Removing Xbox Controller Screen from Hyperspin startup
Angrymic2002
So the Hyperspin setup that I have originated from Mad Little Pixels image.  It is designed to be used with an Xbox controller and thus the Special Art shows Xbox buttons and there is a screen that pops up after the into video that shows the Xbox controller mapping.  This drive is going into a dedicated arcade cabinet so i would like to remove that screen.  I figured that it would be special art on the Main Menu wheel but it is not.  I did manage to change the special art back to the default arcade controllers for each wheel but I cannot figure out how to get this screen removed.  Any ideas on how to remove this?  Thanks
that is the Search theme found in \Media\Main Menu\Themes\ Search.zip
use HyperTheme to modify it. what i did was replace the images inside with my own images of the same dimensions.
