Visual Pinball x Module
jcm9800
Hallo Guys i want to ask if anyone had made a Visual Pinball x module for Launch with Rockrtlauncher i have one that works but some Tables are
not in the frontend and must be take in Front with Alt Tab.
[sIGPIC][/sIGPIC]
Maybe post the module and someone may be able to take a look.
thats the Module that i have
MEmu := "Visual Pinball"
MEmuV := "v8.1.1 & v9.12"
MURL := ["http://sourceforge.net/projects/vpinball/"]
MAuthor := ["djvj"]
MVersion := "2.0.1"
MCRC := "86821212"
iCRC := "5089D1EC"
MID := "635038268932497719"
MSystem := ["Visual Pinball"]
; Notes:
; Requires VPinMame v2.4
; If you want to use a picture while the table is loading, place it on the dir with this module and define the width & height and its filename in the variables below.
; You can also set the color of the background
; If you use Esc as your exit_emulator_key, set EscClose to true. The emu closes faster if you don't use Esc, and this value doesn't seem to matter if you use Win7
; VPinMame uses the registry to store configs @ HKEY_CURRENT_USER\Software\Freeware\Visual PinMame
; Each time a new table is ran, it pulls the default configs into a new folder in the registry
; Visual Pinball stores settings in the registry @ HKEY_USERS\S-1-5-21-440413192-1003725550-97281542-1001\Software\Visual Pinball
StartModule()
FadeInStart()
EscClose := IniReadCheck(settingsFile, "Settings", "EscClose","false",,1) ; This fixes VP from crashing (in WinXP) on exit when using Esc as your exit key.
showDMD := IniReadCheck(settingsFile, "Settings", "ShowDMD","true",,1)
updateDefaultDMD := IniReadCheck(settingsFile, "Settings", "UpdateDefaultDMD","true",,1) ; Set this to true if you want the script to set the default position of the DMD on next run.
dmdX := IniReadCheck(settingsFile, "Settings", "DMDX","45",,1) ; Your new default X position of the DMD
dmdY := IniReadCheck(settingsFile, "Settings", "DMDY","35",,1) ; Your new default Y position of the DMD
dmdWidth := IniReadCheck(settingsFile, "Settings", "DMDWidth","300",,1) ; Your new default DMD Width
dmdHeight := IniReadCheck(settingsFile, "Settings", "DMDHeight","75",,1) ; Your new default DMD Height
validateDMDLaunch := IniReadCheck(settingsFile, "Settings|" . romName, "ValidateDMDLaunch", "false",,1)
; Update default DMD position & size so when new tables are ran, they use the new defaults
If ( updateDefaultDMD  = "true" ) {
    dmdXcur := ReadReg("dmd_pos_x")
    dmdYcur := ReadReg("dmd_pos_y")
    dmdWcur := ReadReg("dmd_width")
    dmdHcur := ReadReg("dmd_height")
    If ( dmdXcur != dmdX or dmdYcur != dmdY or dmdWcur != dmdWidth or dmdHcur != dmdHeight ) {
        WriteReg("dmd_pos_x",dmdX)
        WriteReg("dmd_pos_y",dmdY)
        WriteReg("dmd_width",dmdWidth)
        WriteReg("dmd_height",dmdHeight)
Run(executable . " /exit /play -""" . romPath . "\" . romName . romExtension . """",emuPath, "Min") ; hide does not work
WinWait("Preparing Table AHK_class #32770")
WinWaitClose("Preparing Table AHK_class #32770",,4)
Sleep, 500
; script to look for Please answer window, selects Yes I am and hits enter to continue loading table
Loop {
    Sleep 50
    IfWinExist, Please ; Nag screen the first time a table is ran
    {    WinActivate, Please
        IfWinActive, Please
        {    SetControlDelay -1
            ControlClick, Button2, Please answer AHK_class #32770 ; Click Yes I am
            ControlSend, Button1, {Enter}, Please answer AHK_class #32770 ; Click the OK button
    } Else ifWinExist, Game Info ; unknown window
    {    WinActivate, Game Info
        IfWinActive, Game Info
        {    Send {Enter}
            Send {Enter}
    } Else ifWinExist, Notice ; sound not 100% acurate
    {    WinActivate, Notice
        IfWinActive, Notice
        {    Send {Enter}
            Send {Enter}
    } Else ifWinExist, VBScript ; all msg boxes from vp script (like vb/vpm version not high enough...)
    {    WinActivate, VBScript
        IfWinActive, VBScript
        Send {Enter}
    } ;Else IfWinExist, Error ; serious errors - like z buffer too small and so on
        ; we have some error and we want to see it so we don't send Enter
        ; Send {Enter}
        ; Gui, Destroy
        ; WinActivate, Error
        ; WinWaitActive, Error
        ; WinWaitClose, Error
        ; WinClose, ahk_class VPinball
        ; Process, WaitClose, %executable%
        ; ExitModule()
    IfWinExist, Visual Pinball Player,, DMD ;Check if visual pinball is Ready
        IfWinActive, Visual Pinball Player,, DMD ;Check if visual pinball is Ready
            Break
Sleep, 500
WinWait("ahk_Class VPPlayer")
Sleep, 500
Loop {
    IfWinActive, ahk_class VPPlayer
        Break
    WinActivate, ahk_class VPPlayer
    Sleep, 50
WinWaitActive("ahk_class VPPlayer")
Sleep, 1000
; Give focus to the dmd so it appears on top of the playfield
If showDMD = true
{    DetectHiddenWindows, off ; don't detect dmd if it is hidden
    WinActivate, ahk_class MAME
    If validateDMDLaunch = true
        WinWaitActive("ahk_class MAME",,2)
    ControlClick,, ahk_class MAME ; clicking the dmd to set the WS_EX_TOPMOST parameter (AlwaysOnTop)
    DetectHiddenWindows on
FadeInExit()
Process("WaitClose",executable)
7zCleanUp()
FadeOutExit()
ExitModule()
ReadReg(var1) {
    RegRead, regValue, HKEY_CURRENT_USER, Software\Freeware\Visual PinMame\default, %var1%
    Return %regValue%
WriteReg(var1, var2) {
    RegWrite, REG_DWORD, HKEY_CURRENT_USER, Software\Freeware\Visual PinMame\default, %var1%, %var2%
CloseProcess:
    FadeOutStart()
    If escClose = true
    {    DetectHiddenWindows, On ;Or next line will not work
        Sleep, 50
        ;ControlSend, Button1, q, ahk_class #32770
        ControlSend, Button2, r, ahk_class #32770 ; in case q crashes VP, use this
    ; If ( exe = vp8tag ) {
    ; } Else {
        Sleep, 150
        WinHide, ahk_class VPinball ;This line fixes where the VP Window flashes real quick when closing the window for a cleaner exit
        WinMinimize, ahk_class VPinball
        WinClose("ahk_class VPinball")
Return
[sIGPIC][/sIGPIC]
