lazychicano Posted September 28, 2014 Posted September 28, 2014 I am new to Hyperspin, just got everything set up over the weekend. I am sure this is an easy fix, but how do i change the screen resolution for old school games so they don't stretch on my widescreen LED monitor?
dougan78 Posted September 29, 2014 Posted September 29, 2014 I believe that will be a per system thing. I believe you can set the resolution in the module in hyperlaunchhq. You will probably want bezels then to fill up the black space. Good luck. Asuming your monitor supports other resolutions.
gigapig Posted September 29, 2014 Posted September 29, 2014 Yes dougan is right, that will typically be setup in the emulator itself. Most of mine are set to 4:3 where possible and bezels are used also where possible as not every system has bezel support. There are also options in HLHQ, choose your system and click the module tab, then "edit global module settings" here you can set fullscreen etc if supported. These maybe overriding your emulator settings. Which systems are you working with?
