markyboy782 Posted July 27, 2014 Posted July 27, 2014 Hi all im having a problem with afm the background volume is much lower than the fx volume I know how to adjust the volume ie end then 8 and 9 to adjust but I have to do it every time I enter the table. Is there any way to save my preferences so I don't have to adjust the volume each time I go back into the table.*
32assassin Posted July 27, 2014 Posted July 27, 2014 this problem has nothing to do with UVP. A UVP is a a file is used to run the light animation and scoreboard of the backglass. I suggest you delete them and use the more modern direct2BS. they look so much better. This problem should not be happening, this settings should be saved in your Registry, are you running PinMAME and VP with administrator rights?
