Emu54 Posted August 15, 2014 Posted August 15, 2014 Hi just updated my set up works great i add my databases from my old set up but when i go in to HyperLaunchHQ and load the list i get errors my lists where made with HyperROM2XML is there something else i can try
Emu54 Posted August 15, 2014 Author Posted August 15, 2014 I click on adult all games for this system and it says error parsing database file hyperspin make sure the xml is well formed thinking i need something to make new xml
rfancella Posted August 15, 2014 Posted August 15, 2014 Emu54 said: I click on adult all games for this system and it says error parsing database file hyperspin make sure the xml is well formed thinking i need something to make new xml That's because that program does not create valid xml files. It uses '&' instead of '&'. Try using HyperTools. There is a copy on the FTP server. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
damageinc86 Posted September 3, 2015 Posted September 3, 2015 You can also easy use notepad++ and the "find and replace" function to find all & and replace with &
