HS Start up script
Mrmikey73
Wondering if I did something wrong? I followed @ninja2bceen video on setting up the HS Start up script. Everything loads but a little laggy which is fine but then when I select a game the wheel spins for a few seconds before the game loads. Seems like the profiles for joytokey take time to load causing the lag but that is just a guess. Heres my ini if that could help?
 [Required]
HyperSpin_Folder_Path=E:\HyperSpin
[General]
Primary_Color_RRGGBB=363636
Secondary_Color_RRGGBB=ffffff
[Controls]
Joysticks_Enabled=true
Joysticks_MaxNumberOfJoysticks=4
Joystick_Delay=225
Joystick_Deadzone=25
Joystick_Up=JoyY-|JoyPOVN
Joystick_Down=JoyY+|JoyPOVS
Joystick_SkipUp=JoyX-|JoyPOVW
Joystick_SkipDown=JoyX+|JoyPOVE
Joystick_SkipUpNumber=Joy5
Joystick_SkipDownNumber=Joy6
Joystick_HyperSpin=JoyZ-|JoyZ+|Joy9
Joystick_Genre=Joy3
Joystick_Favorites=Joy4
Joystick_Start=
Joystick_Exit=Joy2
Joystick_Roulette=Joy7
Joystick_Volume=JoyR-
Joystick_Volume_Close=
Joystick_QuickLaunch=JoyU+
Joystick_QuickLaunch_Close=JoyU-
Joystick_Info=JoyU-
Joystick_Info_Close=JoyU+
Joystick_Filters=JoyR+
Joystick_Filters_Close=JoyR-
[Startup]
Minimize_Background_Windows_Enabled=false
Window_Classes_To_Not_Minimize=Shell_TrayWnd,Button
Process_Name_To_Close_1=
Program_To_Run_Target_1=JoyToKey.exe
Program_To_Run_Working_Dir_1=E:\HyperSpin\Utilities\JoyToKey_en  5.8.1 (CLM)
Program_To_Run_MaxMinHide_1=Min
[Exit]
Restore_Windows_On_Exit=True
Program_To_Run_Target_1=joytokeykill.bat
Program_To_Run_Working_Dir_1=E:\HyperSpin\RocketLauncher\Profiles\JoyToKey
Program_To_Run_MaxMinHide_1=min
[Roulette]
Roulette_Key=~1
Roulette_Min_MilliSeconds=3000
Roulette_Max_MilliSeconds=8000
[Volume_Menu]
Volume_Menu_Key=~2
Volume_Bar_Offset_From_Bottom=44
[QuickLaunch]
QuickLaunch_Key=~3
QuickLaunch_Enabled=true
QuickLaunch_Left_Offset=5
QuickLaunch_Top_Offset=10
QuickLaunch_Bottom_Offset=10
Item_1_Path=
Item_1_Parameters=
Item_1_LogoPath=
Item_1_Ignore_Process_Close=false
the wheel spinning is likely because in hyperhq you have hyperspin button on one of the buttons in this script. You could change your controls in hyperhq for hyperspin or change one of the quicklaunch keys here?
I figured it out. I use 1 to launch my games and in the start up script ini 1 is for roulette so I changed it to something else in the start up script and works perfect.
