Hyperspin Front End Arcade Controls
CJLDN
Hi all,
Wanted to control Hyperspin fron end with the Joystick / buttons.
I have the Xin - Mo 2 player usb controller set up with the joystick 7 button (mame / neogeo setup) with independant start and select (coin in) buttons and r3 set as an exit button.
I have tested both inputs in windows (device manager) and it recognises ALL directions and button presses.
I enable the Joystick
I launch HyperHQ - select controls / joystick and enable the joysticks
click set and follow the simple input process (HyperHQ recognises the inputs).
Then exit HyperHQ.
I launch Hyperspin and the controls do absolutly nothing.
Could someone please assist on this matter.
Kind regards
CJLDN
It is well documented here that you cannot use the joystick/spinner/trackball options to control Hyperspin, it will behave very irregular.
Your options are to use the latest versions of xpadder/joy2key.
Appreciate the xpadder and joytokey comment. Have tried thos but it only recognises directional and not button inputs.
o/
