JoyToKey
fettesLama
Hi guys.
i have setup JoyToKey Keymapper for HyperSpin. Imade it launch at Startup with HyperHQ.
It works fine. But I want it to work ONLY in Hyperspin, so if I tab out for example in my Browser it shouldn´t work. Is there a setting for this?
Thanks
no
use the startup script instead,  it will only control your Hyperspiin menu
you can map your joystick directly to the emulator you launch,  the startup script will not be active
Hi thank you for the fast answer.
I tried Startup script and I use it for e.g. Randomizer.But if i turn on Controls sometimes they dont work.
Currently I just enabled the Controls in HyperHQ. I will try Startup-Scripz Controls again.
Thanks
What should I use for Xbox One Controller?
And I use JoyToKey to leave my Emulators. Is there another Soulution?
the start up script was built for a 360 controller but it works with any USB controller
you should not have controller enabled in HyperHQ
is Randomizer a game?   the startup script is to control  the Hyperspin Menu and nothing else!!!!
Map your controller directly to every emulator and PC game you have in your system
I don't know what you mean by bartop  arcade buttons.
you can map  a single joy button  or a combination of joy buttons to exit the emulators in RocketLauncher
if you are using a Xbox One controller I suggest    you map  Start+Back =  exit emulator
