Hyperspin menu Infinitely scrolling up or down on startup?
Obizues
Hey everyone,
It’s been a while since I booted up my arcade, and I went to do it to play with my daughter and after the hitting the 1p button to skip the intro it takes me to select a system.
I pushed my arcade stick down and it’s scrolls indefinitely.
I quite out by ending the process, went back in and used my keyboard and it did the same thing.
I checked my controllers settings for the arcade sticks and buttons and it is all setup properly, and I’m not sure what else to do?!
Thanks in advance!
16 hours ago, Obizues said:
Hey everyone,
Thanks in advance!
It's usually because of a connected controller issue.
Unplug controller to see if issue stops, then investigate what the issue with the controller is (if that's the problem)
Or check to see if you have joysticks ticked in HyperHQ settings.
Had the same thing happen and it ended up being something to do with the Hyperspin start up script. I had to disable joysticks to get it to stop.
