WeveGotBibinho Posted October 13, 2021 Posted October 13, 2021 Hello all! I am new around here and require some help. In our office, we have just got a new HyperSpin arcade cabinet (it rocks!) and i have the honour of trying to set it up! I have come stuck with something though. We have got the program up and running and noticed that only the MAME emulator is on the wheel. "No problem" i thought, "i can go into HyperHQ and change it to the multi wheel". No matter how many times i change the settings in HyperHQ and close it, they do not get applied and go back to the default setting. I have done quite a bit of research and come stuck at every corner! Has anyone else had this problem and how did you solve it if you did? Thank you!
WeveGotBibinho Posted October 19, 2021 Author Posted October 19, 2021 Anyone have any idea on how to fix this, please?
Spawk Posted October 19, 2021 Posted October 19, 2021 What wheels did you add? What emulator are you trying to add? What romset did you get? Everything has to be setup manually.
WeveGotBibinho Posted October 21, 2021 Author Posted October 21, 2021 So all the wheels were automatically set up for us (what we bought came as a package) so all the emulators and roms were provided. When i click the drop down all the emulators are there for us. I thought just clicking multi would add all of the emualtors from the drop down into various wheels, no? As the single option is selected, it is just using the MAME emulator. Whenever i select the Multi option and click the x to close the window, whatever option i choose from any of the tabbed settings doesn't save.
KRIS85 Posted October 31, 2021 Posted October 31, 2021 Hello, I have a similar problem,He builds everything himself so can you tell me how to get HQ to run the same wheel every time (in your case Mame) At the beginning, when I was configuring the HS, everything was ok, I set up, for example: Arcade and Hs started with the Arcade wheel, but after adding a few wheels, it now opens on a different one each time but the same wheel, e.g. collection (I don't use nested wheels etc) Even if I uncheck the last system to enter and enter Hq, the bird is selected but ini is false I tried nowit and nothing + and so it opens on the last wheel so; ( My irritation is slowly reaching the Cosmos: P
