Fraggle99 Posted November 28, 2025 Posted November 28, 2025 Hi Does any know the command line so you load stright to the table, At the moment it open the emulater and then you have to press F5 to load the table. Thanks
Creezz67 Posted November 29, 2025 Posted November 29, 2025 18 hours ago, Fraggle99 said: Hi Does any know the command line so you load stright to the table, At the moment it open the emulater and then you have to press F5 to load the table. Thanks What are you trying to do ? Where are you trying to run the command line from ? A bat file ? Maybe post what you are trying to use currently ?
Fraggle99 Posted December 28, 2025 Author Posted December 28, 2025 hi Am using future pinball and the roms are fpt file i have set the emulator to none (direct Executable/Batch file) i haven't got any batch file to work
fr0stbyt3 Posted December 28, 2025 Posted December 28, 2025 14 hours ago, Fraggle99 said: hi Am using future pinball and the roms are fpt file i have set the emulator to none (direct Executable/Batch file) i haven't got any batch file to work Hey @Fraggle99 Direct executable means it'll try to launch files straight from your ROM path. So if you've got a folder of batch files, each game would be something like RomName.bat and it just runs it directly. Now if you're trying to launch games with a single batch file, that's a bit different - you'd add the .bat as a (emulator) platform instead, then set up the launch command to pass the game name or whatever that script needs. Check out the docs here: https://docs.hyperai.io/docs/hyperhq/managing-systems/#direct-executable-games I'll add this clarification to the docs soon too.
