onehawkeye Posted June 23, 2014 Posted June 23, 2014 I have been configuring Hyperspin on a new machine I recently built and have now found out that my Intel Core i3-4130 Haswell Dual-Core 3.4GHz LGA 1150 54W Processor with Intel HD Graphics 4400 won't play .mp4 videos in Hyperspin due to the Intel 4400 so now I need to purchase a video card to have videos in Hyperspin. Will this card be sufficient for Hypersping and MAME? I don't won't to purchase it to fix one issue and end up causing other issues? MSI N650-MD1GD5/OC GeForce GTX 650 1GB 128-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready Video Card http://www.newegg.com/Product/Product.aspx?Item=N82E16814127703 Thank you in advance for any advice.
dougan78 Posted June 24, 2014 Posted June 24, 2014 You can test disabling hardware acceleration in flash to see if the vids play. http://www.hyperspin-fe.com/forum/showthread.php?22735-Hyperspin-Intel-HD4000-No-Videos/page16 Sent from my SCH-I545 using Tapatalk
onehawkeye Posted June 26, 2014 Author Posted June 26, 2014 Yep, tried all the methods I could find for disabling hardware acceleration. The youtube method did not work since they use HTML5 now instead of flash. I tried selecting 'Use software rendering instead of GPU rendring' in IE I tried going into the advanced display properties in Windows 8 and the Troubleshooting tab where you would disable it has been replaced by the Intel control panel which does not give an option to disable any kind of acceleration. Any other ideas or comments on the video card?
Benzinbruder Posted June 30, 2014 Posted June 30, 2014 I'm having the same problem here. I have disabled hardware acceleration (just go to the Adobe Flash homepage, you'll find a Flash object there), but it didn't allow Hyperspin to work properly. I can't really believe this can be such an issue. Neither .flv nor .mp4 files work for me in Hyperspin. How can that be? If there absolutely is no other option, I'll have to get a dedicated video card. Any moderately priced suggestion? HLSL in MAME is a must! Apart from that, I am mostly interested in the emulation of older consoles (Sega, Nintendo NES, SNES, etc.). Edit: I disabled flash hardware acceleration in IE (right click a flash video and go to Settings, then uncheck the box for hardware acceleration). It did not work when I applied the same setting with Chrome before by the way! However, everything seems to run fine now!
mame68130 Posted July 18, 2015 Posted July 18, 2015 I am able to get flash videos to work, but I am unable to get the MP4 preview/snap videos to play. I have a small media PC that uses a j1900 celeron processor with on chip GPU without hardware acceleration. I have installed VLC and upgraded from windows 7 to windows 8.1 Pro. VLC is installed and I can play MP4 files, but the snap videos are garbled. I appreciate any help! Thank you
pofo14 Posted July 18, 2015 Posted July 18, 2015 The onboard chip gpu won't play the videos. I don't know the reason, but I know I had the issue originally and had to put in a seperate graphics card.
thcdgaf Posted July 18, 2015 Posted July 18, 2015 its not the video card check on codec such as klites codec
Agrajag Posted July 18, 2015 Posted July 18, 2015 Check the known bugs link in my sig below. There's a workaround, and it's been fixed in the new beta version. HyperSpin behaving oddly? Read about known bugs here: http://www.hyperspin-fe.com/topic/4590-known-bugs-and-handy-hints-for-hyperspin/ The installer for HyperSpin now includes HyperLaunch 2. Go here for support: http://www.hyperspin-fe.com/forum/122-hyperlaunch-2/ HyperLaunch3 is now called RocketLauncher. Go here for support: http://www.rlauncher.com/forum/content.php Read this for ftp login info: http://www.hyperspin-fe.com/topic/2320-ftp-access-must-read/ Platinum members get 25% off an Emumovies subscription: http://www.hyperspin-fe.com/topic/1211-emumovies-code/
dmoseder Posted July 22, 2015 Posted July 22, 2015 The Ie method worked for me, you just have to restart your PC after you change the settings.
