Can I transfer working Daphne files to Hyperspin?
Kraftman
I have Daphne running great on my Raspberry Pi via Retropie with many working ROMS.  I just built a Hyperspin machine and I want to know if it's possible to transfer the files from my Pi over to my Hyperspin machine and have it work.  I assume I'd have to manually edit some file paths in the settings.  Has anyone done this successfully?  Thanks in advance.
Roms for emulators don't change  based on the hardware or operating system you are using
I took roms from my  Hyperspin setup  and built a  pie.
for Daphne
you can drag and drop the roms and Mpeg files  in your Daphne emulator folder
the only thing you need to do is update the Framefiles  that came with your Mpeg files
 the path to the mpeg files found in the frame files need to match the updated location.
