Uselchen Posted October 14, 2014 Posted October 14, 2014 Hi there, im pretty new to Hyperspin and i got a Problem.. I´ve set up everything so far but when i try to run the Game "Little Samson" in HS it tells me Missing Rom Extension in Nintendo Entertainment System.ini i have no clue what to do pls help
rfancella Posted October 14, 2014 Posted October 14, 2014 Hi there, im pretty new to Hyperspin and i got a Problem..I´ve set up everything so far but when i try to run the Game "Little Samson" in HS it tells me Missing Rom Extension in Nintendo Entertainment System.ini i have no clue what to do pls help Hello and welcome to the forums! Couple questions. Is it HyperSpin or HyperLaunch telling you that? Can you provide a screen shot or more information. To check your extensions in HyperSpin, go to your HyperSpin directory and launch HyperHQ.exe. Click Wheel Settings tab on top. Click the drop down "Choose A Wheel" and select Nintendo Entertainment System. What is in the Extensions box? A good guide on posting to the forums is here (would recommend everyone read it before posting): http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Uselchen Posted October 14, 2014 Author Posted October 14, 2014 It is HyperSpin that tells me the error. Here are the Screenshots you asked for: http://prntscr.com/4w6prj - HyperSpin Screen (when i try to launch the rom) http://prntscr.com/4w6qmq - HyperHQ Screen http://prntscr.com/4w6quv - HyperLaunch HQ v 1.0..13..0 Screen
rfancella Posted October 14, 2014 Posted October 14, 2014 It is HyperSpin that tells me the error.Here are the Screenshots you asked for: http://prntscr.com/4w6prj - HyperSpin Screen (when i try to launch the rom) http://prntscr.com/4w6qmq - HyperHQ Screen http://prntscr.com/4w6quv - HyperLaunch HQ v 1.0..13..0 Screen wOOt! Looks good. In your HyperHQ, in the Extensions box put: 7z,zip,nes,fds And give it a test. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Uselchen Posted October 14, 2014 Author Posted October 14, 2014 wOOt! Looks good.In your HyperHQ, in the Extensions box put: 7z,zip,nes,fds And give it a test. Thanks, Ron Okay added what you said. Now when i try to launch the game in Hyperspin it tells me there is no Folder and that i could not create it. http://prntscr.com/4w7fy0 - Screen (when i press Ja (yes) it says Couldnt create Folder!) Wondering why it wants to create a folder in G:\Games.... the Hyperspin Folder is in the Root from G:\
rfancella Posted October 14, 2014 Posted October 14, 2014 Okay added what you said.Now when i try to launch the game in Hyperspin it tells me there is no Folder and that i could not create it. http://prntscr.com/4w7fy0 - Screen (when i press Ja (yes) it says Couldnt create Folder!) Wondering why it wants to create a folder in G:\Games.... the Hyperspin Folder is in the Root from G:\ Looks like a dialogue box inside Nestiopia. Probably a setting to save the nvram files or the like (savegames). Does the same thing happen if you try to load and run a rom from within Nestiopia (not using HyperSpin)? Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Uselchen Posted October 15, 2014 Author Posted October 15, 2014 Looks like a dialogue box inside Nestiopia. Probably a setting to save the nvram files or the like (savegames).Does the same thing happen if you try to load and run a rom from within Nestiopia (not using HyperSpin)? Thanks, Ron It happens as soon as i try to open the Nestopia.exe, i guess my emu is broken. I maybe should mention that i didnt set up everything by myself. I downloaded the Hyperspin Project - The Frontent with Pre-configured emulators. It worked at some point but when i installed HyperLaunchHQ it stoped working. Maybe the Emulator configuration doesnt fit anymore.
32assassin Posted October 15, 2014 Posted October 15, 2014 this has noting to do with Hyerlaunch, HyperlaunchHQ or anything related to Hyerpsin. When you first run Nestopia it will creates an XML inside the Nestopia emulator folder called "Nestopia.XML" inside this XML it stores paths; paths Nestopia uses to store files. if you place the Nestopia folder back at G:\Games\Nintendo\Nintendo Entertainment System\Emulator\ your emulator will start to work again. if you don't want to do that delete the Nestopia.XML. When you run Nestopia it will create a new Nestopia.XML
