xvasman1 Posted September 11, 2020 Posted September 11, 2020 Hi, After decorated, i'am setting the emulators. I'm trying to install retroarch or MAME but it's the same : 1) MAME on emulator folder 2) MAME module -> MAME.ahk 3) Database -> MAME.xml 4) HyperHQ -> rom folder and retroarch.exe or mame64.exe Fusion with the megadrive was OK but not with retroarch & MAME. It doesn"thappen anything when i launch my games. Can you help me? Thx in advance !
xvasman1 Posted September 11, 2020 Author Posted September 11, 2020 Here's the logs 12:29:41 PM | HyperSpin Started 12:29:41 PM | Going FullScreen 12:29:42 PM | Checking for updates 12:29:42 PM | Update Check Complete 12:29:42 PM | Startup program unavailable 12:29:42 PM | Playing intro video 12:29:43 PM | Error intializing joysticks 12:29:43 PM | Menu Mode is multi 12:29:43 PM | Loading Main Menu.xml 12:29:43 PM | Main Menu.xml successfully loaded 12:29:44 PM | Main Menu wheel loaded successfully 12:29:48 PM | Loading MAME.xml 12:29:48 PM | Main Menu.xml successfully loaded 12:29:49 PM | MAME wheel loaded successfully 12:29:51 PM | Launching Game 12:29:51 PM | Using HyperLaunch 12:29:51 PM | Getting Launcher path 12:29:51 PM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe 12:29:51 PM | Launcher located at C:\Hyperspin\HyperLaunch.exe 12:29:51 PM | Running Launcher 12:29:51 PM | Launcher Command Line is: C:\Hyperspin\HyperLaunch.exe "MAME" "sbbros"
Spawk Posted September 11, 2020 Posted September 11, 2020 Hyperlaunch is old and crap, i would suggest using RocketLauncher. See here how to connect HS and RL:
xvasman1 Posted September 18, 2020 Author Posted September 18, 2020 Thanks for the answer ! MAME, N64, ... work great but i have a problem with the last : Atomiswave. The emulator is Demul, the launcher launches great but in hyperspin, nothing happens. Had you already this problem ?
Spawk Posted September 18, 2020 Posted September 18, 2020 I don't have it set up at the moment... but when I do finally get to it, I will probably be using the Reicast core in Retroarch.
Spawk Posted September 18, 2020 Posted September 18, 2020 Trying to use bezels? Maybe this thread helps??? http://www.rlauncher.com/showthread.php?6689-Help-with-Demul-0-7a-module-and-running-earlier-demul-for-bezels
xvasman1 Posted September 19, 2020 Author Posted September 19, 2020 I've tried to find the module line but all my modules are compatible with an old rocketlauncher (There is yet StartModule() function). Then i'll try to find an atomiswave module for rocketlauncher and for demul 0.5.6 or 0.5.7 ;(
