aic15700 Posted December 2, 2020 Posted December 2, 2020 Hello All, Hope you are doing well! I am running Hyperspin 1.3.2 but it will not launch on a Win 10 machine build (19041.630). 1. Is there a patch for this and if so, can you please point me to it? 2. If there is no patch, can you please advise how I can get Hyperspin back up and running on this and other Win 10 machines? 3. If I need to rebuild Hyperspin from scratch to the latest version, I may be interested in downloading a prebuilt build from the Hyperspin site. Can you please advise as to how I would go about that? Thank you very much in advance! Happy Gaming everyone!
aic15700 Posted December 2, 2020 Author Posted December 2, 2020 Thank you! Will this work with the current version of HyperSpin I am running (1.3.2)? Also, which directory does it go in?
aic15700 Posted December 2, 2020 Author Posted December 2, 2020 I copied the file to the same directory that HyperSpin.exe is in, but it did not work. I have tried with HyperSpin versions 1.2.0 and 1.3.2. Any other suggestions? Is there a log I can share? When I click the file, it just does nothing. I even tried via command line as an admin, it did not even throw an error, just returned me to the command prompt. Can I upgrade my Hyperspin.exe without having to update my database and other items? Thank you!
gigapig Posted December 2, 2020 Posted December 2, 2020 You probably need the latest version of Hyperspin which is 1.5.1. You just drop the dll into the root folder and run Hyperspin.
aic15700 Posted December 2, 2020 Author Posted December 2, 2020 Thanks again! Can I upgrade my Hyperspin.exe without having to update my database and other items? Basically can I just replace my Hyperspin.exe file to the latest version and it will work with my DB and everything else?
gigapig Posted December 2, 2020 Posted December 2, 2020 1 hour ago, aic15700 said: Thanks again! Can I upgrade my Hyperspin.exe without having to update my database and other items? Basically can I just replace my Hyperspin.exe file to the latest version and it will work with my DB and everything else? Yes but make sure you rename your original file to 1.3.2 so you have a backup.
aic15700 Posted December 2, 2020 Author Posted December 2, 2020 Thank you! It worked on one of my Win 10 machines. Let me try it on the others I have and I will reply back. Thanks again for the support! Much appreciated!
