Trouble Getting Hyperspin to Launch RocketLauncher Correctly
Larsa
I'm a newbie trying to get Hyperspin to work, so thanks in advance!
Problem:
I can get RocketLaunch to work fine.  However, when I select a game in Hyperspin, I get a "Cannot find Launcher" error.
Troubleshooting:
- I go to the DOS command line in the RocketLauncher directory and type: RocketLauncher.exe MAME 1941   and it works fine.  However, if I try HyperLaunch.exe MAME 1941    or    Hyperlaunch.exe MAME 1941   it doesn't work.
- I try the following:
--- Selecting or De-selecting the HyperLaunch radio button in HyperHQ -> Wheel Settings -> MAME -> Emulator.
--- Adding or Removing the directory path to RocketLaucher in the Executable: selection of the same Emulator tab.
Note that the Command Line Preview in this tab shows: HyperLaunch.exe "MAME" "RomName"         and I don't see any way to change this to RocketLaucher.exe "MAME" "RomName"
Questions:
1. How can I change the Command Line Preview to RocketLaucher.exe "MAME" "RomName"     ?
2. Where does Hyperspin look for RocketLauncher (or HyperLaunch) if you don't put anything in the "Executable:" section?
3. Where does Hyperspin store the settings/options that are active?
4. If I deselect the HyperLaunch radio button, I can change the Command Line Preview to "C:\Games\Arcade\RocketLauncher\RocketLauncher.exe" "RomName."    But that doesn't work, either.   Note that there is a period added to the end of the Rom Name, which I can't get rid of.  Because of this, RocketLauncher gives an error that it can't find the "1941." rom.   It also doesn't specify MAME, which could also be a problem.
Thanks!
Thanks, that worked!
The Settings.ini file is hidden in with all of the other settings, making it hard to find!
