Horizon chase turbo
KTMSPARK
Hi , I have added this pc game to HS like normal, game runs fine , no issues , I have set no stick mapping profile to run with Pc games as i use the xbox one controller fine
My issue is as follows
In the game the B button is back /brake ( as it is in many games) , My issue is that when i press the b button then Hypersin sees it as escape and dumps me out of game and back to HS menu
other games can use the b button as back and do not do this .
Am i missing a setting , or is there no fix?
TIA
If you are correctly set up with joytokey in RL the best thing to do is create a totally blank profile for each game you have like this so it has a profile to load instead of staying on the current HS profile.
i use xpadder but disabled for all pc games , are u saying that i setup a profile for game with no button settings at all?
thanks for info , i will try that
