How to add Systems for RetroArch(MAME)
floatingyeti
Recently I've been uploading complete setups for RetroArch(Mame).   Hopefully this is a useful guide explaining how to use the uploads:
1. Add the System to HyperHQ. Everyone should know this step so I wont go into detail.
⦁    Exentions will always be zip or 7z. I always put: 7z,7Z,zip,ZIP
2. In RetroArch make sure you have added this core: Arcade - (Mame-Current)
3. Update Rocket Launcher RetroArch Module
⦁    Edit RetroArch.ahk
⦁    Find the line beginning with: MSystem :=
⦁    Add the system name in quotes "Atari XEGS" don't forget the comma separating names. The order does not matter.
⦁    Find line beginning with: mTypeVar:=
⦁    Add line for: System Name|Core|Mame hash/system name
⦁    In this case: Atari XEGS|mame_libretro|xegs
⦁    If the module already has the system listed with |LibRetro_System| or in this case |LibRetro_XEGS| delete that part. It may cause problems with mame_libretro core.
4. Make sure there are no spaces in the directory path to roms folder
⦁    Good Example: C:\HyperSpin\Roms\Atari_XEGS\xegs
⦁    Bad Example: C:\HyperSpin\Roms\Atari XEGS\xegs
5. Setting up Rocket Launcher. Everyone should know this step so I wont go into detail.
⦁    Set 7z Enabled to "false"
⦁    Don't forget: Edit Global Module Setting and select mame_libretro core
6. RetroArch Mame core settings:
    Turn on: Profile buttons according to game
                  Alternate render method (must be on for Bezels to work)
                  Enable software lists
                  Software list automatic media type
                  Boot from CLI
                  Resolution: 1920x1080 (as of version 0.247 use 1280x720p)
7. To access Mame menu hit Scroll Lock then Tab
I'm currently working on an FM Towns Marty setup using the MAME Software List fmtowns_cd chds. I'm having to do a lot of additions to the Hash file but I'm able to get User/Utility/Boot disks to load when needed.
I just finished testing games from #-B and identified 57 working games so far.
My hope is to create a preconfigured folder that can be merged with SL fmtowns_cd CHD using my modified hash and with complete wheels/video(png).
It's going to take some time.
  • 3 weeks later...
