Quentaeron Posted September 8, 2014 Posted September 8, 2014 There's a few clones of MAME ROMs I'd like to run (2 player version of Gauntlet for instance, since I have a 2p cabinet), but when I put a clone in the XML file for the wheel, it doesn't show up, even though I have the option to show/use clones enabled in HyperHQ. Suggestions?
albert_c Posted September 8, 2014 Posted September 8, 2014 Better to create a custom MAME.xml file using Don's HyperSpin Tools and drop it into your HyperSpin>Databases>MAME folder. I made a little video that can help you where I did the same thing but for TMNT: Click on the 3rd section. When you find great deals on Craigslist for CRT based cabs, exuberance can be a bad thing! Current status of cabs: 0/5 working as desired :wallbash:
Quentaeron Posted September 8, 2014 Author Posted September 8, 2014 I'll have to check that out when I get home. Didn't Don's HyperSpin Tools get phased out? The DL page indicates it's no longer supported.
somail Posted September 8, 2014 Posted September 8, 2014 This issue can be caused by a few items. 1. HyperHQ includes options to only show items with a wheel images, videos, and themes. If enabled you will need to make a copy of the parent's media and rename it to match the clone. 2. There is a naming error in the XML and it is not matching the rom. 3. You are using a merged mame rom set and during HyperSpin's audit (if enabled) it is not finding the clone's zip file.
albert_c Posted September 9, 2014 Posted September 9, 2014 I'll have to check that out when I get home. Didn't Don's HyperSpin Tools get phased out? The DL page indicates it's no longer supported. It still works fine. When you find great deals on Craigslist for CRT based cabs, exuberance can be a bad thing! Current status of cabs: 0/5 working as desired :wallbash:
