[PROBLEM] Could not locate a selection called...
PinnaWarner
Hi to all,
before posting I've read all the threads regarding this matter without resolving my problem.
Hyperspin don't work, I checked all the folders several times. Everything is correct, but when I start any roms for any emulator, it does not work.
I'm using hyperspin 1.2
HyperLaunch v3.0.0.9
Settings\Global Emulators.ini
[Daphne]
Emu_Path=..\Emulators\Daphne\daphne.exe
Rom_Extension=zip|txt
Module=Daphne.ahk
HyperPause_Save_State_Keys=
HyperPause_Load_State_Keys=
Settings\Dalphne\Emulators.ini
[Roms]
Rom_Path=C:\HyperSpin\Emulators\Daphne\roms\
Default_Emulator=C:\HyperSpin\Emulators\Daphne\daphne.exe
[ExampleEmu]
Emu_Path=C:\HyperSpin\Emulators\Emu_Name\emulator.exe
Rom_Extension=7z|bin
Module=Custom_Module_Name_If_Different_Then_Emu_Name
HyperPause_Save_State_Keys=Read_Guide_To_Use_These
HyperPause_Load_State_Keys=Read_Guide_To_Use_These
Anyone can help me??
Hi to all,
[ATTACH=CONFIG]45855[/ATTACH]
[Daphne]
Module=Daphne.ahk
[Roms]
[ExampleEmu]
Your files are not most current. You should (at some time) update them. Here is a post on how to do it:
http://www.hyperspin-fe.com/forum/showthread.php?31472-Complete-Guide-for-Commodore-Amiga-in-HS-and-RL-Using-WinUAE-Only&p=304130&viewfull=1#post304130
Here is a complete guide for Daphne that may help:
http://www.hyperspin-fe.com/forum/showthread.php?29410-Complete-Guide-for-Daphne-in-HyperSpin-and-RL
Thanks,
Ron
Hi to all,
[Daphne]
Module=Daphne.ahk
[Roms]
[ExampleEmu]
Oh, and welcome to the forums!!
Thanks,
Ron
please don't edit your ini files manually.
the main purpose of HyerlaunchHQ is to make things easy for you.
[Daphne]
Module=Daphne.ahk
if you used HyperlaunchHQ to set your emulator you would have this
[Roms]
Default_Emulator=Daphne
your default emulator is the tittle of the emulator not the path.
the path to your emulator is saved in the global emulators ini.
instead of this
[Roms]
