C_Wilson009 Posted July 23, 2014 Posted July 23, 2014 Hey guys, Im trying to get an old sega cd/32x game called Fahrenheit working on my arcade, through Hyperspin. When you boot up the game it asks you to insert disc 2 and press start. How do I do that through Hyperspin?
damageinc86 Posted July 24, 2014 Posted July 24, 2014 I've always wondered about disc switching too. I haven't ever really played many disc switching games, but i am sure someday I will want to.
SIMPLYAUSTIN Posted July 24, 2014 Posted July 24, 2014 Is it not one of the normal ones which asks you to save. Then all you do is boot up disk 2 and load from the save? Simply Austin's YouTube
C_Wilson009 Posted July 24, 2014 Author Posted July 24, 2014 Is it not one of the normal ones which asks you to save. Then all you do is boot up disk 2 and load from the save? nope, unless im doing something wrong. It says please press start and insert disc 2. Then I press start and it just reboots to the same screen.
laframbo Posted February 21, 2016 Posted February 21, 2016 nope, unless im doing something wrong. It says please press start and insert disc 2. Then I press start and it just reboots to the same screen.
laframbo Posted February 22, 2016 Posted February 22, 2016 I GOT IT WORKING I WILL DO THE BEST I CAN TO EXPLAIN FIRST U NEED TO DOWNLOAD THE KEGA FUSION EMULATOR 3.64 NEXT MAKE 2 NEW FOLDERS IN UR C:\hyperspin\Emulators\ DIRECTORY AND PUT A KEGA FUSION EMULATOR IN EACH FOLDER. I NAMED MY FOLDERS "KEGA FUSION FOR SEGA CD" AND THE OTHER "KEGA FUSION FOR SEGA CD-32X" INSIDE "KEGA FUSION FOR SEGA CD" MAKE 4 MORE NEW FOLDERS AND CALL THEM BRM FILES, PATCHES, SAVES, SCREENSHOTS, DO THE SAME FOR "KEGA FUSION FOR SEGA CD-32X" DOWNLOAD THE SEGACD/32X BIOS NEXT...CONFIGURE EACH EMULATOR. "KEGA FUSION FOR SEGA CD" { 1.CLICK OPTIONS...PUT A CHECK MARK BY PERFECT SYNC... THEN CLICK SET CONFIG... 2.CLICK SEGA CD TAB... SET THE PATH TO UR BIOS FOR EACH REGION USA BIOS ="SET PATH"---> us_scd1_9210.bin... (U MUST USE THIS BIOS FOR USA TO MAKE CHANGE DISK WORK PROPERLY IN KEGA FUSION. NOT SURE WHAT BIOS WORKS BEST FOR JAP OR EUR) JAP BIOS= "SET PATH"--->MegaCD Model 1 BIOS V1.00 (J) (Dec 1991) [!].bin EUR BIOS ="SET PATH"---> MegaCD Model 2 BIOS V2.21 (E) (Sep 1993).bin BRM FILES =C:\hyperspin\emulators\kega fusion for sega cd\brm files (POINT THIS TO UR BRM FILES FOLDER U MADE EARLIER) STATE FILES =C:\hyperspin\emulators\kega fusion for sega cd\state files (POINT THIS TO UR STATE FILES FOLDER U MADE EARLIER) READ AHEAD = 8X BUILT-IN RAM = PER BIOS CD+G = OFF (OPTIONAL)SET THE PATHS TO THE OTHER SYSTEMS IF YOU LIKE... NEXT.... 3.CLICK 32X TAB... M68K BIOS="SET PATH"--->32X_G_BIOS.BIN MASTER BIOS="SET PATH"--->32X_M_BIOS.BIN SLAVE BIOS="SET PATH"--->32X_S_BIOS.BIN NOW BELOW ARE 2 BOXES FAST 32X TIMING DISABLE 32X CHECK THE DISABLE 32X BOX (THIS IS THE EMULATOR THAT PLAYS THE SEGA CD VERSION OF FAHRENHEIT) NEXT..... 4.CLICK CONTROLLERS TAB PORT1 CLICK DEFINE (TO SET UP CONTROLLER) } NEXT...CONFIGURE THE OTHER EMULATOR "KEGA FUSION FOR SEGA CD-32X" { DO THE SAME THING FOR THIS EMULATOR. EXCEPT 1.CLICK 32X TAB (SET BIOS PATHS LIKE U DID WITH "KEGA FUSION FOR SEGA CD" ) M68K BIOS="SET PATH"--->32X_G_BIOS.BIN MASTER BIOS="SET PATH"--->32X_M_BIOS.BIN SLAVE BIOS="SET PATH"--->32X_S_BIOS.BIN NOW BELOW ARE 2 BOXES FAST 32X TIMING DISABLE 32X "MAKE SURE DISABLE 32X "IS NOT CHECKED ! !"(THIS IS THE EMULATOR THAT PLAYS THE FAHRENHEIT SEGACD-32X VERSION) } -------------------------------------------------------------------------------------------- EMULATOR SET UP DONE! DAMN THAT WAS ALOT OF TEXT! OK MOVING ON TO SETTING UP UR SEGA CD.xml AND UR SEGA 32X.xml GO TO UR C:\HYPERSPIN\DATABASE (FIND AND CLICK SEGA CD.xml) 1. SEGA CD.xml ( PUT THIS IN ALPHABETICAL ORDER IN YOUR SEGA CD.xml... MAKE SURE YOU USE THE NAME OF YOUR FAHRENHEIT GAME ROM WHERE "game name ="Fahrenheit (USA) (Disk 1)" IS AT ) <game name ="Fahrenheit (USA) (Disk 1)" index="" image=""> <description>Fahrenheit (USA) (Disk 1)</description> <cloneof></cloneof> <crc></crc> <manufacturer>Sega</manufacturer> <year>1995</year> <genre>Adventure</genre> <rating>ESRB - T (Teen)</rating> <enabled>Yes</enabled> </game> ("THIS IS WHAT MY SEGA CD.xml LOOKS LIKE AFTER I INSERT THE ENTRY INTO MY SEGA CD.xml") <game name="Eternal Champions - Challenge from the Dark Side (USA)" index="" image=""> <description>Eternal Champions - Challenge from the Dark Side (USA)</description> <cloneof></cloneof> <crc></crc> <manufacturer>Sega</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>ESRB - M (Mature)</rating> <enabled>Yes</enabled> </game> <game name ="Fahrenheit (USA) (Disk 1)" index="" image=""> <description>Fahrenheit (USA) (Disk 1)</description> <cloneof></cloneof> <crc></crc> <manufacturer>Sega</manufacturer> <year>1995</year> <genre>Adventure</genre> <rating>ESRB - T (Teen)</rating> <enabled>Yes</enabled> </game> <game name="Fatal Fury Special (USA)" index="" image=""> <description>Fatal Fury Special (USA)</description> <cloneof></cloneof> <crc></crc> <manufacturer>JVC Digital Studios</manufacturer> <year>1995</year> <genre>Fighter</genre> <rating>ESRB - T (Teen)</rating> <enabled>Yes</enabled> </game> NOW... DELETE ANY OTHER FAHRENHEIT ENTRIES (THIS IS SO ONLY 1 FAHRENHEIT GAME SHOWS UP ON UR WHEEL ...THE SEGA CD VERSION... AND NOT THE 32X VERSION) NOW OPEN UP C:\RocketLauncher\RocketLauncherUI\database\Sega cd COPY AND PASTE UR SEGA CD.xml TO THIS DIRECTORY OK SEGA CD.xml IS SETUP NOW FOR THE SEGA 32X.xml SETUP ------------------------------------------------------------------------------------------------------------ GO TO UR C:\HYPERSPIN\DATABASE (FIND AND CLICK SEGA 32X.xml) 2.SEGA 32X.xml ( PUT THIS IN ALPHABETICAL ORDER IN YOUR SEGA 32X.xml... MAKE SURE YOU USE THE NAME OF YOUR FAHRENHEIT GAME ROM WHERE game name ="Fahrenheit (USA) (32x) (Disk 2)" IS AT ) <game name ="Fahrenheit (USA) (32x) (Disk 2)" index="" image=""> <description>Fahrenheit (USA) (32x) (Disk 2)</description> <cloneof></cloneof> <crc></crc> <manufacturer>Sega</manufacturer> <year>1995</year> <genre>Adventure</genre> <rating>ESRB - T (Teen)</rating> <enabled>Yes</enabled> </game> ("THIS IS WHAT MY SEGA 32X.xml LOOKS LIKE AFTER I INSERT THE ENTRY INTO MY SEGA 32X.xml") <game name="Doom (Japan, USA)" index="" image=""> <description>Doom (Japan, USA)</description> <cloneof></cloneof> <crc>208332FD</crc> <manufacturer>Sega</manufacturer> <year>1994</year> <genre>Shooter</genre> <rating>ESRB - M (Mature)</rating> <enabled>Yes</enabled> </game> <game name ="Fahrenheit (USA) (32X) (Disk 2)" index="" image=""> <description>Fahrenheit (USA) (32X) (Disk 2)</description> <cloneof></cloneof> <crc></crc> <manufacturer>Sega</manufacturer> <year>1995</year> <genre>Adventure</genre> <rating>ESRB - T (Teen)</rating> <enabled>Yes</enabled> </game> <game name="FIFA Soccer '96 (Europe)" index="true" image="f"> <description>FIFA Soccer '96 (Europe)</description> <cloneof></cloneof> <crc>FB14A7C8</crc> <manufacturer>Electronic Arts</manufacturer> <year>1995</year> <genre>Soccer/Sports</genre> <rating>ESRB - E (Everyone)</rating> <enabled>Yes</enabled> </game> NOW... DELETE ANY OTHER FAHRENHEIT ENTRIES (THIS IS SO ONLY 1 FAHRENHEIT GAME SHOWS UP ON UR WHEEL ...THE SEGA 32X VERSION... AND NOT THE SEGA CD VERSION) NOW OPEN UP C:\RocketLauncher\RocketLauncherUI\database\Sega 32x COPY AND PASTE UR SEGA 32X.xml TO THIS DIRECTORY OK SEGA 32X.xml IS SETUP ------------------------------------------------------------------------------------------------------- OK DAMN.... I DID ALOT TO MAKE THIS HAPPEN DAWG!! ITS WORTH THE READ WISH I HAD THIS TO LOOK AT... IT TOOK ME FOREVER TO FIGURE THIS ALL OUT HAHA OK QUICK RECAP SO FAR WE... 1.SETUP 2 EMULATORS "KEGA FUSION FOR SEGA CD" "KEGA FUSION FOR SEGA CD-32X" 2.SETUP OUR SEGA CD.xml AND SEGA 32X.xml LIST TO INCLUDE OUR FAHRENHEIT GAMES TO OUR WHEELS NOW WE WILL SETUP OUR ROCKET LAUNCHER UI (WE WANT OUR SEGA CD SYSTEM TO HAVE 2 EMULATORS ONE FOR SEGA CD GAMES AND THE OTHER FOR SEGA CD-32X GAMES) (WE WANT OUR SEGA 32X SYSTEM TO HAVE 1 EMULATOR JUST FOR SEGA CD-32X AND REGULAR 32X GAMES) SO LETS START WITH THE GLOBAL SETTING 1.CLICK ON THE "GLOBAL" SYSTEM ON THE LEFT AND THEN SELECT EMULATORS ON THE RIGHT 2.SCROLL DOWN AND FIND "FUSION" DOUBLE CLICK TO OPEN ENTER THE FOLLOWING: NAME = Fusion PATH = PATH------->"KEGA FUSION FOR SEGA CD" EMULATOR ROM EXTENSIONS = 7z|zip|sg|sc|gg|sms|gen|32x|md|cue|bin|iso MODULE = FUSION.AHK 3.CLICK THE + FOR ADD NEW EMULATOR ENTER THE FOLLOWING: NAME = FusionCD32X PATH = PATH------>"KEGA FUSION FOR SEGA CD-32X" EMULATOR ROM EXTENSIONS = iso|bin|cue|zip|32X MODULE = FUSION.AHK CLICK THE SAVE DISK IN THE UPPER LEFT TO SAVE 4.CLICK "SEGA 32X" SYSTEM ON THE LEFT AND THEN SELECT EMULATORS ON THE RIGHT 5.SET THE ROM PATH TO UR 32X ROMS SET DEFAULT EMULATOR TO FUSION 6. CLICK + FOR ADD NEW EMULATOR ENTER THE FOLLOWING NAME = Fusion PATH = PATH -------> "KEGA FUSION FOR SEGA CD-32X" EMULATOR ROM EXTENSIONS = 32X|zip|iso|bin|cue MODULE = FUSION.AHK CLICK THE SAVE DISK IN THE UPPER LEFT TO SAVE 7.CLICK "SEGA CD" SYSTEM ON THE LEFT THEN SELECT EMULATORS ON THE RIGHT 8.SET THE ROM PATH TO UR SEGA CD ROMS SET DEFAULT EMULATOR TO FUSION 9. CLICK + FOR ADD NEW EMULATOR ENTER THE FOLLOWING NAME = Fusion PATH = PATH -------> "KEGA FUSION FOR SEGA CD" EMULATOR ROM EXTENSIONS = iso|bin|cue|32X|zip MODULE = FUSION.AHK CLICK THE SAVE DISK IN THE UPPER LEFT TO SAVE 10.CLICK + AGAIN TO ADD ANOTHER EMULATOR ENTER THE FOLLOWING NAME = FusionCD32X PATH = PATH -------> "KEGA FUSION FOR SEGA CD-32X" EMULATOR ROM EXTENSIONS = iso|bin|cue|32X|zip MODULE = FUSION.AHK CLICK THE SAVE DISK IN THE UPPER LEFT TO SAVE 11.CLICK "SEGA GENESIS" SYSTEM ON THE LEFT THEN SELECT EMULATORS ON THE RIGHT 12.SET THE ROM PATH TO UR SEGA GENESIS ROMS SET DEFAULT EMULATOR TO FUSION. 13. CLICK + FOR ADD NEW EMULATOR ENTER THE FOLLOWING NAME = Fusion PATH = PATH -------> "KEGA FUSION FOR SEGA CD-32X" EMULATOR ROM EXTENSIONS = md|zip MODULE = FUSION.AHK CLICK THE SAVE DISK IN THE UPPER LEFT TO SAVE 14.CLICK ON SEGA CD SYSTEM ON THE LEFT AND SETTINGS ON THE RIGHT 15. CLICK MULTI GAME..UNDER GENERAL OPTIONS SET ENABLE TO TRUE 16.CLICK ON SEGA 32X SYSTEM ON THE LEFT AND SETTINGS ON THE RIGHT 17.CLICK MULTI GAME..UNDER GENERAL OPTIONS SET ENABLE TO TRUE ------------------------------------------------------------------------- OK...ROCKET LAUNCHER UI IS SET UP FOR OUR EMULATORS. THERE IS ONE MORE THING WE HAVE TO DO... WE NEED TO TELL HYPERSPIN WHERE TO FIND THE SEGA CD-32X ROMS WHEN U PICK THE 32X SYSTEM FROM UR WHEEL. TO DO THAT WE WILL GO TO THE DIRECTORY C:\RocketLauncher\Settings\Sega 32X OPEN THE FILE NAMED Games.ini (ENTER IN THE FAHRENHEIT GAMES LIKE U SEE BELOW) -------------------------------------------------------------------------- # This file is only used for remapping specific games to other Emulators and/or Systems. # If you don't want your game to use the Default_Emulator, you would set the Emulator key here. # This file can also be used when you have Wheels with games from other Systems. # You would then use the System key to tell RocketLauncher what System to find the emulator settings. [Fahrenheit (USA) (Disk 1)] System=Sega CD emulator=FusionCD32X [Fahrenheit (USA) (32X) (Disk 2)] System=Sega CD emulator=FusionCD32X ------------------------------------------------------------------------------------------- (MAKE SURE YOUR ROM NAMES MATCH THE NAMES IN UR ROM FOLDER AND MAKE SURE THE SYSTEM NAMES MATCH THE NAMES OF THE SYSTEMS IN UR C:\HYPERSPIN\DATABASE FOLDER) OK THATS IT EVERYTHING IS DONE AND READY TO GO.. EXCEPT ONE MORE MINOR HEAD SPLITTING PAIN IN DA ASSS DETAIL. SO FAR WE HAVE ALL THE EMULATORS SET UP AND ROMS POINTING TO THE RIGHT SYSTEMS. NOW FOR THE TRICKY PART!!.... (THE INFAMOUS DISK 1 AND DISK 2 SWAP) ------------------------------------------------------------------ OK HERE GOES.... 1.START UP YOUR "KEGA FUSION SEGA CD-32X" EMULATOR 2.CLICK FILE..THEN LOAD SEGA CD IMAGE 3.CLICK THE BOX NEXT TO "FILE NAME:" TO SWITCH SO WE CAN SEE THE SEGA CD BIN/ISO FILES AND NOT THE CUE/ISO FILES 4.SELECT THE Fahrenheit (USA) (Disk 1).BIN FILE... LET IT LOAD TILL IT TELLS YOU TO "PLEASE PRESS START AND INSERT DISK 2" 5.PRESS START 6.NOW U WILL SEE A FLASHING TRAY IN THE LOWER LEFT CORNER (U MUST BE USING BIOS VERSION us_scd1_9210.bin TO SEE THIS FLASHING TRAY) 7.NOW CLICK FILE..THEN LOAD SEGA CD IMAGE 8.CLICK THE BOX NEXT TO "FILE NAME:" TO SWITCH SO WE CAN SEE THE SEGA CD BIN/ISO FILES AND NOT THE CUE/ISO FILES 4.SELECT THE Fahrenheit (USA) (32X) (Disk 2).BIN FILE... (IMPORTANT ! ! ! SOON AS YOU PRESS ENTER..GET READY TO PRESS F5 TO SAVE THE STATE OF THE GAME..AND MAKE SURE YOU ARE ON SAVE SLOT 0. YOU CAN PICK YOUR SAVE STATE SLOT BY PRESSING F6 OR F7....F8 LOADS THE SAVED STATE. MAKE SURE U SAVE THE GAME ON SAVE SLOT 0) PRESS ENTER. THE GAME WILL LOAD FAHRENHEIT 32X VERSION NOW... -------------------------------------------------------------------------- NOW THAT WE HAVE THE SECOND DISK SAVED TO SLOT 0... ALL WE HAVE TO DO NOW IS PRESS F8 WHEN THE GAME STARTS FROM OUR 32X MENU BUT THERE IS ONE FINAL STEP THAT TOOK ME FOREVER TO SOLVE ALOT OF DROOL, SWEAT N TEARS BUT I GOT IT FIGURED OUT IF YOU DO THIS LAST STEP YOU WONT HAVE TO PRESS F8 EVERY TIME U START THE 32X VERSION OF FAHRENHEIT FINAL STEP !! !! !! !! --------------------------------------------------------------------------------------------- OK WHAT WE WANNA DO IS DOWNLOAD A POPULAR PROGRAM CALLED AUTOHOTKEY. YOU CAN GET IT AT https://autohotkey.com/ AFTER YOU DOWNLOAD IT AND INSTALL THE PROGRAM YOU CAN RIGHT CLICK ON THE DESKTOP SCREEN.. GOTO NEW THEN AUTOHOTKEY SCRIPT. THIS WILL CREATE A "NEW AUTOHOTKEY SCRIPT.AHK" ON UR DESKTOP RIGHT CLICK ON THAT THEN CHOOSE EDIT SCRIPT. YOU WILL SEE THE FOLLOWING FILE... ------------------------------------------------------------------ #NoEnv ; Recommended for performance and compatibility with future AutoHotkey releases. ; #Warn ; Enable warnings to assist with detecting common errors. SendMode Input ; Recommended for new scripts due to its superior speed and reliability. SetWorkingDir %A_ScriptDir% ; Ensures a consistent starting directory. ------------------------------------------------------------------------ ENTER THE FOLLOWING TEXT LIKE SO... ---------------------------------------------------------------------------------- #NoEnv ; Recommended for performance and compatibility with future AutoHotkey releases. ; #Warn ; Enable warnings to assist with detecting common errors. SendMode Input ; Recommended for new scripts due to its superior speed and reliability. SetWorkingDir %A_ScriptDir% ; Ensures a consistent starting directory. DetectHiddenWindows, On DetectHiddenText, On sleep 10000 Controlsend,,{F8},Fusion 3.64 - SegaCD - FAHRENHEIT -------------------------------------------------------------------------------------- CLICK FILE ..THEN SAVE AS.. AND RENAME THIS FILE TO ....Fahrenheit32XLoadStateScript.ahk NOW WERE GONNA MAKE ONE MORE AUTOHOTKEY SCRIPT FILE RIGHT CLICK ON UR DESKTOP AND GOTO NEW THEN AUTOHOTKEY SCRIPT RIGHT CLICK THAT "NEW AUTOHOTKEY SCRIPT.ahk" FILE AND GO UP TO EDIT SCRIPT ENTER THE FOLLOWING TEXT LIKE SO... ---------------------------------------------------------------------- #NoEnv ; Recommended for performance and compatibility with future AutoHotkey releases. ; #Warn ; Enable warnings to assist with detecting common errors. SendMode Input ; Recommended for new scripts due to its superior speed and reliability. SetWorkingDir %A_ScriptDir% ; Ensures a consistent starting directory. #Persistent ;Script will not Exit when no hotkeys exist. DetectHiddenWindows, On DetectHiddenText, On SetTimer, CheckPrograms, 1000 ;Run CheckPrograms subroutine every 1 second return CheckPrograms: IfWinExist, Fusion 3.64 - SegaCD - FAHRENHEIT { If NotepadTrack = 1 return Run, D:\hyperspin\Scripts\Fahrenheit32XLoadStateScript.ahk NotepadTrack = 1 } IfWinNotExist, Fusion 3.64 - SegaCD - FAHRENHEIT NotepadTrack = 0 return ------------------------------------------------------------------------ CLICK FILE ..THEN SAVE AS.. AND RENAME THIS FILE TO ....Fahrenheit32XStartup.ahk OK NOW WE SHOULD HAVE 2 SCRIPT FILES 1.Fahrenheit32XLoadStateScript.ahk 2.Fahrenheit32XStartup.ahk NOW..MOVE THESE 2 FILES TO YOUR C:\hyperspin\Scripts FOLDER OK LETS NOW GO BACK AND REVISIT Fahrenheit32XStartup.ahk FILE ---------------------------------------------------------------------- #NoEnv ; Recommended for performance and compatibility with future AutoHotkey releases. ; #Warn ; Enable warnings to assist with detecting common errors. SendMode Input ; Recommended for new scripts due to its superior speed and reliability. SetWorkingDir %A_ScriptDir% ; Ensures a consistent starting directory. #Persistent ;Script will not Exit when no hotkeys exist. DetectHiddenWindows, On DetectHiddenText, On SetTimer, CheckPrograms, 1000 ;Run CheckPrograms subroutine every 1 second return CheckPrograms: IfWinExist, Fusion 3.64 - SegaCD - FAHRENHEIT { If NotepadTrack = 1 return Run, D:\hyperspin\Scripts\Fahrenheit32XLoadStateScript.ahk NotepadTrack = 1 } IfWinNotExist, Fusion 3.64 - SegaCD - FAHRENHEIT NotepadTrack = 0 return ------------------------------------------------------------------------ OK THE ONLY PART OF THIS CODE YOU NEED TO KNOW IS Run, D:\hyperspin\Scripts\Fahrenheit32XLoadStateScript.ahk REPLACE THE D:\hyperspin\Scripts\Fahrenheit32XLoadStateScript.ahk WITH C:\hyperspin\Scripts\Fahrenheit32XLoadStateScript.ahk SO THAT THE NEW LINE READS Run, C:\hyperspin\Scripts\Fahrenheit32XLoadStateScript.ahk (THIS DIRECTORY C:\hyperspin\Scripts\Fahrenheit32XLoadStateScript.ahk IS THE C:\hyperspin\Scripts\ DIRECTORY YOU MOVED THE 2 SCRIPT FILES TO) THE NEW FILE SHOULD LOOK LIKE THIS ---------------------------------------------------------------------- #NoEnv ; Recommended for performance and compatibility with future AutoHotkey releases. ; #Warn ; Enable warnings to assist with detecting common errors. SendMode Input ; Recommended for new scripts due to its superior speed and reliability. SetWorkingDir %A_ScriptDir% ; Ensures a consistent starting directory. #Persistent ;Script will not Exit when no hotkeys exist. DetectHiddenWindows, On DetectHiddenText, On SetTimer, CheckPrograms, 1000 ;Run CheckPrograms subroutine every 1 second return CheckPrograms: IfWinExist, Fusion 3.64 - SegaCD - FAHRENHEIT { If NotepadTrack = 1 return Run, C:\hyperspin\Scripts\Fahrenheit32XLoadStateScript.ahk NotepadTrack = 1 } IfWinNotExist, Fusion 3.64 - SegaCD - FAHRENHEIT NotepadTrack = 0 return ------------------------------------------------------------------------ OK NOW GO TO WHERE YOU PUT THE 2 SCRIPT FILES UR C:\hyperspin\Scripts\Fahrenheit32XStartup.ahk RIGHT CLICK Fahrenheit32XStartup.ahk AND CHOOSE COMPILE A NEW FILE WILL BE CREATED CALLED Fahrenheit32XStartup.exe AN EXECUTABLE FILE. NOW MAKE A COPY OF Fahrenheit32XStartup.exe AND PUT IT IN UR STARTUP FOLDER ON MY COMPUTER ITS LOCATED AT C:\Users\wally\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup NOW Fahrenheit32XStartup.exe WILL START UP AUTOMATICALY EVERY TIME WHEN U START UP UR COMPUTER AND YERRRR GOOD TO GO!!!! HIP HIP HURRAY...HIP HIP HURRAHH!!! I HAVE POUR ALL MY KNOWLEDGE INTO YOU ..WHEN YOU LOAD FAHRENHEIT MY SPIRIT LOADS WITH YOU ...WHEN LOADING FAHRENHEIT YOU WILL NEED IT. SEGACD-32X BIOS.zip
Styphelus Posted February 22, 2016 Posted February 22, 2016 There has to be an easier way to do this. There's so much text and so many steps that I just feel like deleting this game from my library. Would you mind posting your setup?
