Problems with System (MAME) XML File
Larsa
I changed <enabled> from Yes to No on some games in my Mame.xml file (and removed the Roms only filter), and now Hyperspin gives me a “Mame.xml file is invalid” error.
I’ve been roughly following the instructions in the Tutorial here:
However, it looks like the info in the tutorial is dated because the format of the xml file (from hyper list.hyperspin-fe.com) is different than what’s in the tutorial.  Here’s the format from Hyperlist:
    <game name="88games" index="true" image="'">
        <description>&apos;88 Games</description>
        <cloneof></cloneof>
        <crc></crc>
        <manufacturer>Konami</manufacturer>
        <year>1988</year>
        <genre>Sports / Track &amp; Field</genre>
        <rating>AAMA - Green (Suitable For All Ages)</rating>
        <enabled>Yes</enabled>
    </game>
So, the tutorial uses enabled=“0” or “1” and the new XML file uses <enabled>Yes and (presumably) <enabled>No.
What do I need to do to set enabled correctly and filter Roms as desired?
 Thanks
Follow the tutorial, the enabled yes/no at the bottom is auto generated from clrmamepro.
HS will use the 0 or 1 enabled like this:
