AshuraX Posted August 13, 2014 Posted August 13, 2014 Un nouveau theme déjà disponible dans la section Download. Peut être que l'on pourra l'utiliser sous Taito Type X 3. Et de nouveau themes à venir. My WIP Projects :Bezel Project Mame Horizontal : https://imageshack.com/a/auM4/1 Mame Vertical : https://imageshack.com/a/jEM4/1 Cave full pack : https://imageshack.com/a/7eJ4/1 Capcom : https://imageshack.com/a/eIM4/1 Themes Neo Geo Full Theme Pack : https://imageshack.com/a/oeJ4/1Mega CD Boxart : new thread will come....My First Cab Build : http://www.hyperspin-fe.com/topic/1221-ashurax-mon-projet-ghouls-ghost-arcade-cab/
Kam3leoN Posted August 13, 2014 Posted August 13, 2014 Magnifique à peine demandé dans un autre tread déjà mis à dispo ! ashurax dieu des mortels ^^
Kam3leoN Posted August 13, 2014 Posted August 13, 2014 Merde je ne peux pas le doawnload je suis trop degouté.
shinobi68 Posted August 13, 2014 Posted August 13, 2014 C'est quoi ton problème pour le downloader? Même si tu n'es pas membre, tu devrais avoir accès à la section download du site ?
Gendoh Posted October 5, 2014 Posted October 5, 2014 Hello. I can´t find the theme in the download section.. can anyone send me the link? Thanks in advance.
dazzlaa Posted November 7, 2017 Posted November 7, 2017 Thank you for the share, I am struggling to get it all working however. Also, the video seems to be just a frame and no video content? Have I messed up somewhere?
Metalzoic Posted November 9, 2017 Posted November 9, 2017 On 11/7/2017 at 10:27 AM, dazzlaa said: Thank you for the share, I am struggling to get it all working however. Also, the video seems to be just a frame and no video content? Have I messed up somewhere? Expand Yes it's a theme. You add whatever video/snap you want to play in that frame (just like any other normal theme). Not sure what you mean by getting it working though. Like any theme it must go into the correct place in your HS media folder, and must be named 100% exactly (case and all) the same as the rest of the games files which should be matched to the database.
dazzlaa Posted November 9, 2017 Posted November 9, 2017 On 11/9/2017 at 6:32 AM, Metalzoic said: Yes it's a theme. You add whatever video/snap you want to play in that frame (just like any other normal theme). Not sure what you mean by getting it working though. Like any theme it must go into the correct place in your HS media folder, and must be named 100% exactly (case and all) the same as the rest of the games files which should be matched to the database. Expand Hi there, Sorry I never came back to say thanks again after I got it working. Its a learning process for sure but I have had a lot of fun figuring it all out this week. I have got the theme up and running and it looks fantastic so thanks again
Metalzoic Posted November 11, 2017 Posted November 11, 2017 On 11/9/2017 at 9:40 AM, dazzlaa said: Hi there, Sorry I never came back to say thanks again after I got it working. Its a learning process for sure but I have had a lot of fun figuring it all out this week. I have got the theme up and running and it looks fantastic so thanks again Expand Sure. You also have a program in your Hyperspin folder called Hypertheme. If you even want to make your own or alter someone else's you can open that up and play around with it.
Question
AshuraX
My WIP Projects :
Bezel Project
Themes
12 answers to this question
