I have HyperLaunch.exe but it cant find it.
benny7438
i try to play a game on hyperspin. but it keeps saying that it cant find hyperlaunch.exe. i'm sure i have it! i never deleted anything. how do i find it and direct hyperspin to it?
i heard someone say that i should find settings.ini and do it that way or something but thats pretty vague for me. can anyone here help?
Welcome to the forum benny.
Yes whoever mentioned the setting.ini was probably right. You'll find it in the Hyperspin settings folder, you need to add your path to Hyperlaunch including a backslash at the end of the line.
ok. thx! :D by the way, is there a way for me to get the official mame wheel images? its just blank text for me that says i could get the video at emumovies.com. is there any way i could get the actual wheel images and videos? ive been searching forever.
ok. thx! by the way, is there a way for me to get the official mame wheel images? its just blank text for me that says i could get the video at emumovies.com. is there any way i could get the actual wheel images and videos? ive been searching forever.
please help this is my settings file and it was working then all of a sudden just stopped
[Main]
Menu_Mode=single
Single_Mode_Name=Super Nintendo Entertainment System
Enable_Exit_Menu=true
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Last_System=Super Nintendo Entertainment System
Hyperlaunch_Path=Z:\Hyperspin\HyperLaunch\
[Resolution]
FullScreen=false
Width=800
Height=600
Scanlines_Active=false
Scanlines_Image=
Scanlines_Scale=2
Scanlines_Alpha=0.1
[Optimizer]
CPU_Priority=normal
Quality=HIGH
Image_Smoothing=true
Animated_Backgrounds=true
Inter_Backgrounds=false
Level1_Backgrounds=true
Level2_Backgrounds=true
Level3_Backgrounds=false
Level4_Backgrounds=false
Special_Backgrounds=true
Wait_For_Special=false
Animated_Artworks=true
Level1_Artworks=true
Level2_Artworks=true
[introVideo]
Use_Intro=true
Stop_On_Keypress=true
[sound]
Master_Volume=100
Video_Volume=100
Wheel_Volume=20
Interface_Volume=100
[AttractMode]
Active=true
Time=60
MaxSpinTime=10
HyperSpin=true
Wait_For_Video=false
[Keyboard]
Key_Delay=true
[P1 Controls]
Start=13
Exit=27
Up=38
Down=40
SkipUp=37
SkipDown=39
SkipUpNumber=70
SkipDownNumber=86
HyperSpin=32
Genre=71
Favorites=76
[P2 Controls]
Start=69
Exit=81
Up=87
Down=83
SkipUp=65
SkipDown=68
SkipUpNumber=74
SkipDownNumber=77
HyperSpin=88
Genre=72
Favorites=90
[P1 Joystick]
Enabled=false
Joy=0
Threshold=40
Start=Button_1
Exit=Button_2
Up=Analog_Up
Down=Analog_Down
SkipUp=Analog_Left
SkipDown=Analog_Right
SkipUpNumber=Button_3
SkipDownNumber=Button_4
HyperSpin=Button_5
Genre=Button_6
Favorites=Button_7
[P2 Joystick]
Enabled=false
Joy=1
Threshold=40
Start=Button_1
Exit=Button_2
Up=Analog_Up
Down=Analog_Down
SkipUp=Analog_Left
HyperSpin=Button_5
Genre=Button_6
Favorites=Button_7
[Trackball]
Enabled=false
Sensitivity=90
[spinner]
Enabled=false
Sensitivity=90
[startup Program]
Executable=
Paramaters=
Working_Directory=
WinState=NORMAL
[Exit Program]
Executable=
Paramaters=
Working_Directory=
WinState=NORMAL
[LEDBlinky]
Active=false
Path=
[HiScore]
Active=false
Y=550
Delay=2
If they are not in the downloads section (I couldn't see them) then the only other way is to donate (click the button up top.) Gold membership gets you access to the ftp where you can download the artwork (Wheels, Themes etc), and platinum allows you to use Hypersync Cloud, that allows you to sync your systems you have setup and download the media for those systems. If you have also bought membership at emumovies then it will sync those as well, it won't however set up your systems for you, it just syncs the media. If all you want is Mame then perhaps gold memberships is for you.
Also remember not every game has a theme, wheel or video, there are around 1488 Mame themes and 6607 wheel images.
[Main]
Menu_Mode=single
[b][color="#FF0000"]Single_Mode_Name=Super Nintendo Entertainment System[/color][/b]
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
[Resolution]
FullScreen=false
Width=800
Height=600
Scanlines_Image=
Scanlines_Scale=2
Scanlines_Alpha=0.1
[Optimizer]
CPU_Priority=normal
Quality=HIGH
[introVideo]
Use_Intro=true
[sound]
Master_Volume=100
Video_Volume=100
Wheel_Volume=20
[AttractMode]
Active=true
Time=60
MaxSpinTime=10
HyperSpin=true
[Keyboard]
Key_Delay=true
[P1 Controls]
Start=13
Exit=27
Up=38
Down=40
SkipUp=37
SkipDown=39
SkipUpNumber=70
SkipDownNumber=86
HyperSpin=32
Genre=71
Favorites=76
[P2 Controls]
Start=69
Exit=81
Up=87
Down=83
SkipUp=65
SkipDown=68
SkipUpNumber=74
SkipDownNumber=77
HyperSpin=88
Genre=72
Favorites=90
[P1 Joystick]
Enabled=false
Joy=0
Threshold=40
Start=Button_1
Exit=Button_2
Up=Analog_Up
Down=Analog_Down
SkipUp=Analog_Left
HyperSpin=Button_5
Genre=Button_6
Favorites=Button_7
[P2 Joystick]
Enabled=false
Joy=1
Threshold=40
Start=Button_1
Exit=Button_2
Up=Analog_Up
Down=Analog_Down
SkipUp=Analog_Left
HyperSpin=Button_5
Genre=Button_6
Favorites=Button_7
[Trackball]
Enabled=false
Sensitivity=90
[spinner]
Enabled=false
Sensitivity=90
[startup Program]
Executable=
Paramaters=
Working_Directory=
WinState=NORMAL
[Exit Program]
Executable=
Paramaters=
Working_Directory=
WinState=NORMAL
[LEDBlinky]
Active=false
Path=
[HiScore]
Active=false
Y=550
Delay=2[/quote]
Also welcome to the forum MJ.
You might want to explain what is actually happening, I can see by the settings info that your only using SNES in single mode and that's all, is that correct?
Thank you gigapig its a really nice place
yea that is correct i only wanna use it for an snes also im gonna post my log here too
10:15:03 PM | HyperSpin Started
10:15:03 PM | Going windowed mode
10:15:03 PM | Checking for updates
10:15:03 PM | Update Check Complete
10:15:03 PM | Startup program unavailable
10:15:03 PM | Playing intro video
10:15:05 PM | Error intializing joysticks
10:15:05 PM | Menu Mode is single
10:15:05 PM | Loading Super Nintendo Entertainment System.xml
10:15:05 PM | Super Nintendo Entertainment System.xml successfully loaded
10:15:06 PM | Super Nintendo Entertainment System wheel loaded successfully
10:15:08 PM | Super Nintendo Entertainment System wheel loaded successfully
10:15:09 PM | Super Nintendo Entertainment System wheel loaded successfully
10:15:10 PM | Super Nintendo Entertainment System wheel loaded successfully
10:15:14 PM | Launching Game
10:15:14 PM | Using HyperLaunch
10:15:14 PM | Getting HyperLaunch path
10:15:14 PM | HyperLaunch located at Z:\Hyperspin\HyperLaunch.exe
10:15:14 PM | Cannot find Hyperlaunch.exe
10:15:16 PM | Exit program unavailable
10:15:16 PM | Quiting Hyperspin
10:15:16 PM | Bye!
what i dont get is it says it was located and then couldnt find it
thx so much! :D i have a few more questions. (sry :() you really dont have to answer them but its also ok if you do. :) is there a way for me to just type in a name of a game and have it pop up in a complete set of roms rather than tediosly scrolling through the menus of hyperspin to find 1 game?
also this: http://www.hyperspin-fe.com/forum/showthread.php?36985-Is-there-a-complete-MAME-bios-download
10:15:16 PM | Bye!
It's looking at the path you supplied but then can't find it.
If you've followed the correct folder structure then the path should be :\HyperSpin\HyperLaunch\HyperLaunch.exe
I think yours is looking in the HyperSpin folder which would be very wrong :)
If holding left or right button down which brings up the letter jump, or adding games to favourites or using genres is not enough, maybe have a look into this, Hypersearch.
I've not used it myself, but may be worth a look.
Answered.
I Have my folders as such it goes
Hyperspin and then inside that folder is the the folder for hyperlaunch then inside of hyper launch i have hyperlaunch hq inside its own folder
You'd need to go into Hyperspin> Settings folder, open the settings.ini and change the Hyperlaunch path including the backslash at the end.
So it should look like this for you.
Z:\HyperSpin\HyperLaunch\HyperLaunch.exe
Get Hyperspin version 1.3.2 if that setting in the Hyperspin Settings folder that gigapig mentions is not working. You can find it in the downloads section.
Do you say that because the version shows 1.0.0.0 or is there another way?
I did notice that but dismissed it because mine shows the same version.
If the person has the right path setting and it shows up in the log without using the path setting than the setting isn't being read for some reason. In this case it's probably an out of date version.
According to this guy the settings being used are
His log shows
If Z:\HyperSpin\HyperLaunch\ is his/her actual setting than the log should show 10:15:14 PM | HyperLaunch located at Z:\Hyperspin\HyperLaunch\HyperLaunch.exe like mine does. Either the person posted the wrong settings being used or they are using an outdated hyperspin.
