rik81 Posted 12 hours ago Posted 12 hours ago No themes show... at all... Not even the Hyperspin default one. I added 4 systems for testing. MAME - Cause its a staple Sega Genesis - Good Console Choice Mugen - For a PC like add Nintendo Wii U Ware - Custom System The wheel media if you import your own seems to work though. I'm assuming the rest will work... like the videos... once the themes start working as then youll have something to display. I also cant seem to assign the Mugen theme to Mugen... Or any of the system themes. Also on every emulator... I got these errors coming up.... I dont want to run these at all.... How would you disable them? These arent needed... I understand what your trying to do... Im still in the process of downloading all the media. There is still over 20000... im hoping the themes will start working after. I dont think so though since ive already tried to update them with Hypertheme.
rik81 Posted 10 hours ago Author Posted 10 hours ago I deleted all the files that get copied on C... readded the systems... and the themes started working. But only for a spin around the wheel or two.... they themes stopped loading after and gets stuck on one of the backgrounds. Media is still pretty busted. Im giving up on this for now... will come back in a month... Im frustrated.
rondar Posted 6 hours ago Posted 6 hours ago I definitely understand the frustration. I've been testing multiple pre-release builds and it can get very tiring when things don't work like they should. That being said, before the last couple of builds I was not able to get MAME to work properly and that has been fixed for me. (If the NARC theme is what locked your wheel, I just removed an animation layer which seemed to be causing some type of bug. Deleting that theme and redownloading should fix that.) There's still a lot of improvement to be done, but we are headed in the right direction. Thank you for trying out the new build and giving your feedback. This video of my MAME wheel was just made using the current HQ and HS build: [sIGPIC][/sIGPIC]
