question for .ahk (module)_ experts
craiganderson
hello,
im working on a module. my first attempt at loading multiple disks.
basically the emulator has 4 "slots" for disks.
some games have two disks
i need to load them both. (into drive 1 and drive 2 separately)..which i know how to do individually.....but
some games only have one disk so the module needs to be able to do the following
check to see if game has 1,2,3,4 disks?
if one disk only....thats easy...load it
if has multiple disks ...load them into the right drive (disk 1 in drive 1 etc)
any modules you can recommend i look at to see how to do this?
if anything comes to mind
thanks
craig
i think i figured it out
this module (WIP) does the following
if rom contains "(Disk" in its name, it will trim off the last 9 characters (i.e trims off (Disk 1) or (Disk 2) etc
and then loads the trimmed rom name PLUS (Disk 1) into drive 1
the trimmed rom name PLUS (Disk 2) into drive 2
all the way up to drive 4
the emulator doesnt care if the disk doesnt exist (i.e. game is 2 disks not 4)
cool thing is .... you can start with any number disk from hyperspin (i.e. click on disk 2 or 4 or 1 etc) as your starting point...but it puts the correct one into the correct drive
just fyi
so far so good
works pretty good so far
let me know if you see a problem with this that perhaps i am not seeing
thanks
MEmu = EmuZ-2500
MEmuV =  Updated on Website: 10/11/2004
MURL = http://www.zophar.net/sharpmzx/emuz-2500.html
MAuthor = craiganderson
MVersion = 1.0
MCRC =
iCRC =
MID =
MSystem = "Sharp MZ-2500""
; FullScreen: Set fullscreen mode in HyperLaunch HQ "Edit Global Module Settings".
; RemoveMenuBar: Enable/Disable Removal of Menu Bar in HyperLaunch HQ "Edit Global Module Settings".
; HideMouseCursor: Enable/Disable Hiding of Mouse Cursor in HyperLaunch HQ "Edit Global Module Settings".
; Module currently ONLY loads disk images (.d88 is the one tested).
; Does not currently load games that need multiple disks.
; BIOS: IPL.ROM and KANJI.ROM are required. Other ROM images are optionally loaded if they exist. See readme.txt file for details.
StartModule()
FadeInStart()
Fullscreen := IniReadCheck(settingsFile, "settings", "Fullscreen","true",,1)
RemoveMenuBar := IniReadCheck(settingsFile, "settings", "RemoveMenuBar","true",,1)
HideMouseCursor := IniReadCheck(settingsFile, "settings", "HideMouseCursor","true",,1)
Run(executable, emuPath)
WinWait("ahk_class CWINDOW")
WinWaitActive("ahk_class CWINDOW")
; loading games with multiple disks
If romName contains (Disk
StringTrimRight, trimmedromName, romName, 9
Sleep,250
WinMenuSelectItem, ahk_class CWINDOW, , FDD1, Insert
Sleep, 1000
	Loop 	{
		ControlGetText, edit1Text, Edit1, Open ahk_class #32770
		If ( edit1Text = romPath . "\" . trimmedromName . " (Disk 1)" . romExtension )
			Break
		Sleep, 150
		ControlSetText, Edit1, %romPath%\%trimmedromName% (Disk 1)%romExtension%, Open ahk_class #32770
Sleep,450
ControlSend, Button1, {Enter}, Open ahk_class #32770
Sleep,250
WinMenuSelectItem, ahk_class CWINDOW, , FDD2, Insert
Sleep, 1200
	Loop 	{
		If ( edit1Text = romPath . "\" . trimmedromName . " (Disk 2)" . romExtension )
			Break
		Sleep, 150
		ControlSetText, Edit1, %romPath%\%trimmedromName% (Disk 2)%romExtension%, Open ahk_class #32770
Sleep, 450
Sleep, 250
WinMenuSelectItem, ahk_class CWINDOW, , FDD3, Insert
Sleep, 1200
	Loop 	{
		If ( edit1Text = romPath . "\" . trimmedromName . " (Disk 3)" . romExtension )
			Break
		Sleep, 150
		ControlSetText, Edit1, %romPath%\%trimmedromName% (Disk 3)%romExtension%, Open ahk_class #32770
Sleep, 450
Sleep, 250
WinMenuSelectItem, ahk_class CWINDOW, , FDD4, Insert
Sleep, 1200
	Loop 	{
		If ( edit1Text = romPath . "\" . trimmedromName . " (Disk 4)" . romExtension )
			Break
		Sleep, 150
		ControlSetText, Edit1, %romPath%\%trimmedromName% (Disk 4)%romExtension%, Open ahk_class #32770
Sleep, 450
ELSE
Sleep,250
	Loop 	{
		If ( edit1Text = romPath . "\" . romName . romExtension )
			Break
		Sleep, 150
		ControlSetText, Edit1, %romPath%\%romName%%romExtension%, Open ahk_class #32770
	Sleep, 450
;*******************FULLSCREEN*******************************
If Fullscreen = true
Sleep, 555
WinMenuSelectItem, ahk_class CWINDOW, , Screen, Fullscreen
;*******************RemoveMenuBar***************************
If RemoveMenuBar = true
Sleep, 555
DllCall("SetMenu", uint, WinActive( "A" ), uint, 0) ; Removes the MenuBar (thank you djvj)
;*******************HideMouseCursor***************************
If HideMouseCursor = true
Sleep, 555
SystemCursor(OnOff=0)
FadeInExit()
7zCleanUp()
FadeOutExit()
ExitModule()
CloseProcess:
FadeOutStart()
IfWinExist, EmuZ-2500
	WinKill
Return
