Raven75 Posted April 25 Posted April 25 How do I set up Ledblinky correctly so that it works with Hyperspin 2?
Polemicist Posted May 7 Posted May 7 That's a good question. I have LED Blinky myself and I'm not that big of a fan of only having things for MAME etc. I'd like a LED controller directly within HS/HT that would allow me to make some form of say XML/INI file that can be configured by a simple interface (like what is used by XPADDER) so I can put in my complete setup visually on screen and directly interact with the XML files but not have these files limited to a single system. So for example if I open up Nintendo 64 I want the controllers to show the arcade buttons I have setup for it and then as I go through each game it shows the buttons for that game and then after a few seconds tells me what each button is... Yes it would be a group configuration (based on standard controller setup) and each configuration could be easily changed for people who have different needs. Would be a bit of work at that end. But first we need the plugin guru who could make this happen. Things are being worked on though. 1
Create an account
Register a new accountSign in
Sign In Now
