gr0bda Posted July 11, 2019 Posted July 11, 2019 I don't understand what is going on. Everything was working fine the first couple of days and now HS freezes. I went from like middle of B to middle of C and all of a sudden it wouldn't display the video and it would freeze. at first for maybe for 10 sec? then it recovers once and will let me scroll up or down maybe one or couple of spaces and then it freezes again for good pretty much. When I use alt+ctrl+del and bring the task manager the task bar on the bottom disappears and the HS process in task manager is also gone and I can start HS, but it freezes again pretty much immediately. What could be causing this weird behavior? EDIT: So I see now that at some point after I was scrolling the video didn't kick in. I left it alone it never did show up. But HS didn't fully freeze. Animated Joystick was still moving. It eventually scrolled on its own to another game. Video showed up, displayed the video and video froze. I left it alone and it spun again and now it seem to be working on its own just fine. Odd, no?
Creezz67 Posted July 11, 2019 Posted July 11, 2019 On 7/11/2019 at 1:57 AM, gr0bda said: I don't understand what is going on. Everything was working fine the first couple of days and now HS freezes. I went from like middle of B to middle of C and all of a sudden it wouldn't display the video and it would freeze. at first for maybe for 10 sec? then it recovers once and will let me scroll up or down maybe one or couple of spaces and then it freezes again for good pretty much. When I use alt+ctrl+del and bring the task manager the task bar on the bottom disappears and the HS process in task manager is also gone and I can start HS, but it freezes again pretty much immediately. What could be causing this weird behavior? EDIT: So I see now that at some point after I was scrolling the video didn't kick in. I left it alone it never did show up. But HS didn't fully freeze. Animated Joystick was still moving. It eventually scrolled on its own to another game. Video showed up, displayed the video and video froze. I left it alone and it spun again and now it seem to be working on its own just fine. Odd, no? Expand sounds like some of your videos may be an issue (wrong format for Hyperspin) Try temporarily removing the videos completely to see if it still freezes up. If it doesn't then you have narrowed down the issue. Also could be the wheelart if you have a format other than png in your wheel set.
gr0bda Posted July 12, 2019 Author Posted July 12, 2019 I'll try thanks for the reply (it did it again today unfortunately, but it didn't recover)
