Recordguy Posted September 2, 2014 Posted September 2, 2014 Hello, I am wits end trying to figure this out. Hope someone can help! I recently installed Hyperspin, Hyperlaunch, HyperlaunchHQ, etc on my windows 7 pc with no problems. I'm using MAMEUIFX64 0.154 as my emulator. Made some modifications to my wheel, added some themes, video, etc. Very happy with it. Now what I'm wanting to do is install the same setup on a different pc running a clean install of Windows XP Pro. It's 32-bit so I'm installing MAMEUIFX32 0.154 instead. I have also installed Microsoft .Net Framework 3.5 & 4.0. The problem I'm having is this. I cannot load any of my roms from any application, including from within the emulator. In fact, when I try and load a game from within the emulator, the emulator shuts down. When I try and test a game from within HyperLaunchHQ by clicking the rocket button I (sometimes) get the following message: There was an error waiting for the window "ahk_class MAME" to become active. Please checkyou have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem. Other times, no message, just nothing happens. Here is the Hyperlaunch log after clicking the rocket to try & launch a game rom: 00:34:15:343 | HL | INFO | +N/A | Main - HyperLaunch v3.0.0.9 00:34:15:375 | HL | INFO | +31 | Main - System Specs: HyperLaunch Dir: C:\Hyperspin\HyperLaunch OS: WIN_XP Architecture: 32-bit (might not be accurate) OS Language: English_United_States OS Admin Status: Yes Monitor #1 (\\.\DISPLAY1): 1024x768 (1024x738 work) AutoHotkey Path: AHK Version: 1.1.09.04 Unicode: No 00:34:15:375 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x y w h 00:34:15:375 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\HyperLaunch.exe exists 00:34:15:375 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription Your favorite Front End companion! FileVersion 3.0.0.9 LegalCopyright ©2013 HL squad ProductName djvj's one swell guy! ProductVersion 1.1.9.4 CompanyName djvj's one swell guy! File Size: 899072 bytes Created: 9/1/2014 - 6:01:26 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:375 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\gdip.ahk exists 00:34:15:390 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 00:34:15:390 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 9/1/2014 - 6:01:20 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:390 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\RIni.ahk exists 00:34:15:390 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 00:34:15:390 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 9/1/2014 - 6:01:22 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:390 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\CLR.ahk exists 00:34:15:390 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 00:34:15:390 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10586 bytes Created: 9/1/2014 - 6:01:20 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:390 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\COM.ahk exists 00:34:15:406 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Extension. 00:34:15:406 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26342 bytes Created: 9/1/2014 - 6:01:20 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:406 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\JSON.ahk exists 00:34:15:406 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 00:34:15:406 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 9203 bytes Created: 9/1/2014 - 6:01:21 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:406 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Fade Init.ahk exists 00:34:15:406 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:34:15:406 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1145 bytes Created: 9/1/2014 - 6:01:16 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:406 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\HyperPause Init.ahk exists 00:34:15:406 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:34:15:406 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 691 bytes Created: 9/1/2014 - 6:01:16 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:406 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Keymapper Init.ahk exists 00:34:15:406 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:34:15:406 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 2485 bytes Created: 9/1/2014 - 6:01:16 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:406 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\MultiGame Init.ahk exists 00:34:15:406 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:34:15:406 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 161 bytes Created: 9/1/2014 - 6:01:16 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:406 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Statistics Init.ahk exists 00:34:15:406 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:34:15:406 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 167 bytes Created: 9/1/2014 - 6:01:16 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:406 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Fade.ahk exists 00:34:15:406 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:34:15:406 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26644 bytes Created: 9/1/2014 - 6:01:16 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:406 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\HyperPause.ahk exists 00:34:15:437 | HL | DEBUG1 | +32 | CRC Check - CRC matches, this is an official unedited Library. 00:34:15:437 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 326352 bytes Created: 9/1/2014 - 6:01:16 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:437 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Keymapper.ahk exists 00:34:15:437 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:34:15:437 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 27844 bytes Created: 9/1/2014 - 6:01:16 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:437 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\MultiGame.ahk exists 00:34:15:437 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:34:15:437 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 28070 bytes Created: 9/1/2014 - 6:01:16 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:437 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Bezel.ahk exists 00:34:15:437 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:34:15:437 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 21407 bytes Created: 9/1/2014 - 6:01:16 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:437 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Statistics.ahk exists 00:34:15:437 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:34:15:437 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26089 bytes Created: 9/1/2014 - 6:01:16 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:437 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Rom Mapping Launch Menu.ahk exists 00:34:15:453 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 00:34:15:453 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 63798 bytes Created: 9/1/2014 - 6:01:16 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:453 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Shared.ahk exists 00:34:15:453 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:34:15:453 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 65137 bytes Created: 9/1/2014 - 6:01:16 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:453 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\XHotkey.ahk exists 00:34:15:453 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:34:15:453 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 28659 bytes Created: 9/1/2014 - 6:01:16 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:453 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Fade Animations.ahk exists 00:34:15:453 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:34:15:468 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 48181 bytes Created: 9/1/2014 - 6:01:16 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:468 | HL | INFO | +0 | Main - HyperLaunch received "MAME" and "defender" 00:34:15:468 | HL | INFO | +0 | Main - defender is using the default emulator: MAME 00:34:15:468 | HL | INFO | +0 | Main - Checking for a [MAME] section in C:\Hyperspin\HyperLaunch\Settings\MAME\Emulators.ini 00:34:15:468 | HL | INFO | +0 | Main - Checking for a [MAME] section in C:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini 00:34:15:468 | HL | INFO | +0 | Main - Found [MAME] in C:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini 00:34:15:468 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Modules\MAME\MAME.ahk exists 00:34:15:468 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 9871 bytes Created: 9/1/2014 - 6:01:24 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:468 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 00:34:15:468 | HL | INFO | +0 | Main - defender will use module: C:\Hyperspin\HyperLaunch\Modules\MAME\MAME.ahk 00:34:15:500 | HL | INFO | +31 | Main - Using standard method with "Rom Extensions" SkipChecks or without any SkipChecks. 00:34:15:500 | HL | INFO | +0 | Main - INI Keys read 00:34:15:500 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\7z.exe exists 00:34:15:500 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 9.20 InternalName 7z LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 163840 bytes Created: 9/1/2014 - 6:01:20 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:500 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\7z.dll exists 00:34:15:500 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7z Standalone Plugin FileVersion 9.20 InternalName 7za LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7za.dll ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 914432 bytes Created: 9/1/2014 - 6:01:20 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:500 | HL | INFO | +0 | CheckPaths - Started 00:34:15:500 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: C:\Roms\MAME\defender.zip 00:34:15:531 | HL | INFO | +31 | CheckPaths - Found rom: C:\Roms\MAME\defender.zip 00:34:15:531 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Emulators\MAME\mameuifx32.exe exists 00:34:15:531 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription Multiple Arcade Machine Emulator with GUI FileVersion 0, 154, 0, 0 InternalName MAMEUIFX LegalCopyright Copyright Nicola Salmoria and the MAME team OriginalFilename MAMEUIFX ProductName MAMEUIFX ProductVersion 0.154 CompanyName MAME Team File Size: 78885376 bytes Created: 7/23/2014 - 4:17:52 AM Modified: 7/23/2014 - 4:17:52 AM 00:34:15:531 | HL | INFO | +0 | CheckPaths - Ended 00:34:15:531 | HL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 2 frontendPID = 0 frontendPath = C:\Hyperspin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = C: exitEmulatorKey = ~Esc exitEmulatorKeyWait = 0 forceHoldKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s emuFullPath = C:\Hyperspin\Emulators\MAME\mameuifx32.exe emuPath = C:\Hyperspin\Emulators\MAME emuName = MAME emuExt = exe romPath = C:\Roms\MAME romPathFromIni = C:\Roms\MAME romExtension = .zip romExtensionOrig = .zip romExtensions = zip|7z executable = mameuifx32.exe systemName = MAME dbName = defender romName = romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfWheelsByScreen = 7 romMappingMenuWidth = 300 romMappingMenuMargin = 50 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s40 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 5 romMappingTextMargin = 10 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s60 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s15 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s15 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 40 romMappingMenuFlagSeparation = 5 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false skipchecks = false romMatchExt = true logFile = C:\Hyperspin\HyperLaunch\HyperLaunch.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 10 logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = false navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1024 originalHeight = 768 dtEnabled = true dtPath = dtUseSCSI = true dtAddDrive = true emuIdleShutdown = 0 hideEmu = false hideFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Align to Top Left fadeLyr2Pos = Bottom Right Corner fadeLyr2X = 300 fadeLyr2Y = 300 fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr3Pos = Center fadeLyr3X = 300 fadeLyr3Y = 300 fadeLyr3Adjust = 0.75 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3PicPad = 0 fadeLyr4Adjust = 0.75 fadeLyr4X = 100 fadeLyr4Y = 100 fadeLyr4Pos = Above Layer 3 - Left fadeLyr4FPS = 10 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = false fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 600 fadeBarWindowH = 120 fadeBarWindowR = 20 fadeBarWindowM = 20 fadeBarWindowHatchStyle = 8 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 20 fadeBarR = 5 fadeBarColor = DD00BFFF fadeBarHatchStyle = 3 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 100 fadeRomInfoDescription = text fadeRomInfoSystemName = text fadeRomInfoYear = text fadeRomInfoManufacturer = text fadeRomInfoGenre = text fadeRomInfoRating = text fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = topRight fadeRomInfoTextMargin = 5 fadeRomInfoText1Options = cFF555555 r4 s20 Bold fadeRomInfoText2Options = cFF555555 r4 s20 Bold fadeRomInfoText3Options = cFF555555 r4 s20 Bold fadeRomInfoText4Options = cFF555555 r4 s20 Bold fadeRomInfoText5Options = cFF555555 r4 s20 Bold fadeRomInfoText6Options = cFF555555 r4 s20 Bold fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topLeft fadeStatsInfoTextMargin = 5 fadeStatsInfoText1Options = cFF555555 r4 s20 Bold fadeStatsInfoText2Options = cFF555555 r4 s20 Bold fadeStatsInfoText3Options = cFF555555 r4 s20 Bold fadeStatsInfoText4Options = cFF555555 r4 s20 Bold fadeStatsInfoText5Options = cFF555555 r4 s20 Bold fadeStatsInfoText6Options = cFF555555 r4 s20 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFFFFFFF r4 s20 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFFFFFFF r4 s20 Right Bold fadeText2 = Extraction Complete fadeFont = Arial fadeSystemAndRomLayersOnly = false fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = C:\Hyperspin\HyperLaunch\Media\Fade HLDataPath = C:\Hyperspin\HyperLaunch\Data HLMediaPath = C:\Hyperspin\HyperLaunch\Media HLErrSoundPath = C:\Hyperspin\HyperLaunch\Media\Sounds\Error modulesPath = C:\Hyperspin\HyperLaunch\Modules moduleFullName = C:\Hyperspin\HyperLaunch\Modules\MAME\MAME.ahk moduleName = MAME modulePath = C:\Hyperspin\HyperLaunch\Modules\MAME moduleExtension = ahk moduleExtensionsPath = C:\Hyperspin\HyperLaunch\Module Extensions libPath = C:\Hyperspin\HyperLaunch\Lib 7zEnabled = false 7zPath = C:\Hyperspin\HyperLaunch\Module Extensions\7z.exe 7zDllPath = C:\Hyperspin\HyperLaunch\Module Extensions\7z.dll 7zExtractPath = C:\Documents and Settings\Arcade\Local Settings\Temp\HS 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgYOffset = 500 mgImageAdjust = 0 mgFont = Arial mgText1Options = x10p y30p w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 70 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgArtworkDir = Artwork1 hpEnabled = false hpKey = ~NumpadAdd hpBackToMenuBarKey = X hpZoomInKey = C hpZoomOutKey = V hpScreenshotKey = ~PrintScreen hpHiToTextPath = C:\Hyperspin\HyperLaunch\Module Extensions\HiToText.exe hpSaveStateKeyCodes = {shift down}{F7 down}{F7 up}{shift up} hpLoadStateKeyCodes = {shift down}{F7 down}{F7 up}{shift up} keymapperEnabled = false keymapper = xpadderFullPath = C:\Hyperspin\Utilities\Xpadder\xpadder.exe joyToKeyFullPath = C:\Hyperspin\Utilities\JoyToKey\JoyToKey.exe keymapperProfilePath = C:\Hyperspin\HyperLaunch\Profiles\ keymapperFrontEndProfileName = HyperSpin keymapperHyperLaunchProfileEnabled = false JoyIDsEnabled = false JoyIDsPreferredControllersSystem = use_global JoyIDsPreferredControllersGlobal = use_global CustomJoyNamesEnabled = false CustomJoyNames = FEProfile = C:\Hyperspin\HyperLaunch\Profiles\\HyperSpin defaultProfile = C:\Hyperspin\HyperLaunch\Profiles\\_Default systemProfile = C:\Hyperspin\HyperLaunch\Profiles\\MAME xPadderSystemProfile = C:\Hyperspin\HyperLaunch\Profiles\\MAME\_Default emuProfile = C:\Hyperspin\HyperLaunch\Profiles\\MAME\MAME romProfile = C:\Hyperspin\HyperLaunch\Profiles\\MAME\defender blankProfile = C:\Hyperspin\HyperLaunch\Profiles\\blank HyperLaunchProfile = C:\Hyperspin\HyperLaunch\Profiles\\HyperLaunch bezelEnabled = false statisticsEnabled = true 00:34:15:531 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 00:34:15:531 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 00:34:15:531 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script 00:34:15:531 | HL | DEBUG1 | +0 | BuildScript - Module starts on line: 285 00:34:15:531 | HL | INFO | +0 | BuildScript - Module: MEmu = MAME MEmuV = v0.148 MURL = http://www.mame.net/ MAuthor = djvj MVersion = 2.0.6 MCRC = D558F163 iCRC = CD775A90 MID = 635038268903403479 MSystem = "AAE","Cave","LaserDisc","MAME","Nintendo Arcade Systems","Sega Model 1","Sega ST-V","SNK Neo Geo","SNK Neo Geo AES" ;---------------------------------------------------------------------------- ; Notes: ; No need to edit mame.ini and set your rom folder, module sends the rompath for you. ; Command Line Options - http://easyemu.mameworld.info/mameguide/mameguide-options.html ; High Scores DO NOT SAVE when cheats are enabled! ; HLSL Documentation: http://mamedev.org/source/docs/hlsl.txt.html ; MAME 149 is currently bugged and HyperPause support is broken. Emu does not let you alt-tab out. This is a mamedev issue, not an HL one. ; If you use MAME for AAE, create a vector.ini in mame's ini subfolder and paste these HLSL settings in there: http://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=309968&page=&view=&sb=5&o=&vc=1 ;---------------------------------------------------------------------------- StartModule() FadeInStart() settingsFile := CheckFile(modulePath . "\" . moduleName . ".ini") Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) Videomode := IniReadCheck(settingsFile, "Settings", "Videomode","d3d",,1) hideConsole := IniReadCheck(settingsFile, "Settings", "HideConsole","true",,1) ; Hides console window from view if it shows up pauseMethod := IniReadCheck(settingsFile, "Settings", "PauseMethod",1,,1) ; set the pause method that works better on your machine (preferred methods 1 and 2) 1 = Win7 and Win8 OK - Problems with Win XP, 2 = preferred method for WinXP - Problems in Win7, 3 and 4 = same as 1 and 2, 5 = only use If you have a direct input version of mame, 6 = suspend mame process method, it could crash mame in some computers bezelMode := IniReadCheck(settingsFile, "Settings", "BezelMode","layout",,1) ; "layout" or "normal" cheatMode := IniReadCheck(settingsFile, "Settings", "CheatMode","false",,1) cheatModeKey := IniReadCheck(settingsFile, "Settings", "CheatModeKey",A_Space,,1) ; user defined key to be held down before launching a mame rom. sysParams := IniReadCheck(settingsFile, systemName, "Params", A_Space,,1) romParams := IniReadCheck(settingsFile, romName, "Params", A_Space,,1) mameRomName := IniReadCheck(settingsFile, romName, "MameRomName", A_Space,,1) Use_Bezels := IniReadCheck(settingsFile, "Settings", "Use_Bezels", "true",,1) Use_Bezels := IniReadCheck(settingsFile, romName, "Use_Bezels", Use_Bezels,,1) ; default is the system's current setting Use_Overlays := IniReadCheck(settingsFile, "Settings", "Use_Overlays", "true",,1) Use_Overlays := IniReadCheck(settingsFile, romName, "Use_Overlays", Use_Overlays,,1) ; default is the system's current setting Use_Backdrops := IniReadCheck(settingsFile, "Settings", "Use_Backdrops", "true",,1) Use_Backdrops := IniReadCheck(settingsFile, romName, "Use_Backdrops", Use_Backdrops,,1) ; default is the system's current setting If bezelEnabled = true { ListXMLtable := [] ListXMLtable := ListXMLInfo(romName) If bezelMode = layout { useBezels := If (Use_Bezels = "true") ? "-use_bezels" : "-nouse_bezels" useOverlays := If (Use_Overlays = "true") ? "-use_overlays" : "-nouse_overlays" useBackdrops := If (Use_Backdrops = "true") ? "-use_backdrops" : "-nouse_backdrops" BezelStart(romName,ListXMLtable[1],ListXMLtable[2],ListXMLtable[3],ListXMLtable[4]) } Else { useBezels := "-nouse_bezels" useOverlays := "-nouse_overlays" useBackdrops := "-nouse_backdrops" BezelStart(,,ListXMLtable[2]) } } ; -romload part of 147u2 that shows what roms were checked when missing roms winstate := If (Fullscreen = "true") ? "Hide UseErrorLevel" : "UseErrorLevel" fullscreen := If (Fullscreen = "true") ? "-nowindow" : "-window" videomode := If (Videomode != "" ) ? "-video " . videomode : "" sysParams := If sysParams != "" ? sysParams : "" romParams := If romParams != "" ? romParams : "" StringReplace,mameRomPaths,romPathFromIni,|,`"`;`",1 ; replace all instances of | to ; in the Rom_Path from Emulators.ini so mame knows where to find your roms mameRomPaths := "-rompath """ . (If mameRomName ? romPath : mameRomPaths) . """" ; if using an alt rom, only supply mame with the path to that rom so it doesn't try to use the original rom If InStr(romParams,"-rompath") ScriptError("""-rompath"" is defined as a parameter for " . romName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.") If InStr(sysParams,"-rompath") ScriptError("""-rompath"" is defined as a parameter for " . systemName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.") If mameRomName { FileMove, %romPath%\%romName%%romExtension%, %romPath%\%mameRomName%%romExtension% ; rename rom to match what mame needs originalRomName := romName ; store romName from database so we know what to rename it back to later romName := mameRomName If ErrorLevel ScriptError("There was a problem renaming " . romName . " to " . mameRomName . " in " . romPath . ". Please check you have write permission to this folder/file and you don't already have a file named """ . mameRomName . """ in your rom folder.",8) Else ; if rename was successful, set var so we know to move it back later fileRenamed = 1 } If cheatMode = true { If cheatModeKey ; if user wants to use a key to enable CheatMode cheatEnabled := If XHotkeyAllKeysPressed(cheatModeKey) ? "-cheat" : "" Else ; no cheat mode key defined cheatEnabled := "-cheat" } If hideConsole = true SetTimer, HideConsole, 10 Run(executable . A_Space . romName . A_Space . fullscreen . A_Space . cheatEnabled . A_Space . videomode . A_Space . useBezels . A_Space . useOverlays . A_Space . useBackdrops . A_Space . mameRomPaths . A_Space . sysParams . A_Space . romParams, emuPath, winstate) If(ErrorLevel != 0){ If (ErrorLevel = 1) Error = Failed Validity Else If(ErrorLevel = 2) Error = Missing Files Else If(ErrorLevel = 3) Error = Fatal Error Else If(ErrorLevel = 4) Error = Device Error Else If(ErrorLevel = 5) Error = Game Does Not Exist Else If(ErrorLevel = 6) Error = Invalid Config Else If ErrorLevel in 7,8,9 Error = Identification Error Else Error = MAME Error ScriptError("MAME Error - " . Error) } WinWait("ahk_class MAME") WinWaitActive("ahk_class MAME") BezelDraw() FadeInExit() Process("WaitClose", executable) BezelExit() If fileRenamed { ; rename file back to alternate name for next launch FileMove, %romPath%\%romName%%romExtension%, %romPath%\%originalRomName%%romExtension% If ErrorLevel ; if rename was successful, set var so we know to move it back later ScriptError("There was a problem renaming " . romName . " back to " . originalRomName) } FadeOutExit() ExitModule() ListXMLInfo(rom){ ; returns MAME/MESS info about parent rom, orientation angle, resolution Global emuFullPath, emuPath ListXMLtable := [] RunWait, % comspec . " /c " . """" . emuFullPath . """" . " -listxml " . rom . " > tempBezel.txt", %emuPath%, Hide Fileread, ListxmlContents, %emuPath%\tempBezel.txt RegExMatch(ListxmlContents, "s)<game.*name=" . """" . rom . """" . ".*" . "cloneof=" . """" . "[^""""]*", parent) RegExMatch(parent,"cloneof=" . """" . ".*", parent) RegExMatch(parent,"""" . ".*", parent) StringTrimLeft, parent, parent, 1 RegExMatch(ListxmlContents, "s)<display.*rotate=" . """" . "[0-9]+" . """", angle) RegExMatch(angle,"[0-9]+", angle, "-6") RegExMatch(ListxmlContents, "s)<display.*width=" . """" . "[0-9]+" . """", width) RegExMatch(width,"[0-9]+", width, "-6") RegExMatch(ListxmlContents, "s)<display.*height=" . """" . "[0-9]+" . """", Height) RegExMatch(Height,"[0-9]+", Height, "-6") ListXMLtable[1] := parent ListXMLtable[2] := angle If (ListXMLtable[2]<>0) ListXMLtable[3] := height Else ListXMLtable[3] := width If (ListXMLtable[2]<>0) ListXMLtable[4] := width Else ListXMLtable[4] := height FileDelete, %emuPath%\tempBezel.txt Return ListXMLtable } HaltEmu: If pauseMethod = 1 { disableSuspendEmu = true disableRestoreEmu = true PostMessage,0x211, 1, , , ahk_class MAME } Else If pauseMethod = 2 { disableSuspendEmu = true PostMessage,0x211, 1, , , ahk_class MAME } Else If pauseMethod = 3 { disableSuspendEmu = true disableRestoreEmu = true PostMessage,% 0x0400+6, 1, , , ahk_class MAME } Else If pauseMethod = 4 { disableSuspendEmu = true PostMessage,% 0x0400+6, 1, , , ahk_class MAME } Else If pauseMethod = 5 { disableSuspendEmu = true Send, {P down} Sleep, 1000 Send, {P up} } Return RestoreEmu: If pauseMethod = 1 { PostMessage,0x212, 1, , , ahk_class MAME WinActivate, ahk_class MAME } Else If pauseMethod = 2 { PostMessage,0x212, 1, , , ahk_class MAME WinActivate, ahk_class MAME } Else If pauseMethod = 3 { PostMessage,% 0x0400+6, 0, , , ahk_class MAME WinActivate, ahk_class MAME } Else If pauseMethod = 4 { PostMessage,% 0x0400+6, 0, , , ahk_class MAME WinActivate, ahk_class MAME } Else If pauseMethod = 5 { disableSuspendEmu = true Send, {P down} Sleep, 1000 Send, {P up} WinActivate, ahk_class MAME } Else If pauseMethod = 6 WinActivate, ahk_class MAME Return HideConsole: hideConsoleTimer++ IfWinExist, ahk_class ConsoleWindowClass { Log("Module - HideConsole - Console window found, hiding it out of view.") WinSet, Transparent, 0, ahk_class ConsoleWindowClass SetTimer, HideConsole, Off } Else If hideConsoleTimer >= 200 SetTimer, HideConsole, Off Return CloseProcess: FadeOutStart() WinClose("ahk_class MAME") Return 00:34:15:531 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 00:34:15:531 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script 00:34:15:531 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 00:34:15:531 | HL | INFO | +0 | Main - Module is built 00:34:15:531 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\AutoHotkey.dll exists 00:34:15:546 | HL | DEBUG1 | +16 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 9/1/2014 - 6:01:26 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:593 | HL | INFO | +47 | Main - Running module 00:34:15:593 | HL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 00:34:15:718 | MD | INFO | +N/A | Module initialized 00:34:15:750 | MD | INFO | +31 | StartModule - Started 00:34:15:750 | MD | INFO | +0 | StartModule - MEmu: MAME MEmuV: v0.148 MURL: http://www.mame.net/ MAuthor: djvj MVersion: 2.0.6 MCRC: D558F163 iCRC: CD775A90 MID: MSystem: "AAE","Cave","LaserDisc","MAME","Nintendo Arcade Systems","Sega Model 1","Sega ST-V","SNK Neo Geo","SNK Neo Geo AES" 00:34:15:750 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "MAME" 00:34:15:750 | MD | DEBUG1 | +0 | StartModule - Setting romName to the dbName sent to HyperLaunch: 00:34:15:750 | MD | INFO | +0 | StartModule - Ended 00:34:15:750 | MD | INFO | +0 | StartGlobalUserFeatures - Starting 00:34:15:750 | MD | INFO | +0 | StartGlobalUserFeatures - Ending 00:34:15:750 | MD | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Modules\MAME\MAME.ini exists 00:34:15:750 | MD | DEBUG1 | +0 | CheckFile - Attributes: File Size: 2352 bytes Created: 9/1/2014 - 6:01:24 PM Modified: 9/1/2014 - 5:58:07 PM 00:34:15:781 | MD | INFO | +31 | Module Setting - Fullscreen: true 00:34:15:781 | MD | INFO | +0 | Module Setting - Videomode: d3d 00:34:15:781 | MD | INFO | +0 | Module Setting - HideConsole: true 00:34:15:781 | MD | INFO | +0 | Module Setting - PauseMethod: 4 00:34:15:781 | MD | INFO | +0 | Module Setting - BezelMode: normal 00:34:15:781 | MD | INFO | +0 | Module Setting - CheatMode: true 00:34:15:781 | MD | INFO | +0 | Module Setting - CheatModeKey: Z&X 00:34:15:781 | MD | INFO | +0 | Module Setting - Use_Bezels: true 00:34:15:781 | MD | INFO | +0 | Module Setting - Use_Bezels: true 00:34:15:781 | MD | INFO | +0 | Module Setting - Use_Overlays: true 00:34:15:781 | MD | INFO | +0 | Module Setting - Use_Overlays: true 00:34:15:781 | MD | INFO | +0 | Module Setting - Use_Backdrops: true 00:34:15:781 | MD | INFO | +0 | Module Setting - Use_Backdrops: true 00:34:15:781 | MD | INFO | +0 | Module Run - Running: C:\Hyperspin\Emulators\MAME\mameuifx32.exe defender -nowindow -video d3d -rompath "C:\Roms\MAME" 00:34:15:921 | MD | DEBUG1 | +141 | Module Run - "mameuifx32.exe defender -nowindow -video d3d -rompath "C:\Roms\MAME" " Process ID: 2536 00:34:15:921 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: HyperLaunch HQ v1.0.13.0 | Class: HwndWrapper[HyperLaunchHQ.exe;;5ab1b5c0-6387-4f40-b496-a8a210cd2b43] | State: 0 | X: 2 | Y: 2 | Width: 1022 | Height: 736 | Window HWND: 0xc0160 | Process ID: 2352 | Process Path: C:\Hyperspin\HyperLaunch\HyperLaunchHQ\HyperLaunchHQ.exe 00:34:15:921 | MD | INFO | +0 | Module WinWait - Waiting for ahk_class MAME 00:34:21:968 | MD | DEBUG1 | +6047 | GetActiveWindowStatus - Title: MAME: Defender (Red label) [defender] | Class: MAME | State: 0 | X: 0 | Y: 0 | Width: 1024 | Height: 768 | Window HWND: 0x47019c | Process ID: 2536 | Process Path: C:\Hyperspin\Emulators\MAME\mameuifx32.exe 00:34:21:968 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: MAME: Defender (Red label) [defender] | Class: MAME | State: 0 | X: 0 | Y: 0 | Width: 1024 | Height: 768 | Window HWND: 0x47019c | Process ID: 2536 | Process Path: C:\Hyperspin\Emulators\MAME\mameuifx32.exe 00:34:21:968 | MD | INFO | +0 | Module WinWaitActive - Waiting for "ahk_class MAME" 00:34:22:078 | MD | DEBUG1 | +109 | GetActiveWindowStatus - Title: MAME: Defender (Red label) [defender] | Class: MAME | State: 0 | X: 0 | Y: 0 | Width: 1024 | Height: 768 | Window HWND: 0x47019c | Process ID: 2536 | Process Path: C:\Hyperspin\Emulators\MAME\mameuifx32.exe 00:34:22:578 | MD | INFO | +500 | Module Process - WaitClose mameuifx32.exe 00:34:22:687 | MD | INFO | +110 | StopGlobalUserFeatures - Starting 00:34:22:687 | MD | INFO | +0 | StopGlobalUserFeatures - Ending 00:34:22:687 | MD | INFO | +0 | ExitModule - Started 00:34:22:687 | MD | INFO | +0 | Starting Updating Statistics: 00:34:22:687 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 00:34:22:687 | MD | DEBUG2 | +0 | gameSectionStartTime:25529312 00:34:22:687 | MD | DEBUG2 | +0 | ElapsedTime:6 00:34:22:687 | MD | INFO | +0 | CreateRomTable - Started 00:34:22:687 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "defender" and "(Disc" 00:34:22:687 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "defender" and "(Disk" 00:34:22:687 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "defender" and "(Cart" 00:34:22:687 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "defender" and "(Tape" 00:34:22:687 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "defender" and "(Cassette" 00:34:22:687 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "defender" and "(Part" 00:34:22:687 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "defender" and "(Side" 00:34:22:687 | MD | INFO | +0 | CreateRomTable - Ended, 7 Loops to create table. 00:34:22:687 | MD | DEBUG2 | +0 | Statistics cleared game name: defender 00:34:22:734 | MD | DEBUG2 | +46 | Loaded game statistics from ini files: Number_of_Times_Played: 0 Last_Time_Played: 0 Average_Time_Played: 0 Total_Time_Played: 0 System_Total_Played_Time: 23 Total_Global_Played_Time: 23 00:34:22:812 | MD | DEBUG2 | +79 | Updated Statistics: Number_of_Times_Played: 1 Last_Time_Played: Tuesday September 2, 2014 12:34:22 AM Average_Time_Played: 6 Total_Time_Played: 6 System_Total_Played_Time: 29 Total_Global_Played_Time: 29 00:34:22:968 | MD | INFO | +156 | Game section statistics updated. 00:34:22:968 | MD | INFO | +0 | ExitModule - Ended 00:34:22:968 | MD | INFO | +0 | End of Module Logs 00:34:23:078 | HL | INFO | +7484 | Main - Module ended, exiting HyperLaunch normally 00:34:23:078 | HL | INFO | +0 | ExitScript - Started 00:34:23:109 | HL | DEBUG1 | +31 | ExitScript - Putting HyperSpin.exe back in focus 00:34:23:140 | HL | INFO | +32 | SystemCursor - Restoring mouse cursor 00:34:23:140 | HL | INFO | +0 | ExitScript - Ended Any ideas? Thanks in advance, Rob
Polemicist Posted September 6, 2014 Posted September 6, 2014 Sorry mate looks like you post got spam blocked. My reply should shoot it back to the top so it will get noticed.
ghutch92 Posted September 6, 2014 Posted September 6, 2014 my guess is hyperlaunch is sending a command line option that mame doesn't like. Try updating your install using git and see if the hyperlaunch developer has already fixed your issue. https://sites.google.com/site/hyperlaunch2/home/downloads How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
Recordguy Posted September 6, 2014 Author Posted September 6, 2014 ghutch, thanks for the reply. After a lot of trial and error & research it turns out that my video driver was not updated since the xp reinstall. Works like a charm now. Thanks.
