Visual Pinball inside Hyperspin
^F117^
hello I don't understand how it works. this is the configuration file.
[exe info]
path=C:\Pinball\
rompath=C:\Pinball\Tables\
userompath=false
exe=VPinball.exe
romextension=vpt
parameters=
searchsubfolders=false
pcgame=false
winstate=HIDDEN
hyperlaunch=false
database File xml
<?xml version="1.0"?>
-<menu>
-<game name="Twilight Zone">
<description>Twilight Zone (Bally)</description>
<manufacturer>Bally</manufacturer>
<year>1993</year>
<type>SS</type>
</game>
</menu>
if I click in the wheels menu Twilight Zone I see Visual Pinball opened But table does not start.
Yes same name.. I don't have Hyperlaunch, I have downloaded HyperSpin Install v1.3.2.0, I have configure Mame and neogeo , and works fine, now I have try, to add a Visual pinball..
Hyperspin Already has Hyperlaunch. 1.3.2.0 just has a really outdated hyperlaunch. If you upgrade you will have less issues. It takes a moment to learn but this is the current standard and will yield the most support.
Give these a try.
[exe info]
path=C:\Pinball\
userompath = true
exe = vpinball.exe
romextension = vpt
parameters =
searchsubfolders = true
pcgame = false
winstate = HIDDEN
hyperlaunch = true
Also change your xml to: The one you posted is used for HyperPin not Spin
<game name="Twilight Zone" index="" image="">
<cloneof></cloneof>
<crc></crc>
<year>1993</year>
<genre></genre>
<rating></rating>
<enabled></enabled>
</game>
first of delete your system emulator and learn how to set up Global emulators here
http://www.hyperspin-fe.com/forum/showthread.php?26140-Understanding-the-differences-between-Global-Emulators-and-System-ones&highlight=global+emulator
second their are a few things you need to do to set up Visual Pinball
1.disable Esc in the Visual Pinball keys
2. Edit Visual Pinball Global Module Settings.
learn how here
http://www.hyperspin-fe.com/forum/showthread.php?36788-Visual-Pinball-Exit-Emulator-back-to-Hyperspin
your MAME ahk error is because you need to update your Hyeprlaunch learn how here
http://www.hyperspin-fe.com/forum/showthread.php?27528-HyperLaunch-GIT
if you update your files
make the Visual Pinball changes I suggested
post your Hyperlaunch log found in
C:\HyperSpin\Hyperlaunch\Hyperlaunch.log
if you have any errors.
