Hoppy72450 Posted July 8, 2014 Posted July 8, 2014 So I just started using the new Hyperspin and all. I setup HyperLaunchHQ emulators and the roms etc. But now when I go to Hyperspin and try to enter on the wheel it doesn't work. It acts like it's going to then it just resets the wheel and stay in the same spot. Any help on this to what I may be doing wrong ?
rfancella Posted July 8, 2014 Posted July 8, 2014 So I just started using the new Hyperspin and all. I setup HyperLaunchHQ emulators and the roms etc. But now when I go to Hyperspin and try to enter on the wheel it doesn't work. It acts like it's going to then it just resets the wheel and stay in the same spot. Any help on this to what I may be doing wrong ? A little more information would be in order. There are a couple reasons why this could happen. Post your HyperSpin and HyperLaunch logs along with version numbers. See this post on how to do it: http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Hoppy72450 Posted July 9, 2014 Author Posted July 9, 2014 No clue where to find those and that's too much info bunched together. I am dyslexic and I have a hard time reading stuff when its bunched together. I had to watch a video just to learn how to compile the Hyperspin. Sorry, thanks anyways.
relic Posted July 9, 2014 Posted July 9, 2014 i had this problem too at first i thought it was the theme but it turns out i had corrupted or broken objects once i got rid of them that issue was over for me with mame 100%
Hoppy72450 Posted July 9, 2014 Author Posted July 9, 2014 09:21:00 PM | HyperSpin Started 09:21:00 PM | Going windowed mode 09:21:00 PM | Checking for updates 09:21:00 PM | Update Check Complete 09:21:00 PM | Startup program unavailable 09:21:00 PM | Playing intro video 09:21:02 PM | Error intializing joysticks 09:21:02 PM | Menu Mode is multi 09:21:02 PM | Loading Main Menu.xml 09:21:02 PM | Main Menu.xml successfully loaded 09:21:03 PM | Main Menu wheel loaded successfully 09:21:05 PM | Loading Nintendo Entertainment System.xml 09:21:05 PM | roms_only is true, checking files 09:21:05 PM | Loading Main Menu.xml 09:21:05 PM | No Games found in current filter 09:21:05 PM | Main Menu.xml successfully loaded 09:21:06 PM | Main Menu wheel loaded successfully 09:21:08 PM | Exit program unavailable 09:21:08 PM | Quiting Hyperspin 09:21:08 PM | Bye! This is my Hyperspin Logs.. Hyperspin is where I am having the problem. HyperlaunchHQ works fine.
volumetric Posted July 9, 2014 Posted July 9, 2014 Sounds like you dont have any speakers plugged in (no pun intended), either that or you've got a filter switched on in HyperHQ eg themes only/wheels only, and you have no themes or wheel images.
Hoppy72450 Posted July 9, 2014 Author Posted July 9, 2014 Sounds like you dont have any speakers plugged in (no pun intended), either that or you've got a filter switched on in HyperHQ eg themes only/wheels only, and you have no themes or wheel images. WOW, you was right. It was cuz I had Parent Only, Roms Only, checked in HyperHQ Wheel Settings.. Thanks! Works after I unchecked them.
