 09:01:34 PM | Main Menu wheel loaded successfully 09:01:35 PM | Loading MAME.xml 09:01:35 PM | Main Menu.xml successfully loaded 09:01:36 PM | MAME wheel loaded successfully 09:01:37 PM | Launching Game 09:01:37 PM | Using HyperLaunch 09:01:37 PM | Getting HyperLaunch path 09:01:37 PM | HyperLaunch located at C:\HyperSpin\HyperLaunch.exe 09:01:37 PM | Running HyperLaunch.exe 09:01:37 PM | HyperLaunch Command Line is: C:\HyperSpin\HyperLaunch.exe "MAME" "88games" 09:01:42 PM | Launching Game 09:01:42 PM | Using HyperLaunch 09:01:42 PM | Getting HyperLaunch path 09:01:42 PM | HyperLaunch located at C:\HyperSpin\HyperLaunch.exe 09:01:42 PM | Running HyperLaunch.exe 09:01:42 PM | HyperLaunch Command Line is: C:\HyperSpin\HyperLaunch.exe "MAME" "88games" 09:02:52 PM | Loading Main Menu.xml 09:02:52 PM | Main Menu.xml successfully loaded 09:02:53 PM | Main Menu wheel loaded successfully 09:02:54 PM | Exit program unavailable 09:02:54 PM | Quiting Hyperspin 09:02:54 PM | Bye! Hi, By the looks of this HyperSpin log file. You are using an old HyperLaunch? What version of HyperLaunch are you using? Also, does the rom load and play in MAME? Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
gigapig Posted June 6, 2014 Posted June 6, 2014 Fire up Hyper HQ and remove any check marks from the wheel filters then report back.
00ashley Posted June 6, 2014 Author Posted June 6, 2014 thanks for the replies. I'm using RocketLauncher, I have no issues when just running hyperlaunch or Mame emulator. I also have no check marks on wheel filters. I can get it working by setting it not to launch through hyperlaunch but this is not ideal. any other ideas?
rfancella Posted June 6, 2014 Posted June 6, 2014 thanks for the replies. I'm using RocketLauncher, I have no issues when just running hyperlaunch or Mame emulator. I also have no check marks on wheel filters. I can get it working by setting it not to launch through hyperlaunch but this is not ideal.any other ideas? Yepper. Navigate to HyperSpin\Settings\ and open up Settings.ini in notepad. In the first section you should have the following: [Main] Menu_Mode=multi Single_Mode_Name=MAME Enable_Exit_Menu=true Enable_Exit=true Exit_Default=yes Exit_Action=exit Version=1.0.0.0 Last_System=MAME Hyperlaunch_Path=HyperLaunch\ Some of the values may be different, but look at the last line. If your HyperLaunch directory is inside your HyperSpin directory. Make it look like mine. Otherwise type in the full path to your HyperLaunch directory. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
rfancella Posted June 6, 2014 Posted June 6, 2014 thanks again but still no luck What is your Hyperlaunch_Path set to in the settings.ini? Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
rfancella Posted June 6, 2014 Posted June 6, 2014 I changed it to your suggestion... Cool. Now, try to launch a game and as soon as your done, post your HyperLaunch and HyperSpin logs using code tags as described here: http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm You are not giving us enough information to be very helpful. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
gigapig Posted June 6, 2014 Posted June 6, 2014 You are not giving us enough information to be very helpful. Thanks, Ron True. What version of Hyperspin and Mame are you running? Is Mame your only system, if not dies it happen with other systems? How are your controls setup? What is your launch key?
00ashley Posted June 6, 2014 Author Posted June 6, 2014 Cool. Now, try to launch a game and as soon as your done, post your HyperLaunch and HyperSpin logs using code tags as described here:http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm You are not giving us enough information to be very helpful. Thanks, Ron Please find the logs after I tried to launch a game in hyperspin. The log for hyperlaunch (unless i'm mistaken) is unchanged and only shows the last time I used hyperlaunch. hyperspin: 11:46:20 PM | HyperSpin Started 11:46:20 PM | Going FullScreen 11:46:20 PM | Checking for updates 11:46:20 PM | Update Check Complete 11:46:20 PM | Startup program unavailable 11:46:20 PM | Error intializing joysticks 11:46:20 PM | Menu Mode is multi 11:46:20 PM | Loading Main Menu.xml 11:46:20 PM | Main Menu.xml successfully loaded 11:46:21 PM | Main Menu wheel loaded successfully 11:46:22 PM | Loading MAME.xml 11:46:22 PM | Main Menu.xml successfully loaded 11:46:23 PM | MAME wheel loaded successfully 11:46:25 PM | Launching Game 11:46:25 PM | Using HyperLaunch 11:46:25 PM | Getting HyperLaunch path 11:46:25 PM | HyperLaunch located at C:\HyperSpin\HyperLaunch.exe 11:46:25 PM | Running HyperLaunch.exe 11:46:25 PM | HyperLaunch Command Line is: C:\HyperSpin\HyperLaunch.exe "MAME" "88games" 11:46:29 PM | Loading Main Menu.xml 11:46:29 PM | Main Menu.xml successfully loaded 11:46:29 PM | Main Menu wheel loaded successfully 11:46:32 PM | Exit program unavailable 11:46:32 PM | Quiting Hyperspin 11:46:32 PM | Bye! hyperlaunch: 23:36:22:452 | HL | INFO | +N/A | Main - HyperLaunch v3.0.0.9 23:36:22:453 | HL | INFO | +0 | Main - System Specs: HyperLaunch Dir: C:\HyperSpin OS: WIN_7 Architecture: 64-bit (might not be accurate) OS Language: English_United_States OS Admin Status: Yes Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work) AutoHotkey Path: AHK Version: 1.1.09.04 Unicode: No 23:36:22:453 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x y w h 23:36:22:453 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch.exe exists 23:36:22:454 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Databases\Main Menu\Main Menu.xml exists 23:36:22:503 | HL | INFO | +47 | Main - HyperLaunch launched directly 23:36:33:436 | HL | INFO | +10936 | Main - HyperLaunch received "MAME" and "simpsons" 23:36:33:463 | HL | INFO | +15 | Main - simpsons is using the default emulator: MAME 23:36:33:463 | HL | INFO | +0 | Main - Checking for a [MAME] section in C:\HyperSpin\Settings\MAME\Emulators.ini 23:36:33:464 | HL | INFO | +16 | Main - Checking for a [MAME] section in C:\HyperSpin\Settings\Global Emulators.ini 23:36:33:465 | HL | INFO | +0 | Main - Found [MAME] in C:\HyperSpin\Settings\Global Emulators.ini 23:36:33:466 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Modules\MAME\MAME.ahk exists 23:36:33:488 | HL | INFO | +16 | Main - CRC Check - CRC matches, this is an official unedited module. 23:36:33:488 | HL | INFO | +0 | Main - simpsons will use module: C:\HyperSpin\Modules\MAME\MAME.ahk 23:36:33:507 | HL | INFO | +15 | Main - Using standard method with "Rom Extensions" SkipChecks or without any SkipChecks. 23:36:33:509 | HL | INFO | +0 | Main - INI Keys read 23:36:33:510 | HL | INFO | +16 | CheckFile - Checking if C:\HyperSpin\Module Extensions\7z.exe exists 23:36:33:511 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\7z.dll exists 23:36:33:512 | HL | INFO | +0 | CheckPaths - Started 23:36:33:512 | HL | INFO | +0 | CheckPaths - Found rom: C:\HyperSpin\Emulators\MAME\Roms\simpsons.7z 23:36:33:512 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Emulators\MAME\mame64.exe exists 23:36:33:513 | HL | INFO | +0 | CheckPaths - Ended 23:36:33:513 | HL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 0 frontendPID = 0 frontendPath = C:\HyperSpin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = C: exitEmulatorKey = ~Esc exitEmulatorKeyWait = 0 forceHoldKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s emuFullPath = C:\HyperSpin\Emulators\MAME\mame64.exe emuPath = C:\HyperSpin\Emulators\MAME emuName = MAME emuExt = exe romPath = C:\HyperSpin\Emulators\MAME\Roms romPathFromIni = C:\HyperSpin\Emulators\MAME\Roms romExtension = .7z romExtensionOrig = .7z romExtensions = zip|7z executable = mame64.exe systemName = MAME dbName = simpsons romName = romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfWheelsByScreen = 7 romMappingMenuWidth = 300 romMappingMenuMargin = 50 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s40 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 5 romMappingTextMargin = 10 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s60 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s15 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s15 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 40 romMappingMenuFlagSeparation = 5 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false skipchecks = false romMatchExt = true logFile = C:\HyperSpin\HyperLaunch.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 3 logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = false navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1920 originalHeight = 1080 dtEnabled = true dtPath = dtUseSCSI = true dtAddDrive = true emuIdleShutdown = 0 hideEmu = false hideFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Align to Top Left fadeLyr2Pos = Bottom Right Corner fadeLyr2X = 300 fadeLyr2Y = 300 fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr3Pos = Center fadeLyr3X = 300 fadeLyr3Y = 300 fadeLyr3Adjust = 0.75 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3PicPad = 0 fadeLyr4Adjust = 0.75 fadeLyr4X = 100 fadeLyr4Y = 100 fadeLyr4Pos = Above Layer 3 - Left fadeLyr4FPS = 10 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = false fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 600 fadeBarWindowH = 120 fadeBarWindowR = 20 fadeBarWindowM = 20 fadeBarWindowHatchStyle = 8 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 20 fadeBarR = 5 fadeBarColor = DD00BFFF fadeBarHatchStyle = 3 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 100 fadeRomInfoDescription = text fadeRomInfoSystemName = text fadeRomInfoYear = text fadeRomInfoManufacturer = text fadeRomInfoGenre = text fadeRomInfoRating = text fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = topRight fadeRomInfoTextMargin = 5 fadeRomInfoText1Options = cFF555555 r4 s20 Bold fadeRomInfoText2Options = cFF555555 r4 s20 Bold fadeRomInfoText3Options = cFF555555 r4 s20 Bold fadeRomInfoText4Options = cFF555555 r4 s20 Bold fadeRomInfoText5Options = cFF555555 r4 s20 Bold fadeRomInfoText6Options = cFF555555 r4 s20 Bold fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topLeft fadeStatsInfoTextMargin = 5 fadeStatsInfoText1Options = cFF555555 r4 s20 Bold fadeStatsInfoText2Options = cFF555555 r4 s20 Bold fadeStatsInfoText3Options = cFF555555 r4 s20 Bold fadeStatsInfoText4Options = cFF555555 r4 s20 Bold fadeStatsInfoText5Options = cFF555555 r4 s20 Bold fadeStatsInfoText6Options = cFF555555 r4 s20 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFFFFFFF r4 s20 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFFFFFFF r4 s20 Right Bold fadeText2 = Extraction Complete fadeFont = Arial fadeSystemAndRomLayersOnly = false fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = C:\HyperSpin\Media\Fade HLDataPath = C:\HyperSpin\Data HLMediaPath = C:\HyperSpin\Media HLErrSoundPath = C:\HyperSpin\Media\Sounds\Error modulesPath = C:\HyperSpin\Modules moduleFullName = C:\HyperSpin\Modules\MAME\MAME.ahk moduleName = MAME modulePath = C:\HyperSpin\Modules\MAME moduleExtension = ahk moduleExtensionsPath = C:\HyperSpin\Module Extensions libPath = C:\HyperSpin\Lib 7zEnabled = false 7zPath = C:\HyperSpin\Module Extensions\7z.exe 7zDllPath = C:\HyperSpin\Module Extensions\7z.dll 7zExtractPath = C:\Users\Chris\AppData\Local\Temp\HS 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgYOffset = 500 mgImageAdjust = 1 mgFont = Arial mgText1Options = x10p y30p w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 70 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgArtworkDir = Artwork1 hpEnabled = false hpKey = ~NumpadAdd hpBackToMenuBarKey = X hpZoomInKey = C hpZoomOutKey = V hpScreenshotKey = ~PrintScreen hpHiToTextPath = C:\HyperSpin\Module Extensions\HiToText.exe hpSaveStateKeyCodes = {shift down}{F7 down}{F7 up}{shift up} hpLoadStateKeyCodes = {shift down}{F7 down}{F7 up}{shift up} keymapperEnabled = false keymapper = ahk xpadderFullPath = C:\Utilities\Xpadder\xpadder.exe joyToKeyFullPath = C:\Utilities\JoyToKey\JoyToKey.exe keymapperProfilePath = C:\HyperSpin\Profiles\ahk keymapperFrontEndProfileName = HyperSpin keymapperHyperLaunchProfileEnabled = false JoyIDsEnabled = false JoyIDsPreferredControllersSystem = use_global JoyIDsPreferredControllersGlobal = use_global CustomJoyNamesEnabled = false CustomJoyNames = FEProfile = C:\HyperSpin\Profiles\ahk\HyperSpin defaultProfile = C:\HyperSpin\Profiles\ahk\_Default systemProfile = C:\HyperSpin\Profiles\ahk\MAME xPadderSystemProfile = C:\HyperSpin\Profiles\ahk\MAME\_Default emuProfile = C:\HyperSpin\Profiles\ahk\MAME\MAME romProfile = C:\HyperSpin\Profiles\ahk\MAME\simpsons blankProfile = C:\HyperSpin\Profiles\ahk\blank HyperLaunchProfile = C:\HyperSpin\Profiles\ahk\HyperLaunch bezelEnabled = false statisticsEnabled = true 23:36:33:514 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 23:36:33:514 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 23:36:33:514 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script 23:36:33:516 | HL | INFO | +0 | BuildScript - Module: MEmu = MAME MEmuV = v0.148 MURL = http://www.mame.net/ MAuthor = djvj MVersion = 2.0.6 MCRC = D558F163 iCRC = CD775A90 MID = 635038268903403479 MSystem = "AAE","Cave","LaserDisc","MAME","Nintendo Arcade Systems","Sega Model 1","Sega ST-V","SNK Neo Geo","SNK Neo Geo AES" ;---------------------------------------------------------------------------- ; Notes: ; No need to edit mame.ini and set your rom folder, module sends the rompath for you. ; Command Line Options - http://easyemu.mameworld.info/mameguide/mameguide-options.html ; High Scores DO NOT SAVE when cheats are enabled! ; HLSL Documentation: http://mamedev.org/source/docs/hlsl.txt.html ; MAME 149 is currently bugged and HyperPause support is broken. Emu does not let you alt-tab out. This is a mamedev issue, not an HL one. ; If you use MAME for AAE, create a vector.ini in mame's ini subfolder and paste these HLSL settings in there: http://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=309968&page=&view=&sb=5&o=&vc=1 ;---------------------------------------------------------------------------- StartModule() FadeInStart() settingsFile := CheckFile(modulePath . "\" . moduleName . ".ini") Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) Videomode := IniReadCheck(settingsFile, "Settings", "Videomode","d3d",,1) hideConsole := IniReadCheck(settingsFile, "Settings", "HideConsole","true",,1) ; Hides console window from view if it shows up pauseMethod := IniReadCheck(settingsFile, "Settings", "PauseMethod",1,,1) ; set the pause method that works better on your machine (preferred methods 1 and 2) 1 = Win7 and Win8 OK - Problems with Win XP, 2 = preferred method for WinXP - Problems in Win7, 3 and 4 = same as 1 and 2, 5 = only use If you have a direct input version of mame, 6 = suspend mame process method, it could crash mame in some computers bezelMode := IniReadCheck(settingsFile, "Settings", "BezelMode","layout",,1) ; "layout" or "normal" cheatMode := IniReadCheck(settingsFile, "Settings", "CheatMode","false",,1) cheatModeKey := IniReadCheck(settingsFile, "Settings", "CheatModeKey",A_Space,,1) ; user defined key to be held down before launching a mame rom. sysParams := IniReadCheck(settingsFile, systemName, "Params", A_Space,,1) romParams := IniReadCheck(settingsFile, romName, "Params", A_Space,,1) mameRomName := IniReadCheck(settingsFile, romName, "MameRomName", A_Space,,1) Use_Bezels := IniReadCheck(settingsFile, "Settings", "Use_Bezels", "true",,1) Use_Bezels := IniReadCheck(settingsFile, romName, "Use_Bezels", Use_Bezels,,1) ; default is the system's current setting Use_Overlays := IniReadCheck(settingsFile, "Settings", "Use_Overlays", "true",,1) Use_Overlays := IniReadCheck(settingsFile, romName, "Use_Overlays", Use_Overlays,,1) ; default is the system's current setting Use_Backdrops := IniReadCheck(settingsFile, "Settings", "Use_Backdrops", "true",,1) Use_Backdrops := IniReadCheck(settingsFile, romName, "Use_Backdrops", Use_Backdrops,,1) ; default is the system's current setting If bezelEnabled = true { ListXMLtable := [] ListXMLtable := ListXMLInfo(romName) If bezelMode = layout { useBezels := If (Use_Bezels = "true") ? "-use_bezels" : "-nouse_bezels" useOverlays := If (Use_Overlays = "true") ? "-use_overlays" : "-nouse_overlays" useBackdrops := If (Use_Backdrops = "true") ? "-use_backdrops" : "-nouse_backdrops" BezelStart(romName,ListXMLtable[1],ListXMLtable[2],ListXMLtable[3],ListXMLtable[4]) } Else { useBezels := "-nouse_bezels" useOverlays := "-nouse_overlays" useBackdrops := "-nouse_backdrops" BezelStart(,,ListXMLtable[2]) } } ; -romload part of 147u2 that shows what roms were checked when missing roms winstate := If (Fullscreen = "true") ? "Hide UseErrorLevel" : "UseErrorLevel" fullscreen := If (Fullscreen = "true") ? "-nowindow" : "-window" videomode := If (Videomode != "" ) ? "-video " . videomode : "" sysParams := If sysParams != "" ? sysParams : "" romParams := If romParams != "" ? romParams : "" StringReplace,mameRomPaths,romPathFromIni,|,`"`;`",1 ; replace all instances of | to ; in the Rom_Path from Emulators.ini so mame knows where to find your roms mameRomPaths := "-rompath """ . (If mameRomName ? romPath : mameRomPaths) . """" ; if using an alt rom, only supply mame with the path to that rom so it doesn't try to use the original rom If InStr(romParams,"-rompath") ScriptError("""-rompath"" is defined as a parameter for " . romName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.") If InStr(sysParams,"-rompath") ScriptError("""-rompath"" is defined as a parameter for " . systemName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.") If mameRomName { FileMove, %romPath%\%romName%%romExtension%, %romPath%\%mameRomName%%romExtension% ; rename rom to match what mame needs originalRomName := romName ; store romName from database so we know what to rename it back to later romName := mameRomName If ErrorLevel ScriptError("There was a problem renaming " . romName . " to " . mameRomName . " in " . romPath . ". Please check you have write permission to this folder/file and you don't already have a file named """ . mameRomName . """ in your rom folder.",8) Else ; if rename was successful, set var so we know to move it back later fileRenamed = 1 } If cheatMode = true { If cheatModeKey ; if user wants to use a key to enable CheatMode cheatEnabled := If XHotkeyAllKeysPressed(cheatModeKey) ? "-cheat" : "" Else ; no cheat mode key defined cheatEnabled := "-cheat" } If hideConsole = true SetTimer, HideConsole, 10 Run(executable . A_Space . romName . A_Space . fullscreen . A_Space . cheatEnabled . A_Space . videomode . A_Space . useBezels . A_Space . useOverlays . A_Space . useBackdrops . A_Space . mameRomPaths . A_Space . sysParams . A_Space . romParams, emuPath, winstate) If(ErrorLevel != 0){ If (ErrorLevel = 1) Error = Failed Validity Else If(ErrorLevel = 2) Error = Missing Files Else If(ErrorLevel = 3) Error = Fatal Error Else If(ErrorLevel = 4) Error = Device Error Else If(ErrorLevel = 5) Error = Game Does Not Exist Else If(ErrorLevel = 6) Error = Invalid Config Else If ErrorLevel in 7,8,9 Error = Identification Error Else Error = MAME Error ScriptError("MAME Error - " . Error) } WinWait("ahk_class MAME") WinWaitActive("ahk_class MAME") BezelDraw() FadeInExit() Process("WaitClose", executable) BezelExit() If fileRenamed { ; rename file back to alternate name for next launch FileMove, %romPath%\%romName%%romExtension%, %romPath%\%originalRomName%%romExtension% If ErrorLevel ; if rename was successful, set var so we know to move it back later ScriptError("There was a problem renaming " . romName . " back to " . originalRomName) } FadeOutExit() ExitModule() ListXMLInfo(rom){ ; returns MAME/MESS info about parent rom, orientation angle, resolution Global emuFullPath, emuPath ListXMLtable := [] RunWait, % comspec . " /c " . """" . emuFullPath . """" . " -listxml " . rom . " > tempBezel.txt", %emuPath%, Hide Fileread, ListxmlContents, %emuPath%\tempBezel.txt RegExMatch(ListxmlContents, "s)<game.*name=" . """" . rom . """" . ".*" . "cloneof=" . """" . "[^""""]*", parent) RegExMatch(parent,"cloneof=" . """" . ".*", parent) RegExMatch(parent,"""" . ".*", parent) StringTrimLeft, parent, parent, 1 RegExMatch(ListxmlContents, "s)<display.*rotate=" . """" . "[0-9]+" . """", angle) RegExMatch(angle,"[0-9]+", angle, "-6") RegExMatch(ListxmlContents, "s)<display.*width=" . """" . "[0-9]+" . """", width) RegExMatch(width,"[0-9]+", width, "-6") RegExMatch(ListxmlContents, "s)<display.*height=" . """" . "[0-9]+" . """", Height) RegExMatch(Height,"[0-9]+", Height, "-6") ListXMLtable[1] := parent ListXMLtable[2] := angle If (ListXMLtable[2]<>0) ListXMLtable[3] := height Else ListXMLtable[3] := width If (ListXMLtable[2]<>0) ListXMLtable[4] := width Else ListXMLtable[4] := height FileDelete, %emuPath%\tempBezel.txt Return ListXMLtable } HaltEmu: If pauseMethod = 1 { disableSuspendEmu = true disableRestoreEmu = true PostMessage,0x211, 1, , , ahk_class MAME } Else If pauseMethod = 2 { disableSuspendEmu = true PostMessage,0x211, 1, , , ahk_class MAME } Else If pauseMethod = 3 { disableSuspendEmu = true disableRestoreEmu = true PostMessage,% 0x0400+6, 1, , , ahk_class MAME } Else If pauseMethod = 4 { disableSuspendEmu = true PostMessage,% 0x0400+6, 1, , , ahk_class MAME } Else If pauseMethod = 5 { disableSuspendEmu = true Send, {P down} Sleep, 1000 Send, {P up} } Return RestoreEmu: If pauseMethod = 1 { PostMessage,0x212, 1, , , ahk_class MAME WinActivate, ahk_class MAME } Else If pauseMethod = 2 { PostMessage,0x212, 1, , , ahk_class MAME WinActivate, ahk_class MAME } Else If pauseMethod = 3 { PostMessage,% 0x0400+6, 0, , , ahk_class MAME WinActivate, ahk_class MAME } Else If pauseMethod = 4 { PostMessage,% 0x0400+6, 0, , , ahk_class MAME WinActivate, ahk_class MAME } Else If pauseMethod = 5 { disableSuspendEmu = true Send, {P down} Sleep, 1000 Send, {P up} WinActivate, ahk_class MAME } Else If pauseMethod = 6 WinActivate, ahk_class MAME Return HideConsole: hideConsoleTimer++ IfWinExist, ahk_class ConsoleWindowClass { Log("Module - HideConsole - Console window found, hiding it out of view.") WinSet, Transparent, 0, ahk_class ConsoleWindowClass SetTimer, HideConsole, Off } Else If hideConsoleTimer >= 200 SetTimer, HideConsole, Off Return CloseProcess: FadeOutStart() WinClose("ahk_class MAME") Return 23:36:33:517 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 23:36:33:517 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script 23:36:33:517 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 23:36:33:517 | HL | INFO | +0 | Main - Module is built 23:36:33:517 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\AutoHotkey.dll exists 23:36:33:518 | HL | INFO | +0 | Main - Running module 23:36:33:634 | MD | INFO | +N/A | Module initialized 23:36:33:657 | MD | INFO | +31 | StartModule - Started 23:36:33:657 | MD | INFO | +0 | StartModule - MEmu: MAME MEmuV: v0.148 MURL: http://www.mame.net/ MAuthor: djvj MVersion: 2.0.6 MCRC: D558F163 iCRC: CD775A90 MID: MSystem: "AAE","Cave","LaserDisc","MAME","Nintendo Arcade Systems","Sega Model 1","Sega ST-V","SNK Neo Geo","SNK Neo Geo AES" 23:36:33:657 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "MAME" 23:36:33:658 | MD | INFO | +0 | StartModule - Ended 23:36:33:658 | MD | INFO | +0 | StartGlobalUserFeatures - Starting 23:36:33:658 | MD | INFO | +0 | StartGlobalUserFeatures - Ending 23:36:33:658 | MD | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Modules\MAME\MAME.ini exists 23:36:33:659 | MD | INFO | +0 | Module Setting - Fullscreen: true 23:36:33:659 | MD | INFO | +0 | Module Setting - Videomode: d3d 23:36:33:659 | MD | INFO | +0 | Module Setting - HideConsole: true 23:36:33:659 | MD | INFO | +0 | Module Setting - PauseMethod: 4 23:36:33:659 | MD | INFO | +0 | Module Setting - BezelMode: normal 23:36:33:659 | MD | INFO | +0 | Module Setting - CheatMode: true 23:36:33:659 | MD | INFO | +0 | Module Setting - CheatModeKey: Z&X 23:36:33:660 | MD | INFO | +0 | Module Setting - Use_Bezels: true 23:36:33:660 | MD | INFO | +0 | Module Setting - Use_Bezels: true 23:36:33:660 | MD | INFO | +0 | Module Setting - Use_Overlays: true 23:36:33:660 | MD | INFO | +0 | Module Setting - Use_Overlays: true 23:36:33:660 | MD | INFO | +0 | Module Setting - Use_Backdrops: true 23:36:33:660 | MD | INFO | +0 | Module Setting - Use_Backdrops: true 23:36:33:660 | MD | INFO | +0 | Module Run - Running: C:\HyperSpin\Emulators\MAME\mame64.exe simpsons -nowindow -video d3d -rompath "C:\HyperSpin\Emulators\MAME\Roms" 23:36:33:682 | MD | INFO | +31 | Module WinWait - Waiting for ahk_class MAME 23:36:33:731 | MD | INFO | +47 | Module - HideConsole - Console window found, hiding it out of view. 23:36:34:004 | MD | INFO | +265 | Module WinWaitActive - Waiting for "ahk_class MAME" 23:36:34:104 | MD | INFO | +110 | Module Process - WaitClose mame64.exe 23:41:41:899 | MD | INFO | +307790 | Module WinClose - Closing: ahk_class MAME 23:41:42:215 | MD | INFO | +312 | StopGlobalUserFeatures - Starting 23:41:42:215 | MD | INFO | +0 | StopGlobalUserFeatures - Ending 23:41:42:215 | MD | INFO | +0 | ExitModule - Started 23:41:42:215 | MD | INFO | +0 | Starting Updating Statistics: 23:41:42:215 | MD | INFO | +0 | CreateRomTable - Started 23:41:42:215 | MD | INFO | +0 | CreateRomTable - Ended, 7 Loops to create table. 23:41:42:285 | MD | INFO | +78 | Game section statistics updated. 23:41:42:285 | MD | INFO | +0 | ExitModule - Ended 23:41:42:285 | MD | INFO | +0 | End of Module Logs 23:41:42:364 | HL | INFO | +308851 | Main - Module ended, exiting HyperLaunch normally 23:41:42:364 | HL | INFO | +0 | ExitScript - Started 23:41:42:404 | HL | INFO | +31 | SystemCursor - Restoring mouse cursor 23:41:42:420 | HL | INFO | +15 | ExitScript - Ended i hope this helps
00ashley Posted June 7, 2014 Author Posted June 7, 2014 True.What version of Hyperspin and Mame are you running? Is Mame your only system, if not dies it happen with other systems? How are your controls setup? What is your launch key? Sorry for the lack of info. Hopefully my logs will appear here after the mods have approved. The hyperspin log if very similar to the original I posted, the hyperlaunch log is unchanged by attempting to open a game in hyperspin. I am running Hyperspin v1.32, Mame64 v0.153. Mame is not the only system and the same thing happens to Atari5200 (kat5200), Nintendo64 (project64 v1.7), Gameboy Advance (VisualBoyAdvance v1.8). Each of these work in hyperlaunch, just not hyperspin. The controls are setup using an iPac2 on default settings, the launch key is set to shift. I have attempted using default settings for controls using my keyboard. The system did work originally, however it stopped after I installed it in the cabinet and set up the controls. I also used Don's tools to create a database file (note that I have attempted using the original with no success), and I also unzipped a load of artwork and video files which all work in Hyperspin. Hope this helps...
gigapig Posted June 7, 2014 Posted June 7, 2014 I was comparing my log to yours. 11:03:18 AM | HyperSpin Started 11:03:18 AM | Going FullScreen 11:03:18 AM | LEDBlinky is set to active 11:03:18 AM | Found LEDBlinky.exe 11:03:18 AM | Running LEDBlinky 11:03:18 AM | Command Line is: "O:\HyperSpeech v0.9\LEDBlinky.exe" 1 11:03:18 AM | Checking for updates 11:03:18 AM | Update Check Complete 11:03:18 AM | Startup program: HS Startup.exe 11:03:18 AM | Startup params not set 11:03:18 AM | Working directory: O:\ 11:03:18 AM | Window State: NORMAL 11:03:18 AM | Launching HS Startup.exe 11:03:18 AM | Command Line is HS Startup.exe 11:03:18 AM | Playing intro video 11:03:20 AM | Error intializing joysticks 11:03:20 AM | Menu Mode is multi 11:03:20 AM | Loading Main Menu.xml 11:03:20 AM | Command Line is: "O:\HyperSpeech v0.9\LEDBlinky.exe" 8 11:03:20 AM | Main Menu.xml successfully loaded 11:03:21 AM | Main Menu wheel loaded successfully 11:03:37 AM | Loading MAME.xml 11:03:37 AM | Command Line is: "O:\HyperSpeech v0.9\LEDBlinky.exe" 7 "MAME" 11:03:37 AM | Main Menu.xml successfully loaded 11:03:37 AM | MAME wheel loaded successfully 11:03:38 AM | Command Line is: "O:\HyperSpeech v0.9\LEDBlinky.exe" 9 "mysticri" 11:03:47 AM | Launching Game 11:03:47 AM | Command Line is: "O:\HyperSpeech v0.9\LEDBlinky.exe" 3 "mysticri" "MAME" 11:03:47 AM | Using HyperLaunch 11:03:47 AM | Getting HyperLaunch path 11:03:47 AM | HyperLaunch located at O:\HyperLaunch\HyperLaunch.exe 11:03:47 AM | Running HyperLaunch.exe 11:03:47 AM | HyperLaunch Command Line is: O:\HyperLaunch\HyperLaunch.exe "MAME" "mysticri" 11:03:48 AM | Command Line is: "O:\HyperSpeech v0.9\LEDBlinky.exe" 4 11:04:16 AM | Command Line is: "O:\HyperSpeech v0.9\LEDBlinky.exe" 4 11:04:16 AM | Command Line is: "O:\HyperSpeech v0.9\LEDBlinky.exe" 4 11:04:22 AM | Command Line is: "O:\HyperSpeech v0.9\LEDBlinky.exe" 4 11:04:23 AM | Loading Main Menu.xml 11:04:23 AM | Command Line is: "O:\HyperSpeech v0.9\LEDBlinky.exe" 8 11:04:23 AM | Main Menu.xml successfully loaded 11:04:23 AM | Main Menu wheel loaded successfully 11:04:27 AM | Exit program unavailable 11:04:27 AM | Quiting Hyperspin 11:04:27 AM | Command Line is: "O:\HyperSpeech v0.9\LEDBlinky.exe" 2 11:04:27 AM | Bye! Is Hyperlaunch.exe in the Hyperspin folder? I have Hyperlaunch in it's own folder inside the Hyperspin folder and the Hyperlaunch HQ is then in a folder within the Hyperlaunch folder. So you path to Hyperlaunch, I think, should be C:\Hyperspin\Hyperlaunch\Hyperlaunch.exe If you have it all mixed into the same folder your heading for problems.
