Xpadder profile not changing automatically
Hello Everyone,
I will share my situation. Thank you to all of those will help me. (sorry for the pictures, some are in french, but will probably recognize the settings)
- I ve installed hyperspin with some systems & games, everything seem to work fine with the keyboard
- Unfortunatelly, I could not managed to configure Xpadder for my arcade pad (homemade)
I have:
2 joysitcks + 2x6 buttons + 2x2 buttons (start+Select) + 1 Button (that is used to exit at the moment, but at the end I would like it to be the "coin" & exit button)
Before diving into my settings, my REAL problem is that, as the title says, Xpadder does not change profiles automatically when I launch a game.
Please help me solve this issue (if you need more info dont hesitate to ask)
EDIT: For key mapper, this is an example of my config of one system, but all systems are more or less the same.
Xpadder
Rocket Launcher UI
1908881933_controlsGeneralsettingsRLUI.thumb.PNG.9d0d3d43bbbab3d470c3bb3040252b72.PNG
787552299_thridpartyGeneralsettingsRLUI.thumb.PNG.1c2f9afc9db454ab1f42b46b3d350521.PNG
KeyMapper
simple solution for you
don't use Xpadder
Unless you are running 5-10 year old emulators;  every single modern emulator supports direct joystick mapping
So map all your emulators directly to your joystick controller.
the only problem you will find with using a joystick is that Hyperspin does not support joystick controls.
Disable Joystick use in Hyperspin
and use the startupscript to map your Joystick to control Hypeespin
it was made for a 360 controller but you can remap all the butotns in the
 HyperSpin Startup Script.INI
example
change if the default exit button is set to button 7   change it to   button 3
Joystick_Exit=Joy7      --->   Joystick_Exit=Joy3
I have not used Xpadder in a very long time  but I"m almost certain
that you need to define a preferred controller  in order for Xpadder to work.
I did it on a per emulator basis given that I used my
Preferred controller --> Arcade buttons for arcade games
and
Preferred
Controller -->  a 360 controller for console games.
8 hours ago, xandrae said:
KeyMapper
