iceman1981 Posted June 4, 2019 Posted June 4, 2019 Running into an issue with Kfusion. Had an issue with Snes9x as well...Emulators always work in rlauncher but have different effects in hyperlauch. Kfusion is working with ESC to close in rlauncher. However in hyperspin/hyperlaunch this is not working, any ideas?
Spawk Posted June 5, 2019 Posted June 5, 2019 Running into an issue with Kfusion. Had an issue with Snes9x as well...Emulators always work in rlauncher but have different effects in hyperlauch. Kfusion is working with ESC to close in rlauncher. However in hyperspin/hyperlaunch this is not working, any ideas?You either use RL or hyperlaunch... not both! If your RL is set up properly you can delete the hyperlaunch folder altogether.Open /hyperspin/settings/settings.cfg and make sure the path is to Rocketlaucher.exe and not hyperlaunch.Sent from my SM-A520W using Tapatalk
iceman1981 Posted June 5, 2019 Author Posted June 5, 2019 i did this, but im still having the same issues. If i launch a sega game with RocketLauncher.exe, i test a bunch of games, and they open just fine. I hit the ESC key and the emulator closes. When i run in Hyperspin, the ESC key just changes from fullscreen to a smaller screen.
Spawk Posted June 5, 2019 Posted June 5, 2019 i did this, but im still having the same issues. If i launch a sega game with RocketLauncher.exe, i test a bunch of games, and they open just fine. I hit the ESC key and the emulator closes. When i run in Hyperspin, the ESC key just changes from fullscreen to a smaller screen.Again, this still sounds like you are not connected properly. Works in RLUI but not HS?You have Hyperspin set as active and default frontend in RLUI?Sent from my SM-A520W using Tapatalk
iceman1981 Posted June 5, 2019 Author Posted June 5, 2019 in RLUI, in frontends, i have RocketLauncherUI, "UI PLugin - RLUI", "RL plugin: RLUI", this is where all my systems show up(only have 3, NES, SNES, and working on GEN) I changed the DEFAULT/ACTIVE to Hyperspin/hyperspin as you suggested, and all of the systems showed up under global(which is what i remember from the last time i set up Hyperspin, before hyperlauncher switched to rocketlauncher) The systems i set up, all show the emulators and roms. all launch through this UI and the rocketlauncher.exe However running sega through hyperspin refuses to close on the ESC key, just minimizes the window. top of RLUI window says : "FE = hyperspin | Plugin = hyperspin] I am not sure how else to point hyperspin to behave like RL
Spawk Posted June 5, 2019 Posted June 5, 2019 Not sure what else to say other than it sounds like HS is still using hyperlaunch.I have run across emulators that just wouldnt exit with esc before. Being a joytokey user I simply use it to send "alt f4" instead.Clearly if it works in RL you shouldnt need to go this route, but it is an option. Have you tried with different emu?Sent from my SM-A520W using Tapatalk
iceman1981 Posted June 5, 2019 Author Posted June 5, 2019 Also, i went over to my arcade and checked the config, aside from it being Hyperlauncher HQ, everything for sega genesis is the same. I even tried copying the ahk and isd files over, but that only caused errors Also tried the version of the emulator on the arcade(a bit older) and it does it as well...Raspberry Pi is looking good about now, lol
