Emu54 Posted August 16, 2014 Posted August 16, 2014 Hi trying to add some artwork box's for sega saturn the collection i have are jpeg am i right in thinking JPEGs don't work and have to be PNG i tryed to convert them with IrfanView bulk worked but size is huge and one no the right settings or a better converter seen not found some collections on ftp but wrong names take so long to rename any help be great
rfancella Posted August 16, 2014 Posted August 16, 2014 Hi trying to add some artwork box's for sega saturn the collection i have are jpeg am i right in thinking JPEGs don't work and have to be PNG i tryed to convert them with IrfanView bulk worked but size is huge and one no the right settings or a better converter seen not found some collections on ftp but wrong names take so long to rename any help be great I just tested. Converted one of my png files to jpg and it did not show. Tried jpeg also, no joy. So I would think it has to be png files. I have used this utility before and it will convert a mass of files from one format to another and delete the originals if you tick the box. It's called Bulk Image Converter: http://sourceforge.net/projects/bulkimageconver/ Hope this helps. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Emu54 Posted August 16, 2014 Author Posted August 16, 2014 That worked Ron thanks had your help twice in 2 days thanks very much
rfancella Posted August 16, 2014 Posted August 16, 2014 That worked Ron thanks had your help twice in 2 days thanks very much Your very welcome my friend! Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
