Configuring retroarch with sammy atomiswave or sega naomi
angus81
am stuck with this error while trying to run atomiswave or Naomi through RetroArch in RocketLauncher. It works outside of RL, but when trying to launch the game through HyperSpin, I get this error:
There was an error waiting for the window "RetroArch ahk_class RetroArch". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem.
Every time I’ve had this error It was a compatibility issue with the module and emulator. You can head over to rocket launcher and see if there’s an updated module. I think I had to do this as well.
Make sure your RA module MSystem has Sammy Atomiswave and Sega Naomi in the list
Also make sure you have the flycast core setup in the cores and you are using MAME roms for your games.
Dear Creezz67, many thanx for your help. I've checked and both this things are ok
Then it's either your RocketLauncher setup or the RA module.
Works perfect with RA with flycast and MAME roms on both.
