peterj116 Posted October 30, 2022 Posted October 30, 2022 I'm not a fan of the Special Art & want to remove them all. Going into HyperHQ, selecting each individual wheel & unticking Special Art A B @ C for each wheel is tedious. Is there a batch file to do this?
floatingyeti Posted October 31, 2022 Posted October 31, 2022 The ini files for each system are in the hyperspin\settings folder You are just changing text in each ini file. Make a backup of your entire settings folder first! Use Notepad++ and you could change the default special art settings in all the files at once Open one of the ini files in Notepad++ Press Ctrl+F Use the Find in Files feature. Find what: (the original settings line) Replace with: (adjusted settings line) - copy from system ini you already altered. Select Replace in Files The HyperSpin\Settings should already be selected
Andyman Posted October 31, 2022 Posted October 31, 2022 On 10/31/2022 at 1:26 AM, floatingyeti said: ...Find what: ... Replace with... Expand This is exactly what I do for the Special Art, and to also ensure the game title and release information is formatted the same way in every wheel. Set one wheel up to your liking, then copy-paste for the rest. Works perfectly, and only takes a minute or two for the whole setup.
