Adding Hyper NeoGeo 64 to MAME module?
jd83jd83
Hi, I have added Hyper NeoGeo 64 system to my setup. I have everything except I cannot launch games from HS/RL. I am able to launch the games from MAME, so I'm sure the issue is in the module. I don't know much about programming, so I have come here for help. All I know is to add the system name to the MSystem line. When I launch through HS/RL, it opens MAME, and I see MAME quickly show "Loading Machine xx%" but then it just closes. I know I'm missing something from the module.
Does anyone know what I'm missing?
Thank you
Thank you
If you have added system name to MAME module, then check in RocketLauncher that skip checks is set to rom only (if using a split romset) or rom extension (if using a merged romset)
Also that 7z is set to false.
Hi,  Thank you for the reply. Sorry didn't work. My roms are in separate zip files, they look like mame roms. My 7z is always set to false (globally) and I tried all the different "skip checks" options. I get the same result either way.
What version of MAME roms are you using ?
If it is above 0.211 your module may be out of date.
New one to use after MAME 0.211 if you do not have it.
I figured out the problem. It had nothing to do with the module. Something to do with duplicate roms, or rom location.
I had the roms in both my MAME roms folder and a separate folder for Hyper NeoGeo 64 roms. I had RL pointed to the Hyper NeoGeo 64 folder.
So, I deleted the Hyper NeoGeo 64 roms folder and pointed RL to my MAME roms folder. Now it launches just fine.
Thank you for your help.
