Hyperspin pops up after pc game loads
rudealleycat
@ghutch92 this is bad as the game is hidden while I'm trying to play.
@guyverjay I didn't and read somewhere that using them might fix this issue. I tried them but it didn't work.
If your running this through PC Launcher and not HL exe then you have more options. Im no pro but I got mine to work by doing the "wait for fade thingy on the bottom right of the module and roms options in HLHQ.... the one where you run it and then press ctl q or somehting. Once I do that once the game start and then restart it with those options its fine.
I think sometimes HL gets confused as to what its looking for when the game starts. If it doesnt see the right thing it just brings you back thinking it never started.
Hope this helped. I had to play with many of these settings getting my TTX to work
I tried to find what you were talking about austin585 but couldn't find that option. Where is that at?
Here is the log from trying to run hyperspin
10:26:49 PM | HyperSpin Started
10:26:49 PM | Going FullScreen
10:26:49 PM | Checking for updates
10:26:49 PM | Update Check Complete
10:26:49 PM | Startup program: JoyToKey.exe
10:26:49 PM | Startup params not set
10:26:49 PM | Working directory: C:\Hyperspin\JoyToKey\
10:26:49 PM | Window State: NORMAL
10:26:49 PM | Launching JoyToKey.exe
10:26:49 PM | Command Line is JoyToKey.exe
10:26:50 PM | Playing intro video
10:26:54 PM | Error intializing joysticks
10:26:54 PM | Menu Mode is multi
10:26:54 PM | Loading Main Menu.xml
10:26:54 PM | Main Menu.xml successfully loaded
10:26:55 PM | Main Menu wheel loaded successfully
10:27:00 PM | Loading PC Games.xml
10:27:00 PM | Main Menu.xml successfully loaded
10:27:00 PM | PC Games wheel loaded successfully
10:27:16 PM | Launching Game
10:27:16 PM | Using HyperLaunch
10:27:16 PM | Getting HyperLaunch path
10:27:16 PM | HyperLaunch located at C:\Hyperspin\HyperLaunch\HyperLaunch.exe
10:27:16 PM | Running HyperLaunch.exe
10:27:16 PM | HyperLaunch Command Line is: C:\Hyperspin\HyperLaunch\HyperLaunch.exe "PC Games" "Audiosurf"
10:27:52 PM | Loading Main Menu.xml
10:27:53 PM | Main Menu.xml successfully loaded
10:27:53 PM | Main Menu wheel loaded successfully
10:27:56 PM | Exit program unavailable
10:27:56 PM | Quiting Hyperspin
10:27:56 PM | Bye!
I've seen this problem before.
One fix is to disable keymapper
Another fix is to use xpadder
Another fix is to download the latest and greatest version of HyperLaunch (has a fix for the joytokey issue) using git.
Another fix is to not use git and just download the zip file from the repository here. Not recommended because it makes updating the modules and supporting files a pain.
I figured out the problem. The game loads a totally different exe at first before launching into the game. After updating HyperLaunch I used AppWaitExe in the pclauncher module to fix this problem.
Thanks for the help!
