nitsuga256 Posted August 30, 2022 Posted August 30, 2022 Hello, do you know if directly from hyperspin it is possible that there will be an emulator selection submenu before launching a game? and not having to be previously configuring with which emulator you have to run a certain game that does not work witch the default one. Buenas, ¿sabéis si directamente en la ruleta de hyperspin es posible que habrá un submenu de selección de emuladores antes de lanzar un juego?, y no tener que estar configurando previamente con que emulador hay que ejecutar un determinado juego que con el que esta por defecto no funciona.
floatingyeti Posted September 1, 2022 Posted September 1, 2022 That's more of a Rocklauncher question. You can set what emulator you want used on a per-game basis using the alternate emulator settings. I don't think you can change emulators before launching a game from the hyperspin menu.
nitsuga256 Posted September 4, 2022 Author Posted September 4, 2022 Thanks, we will have to program a script that allows it
