djmarkhill Posted October 16, 2014 Posted October 16, 2014 Hi I'm struggling to start games in hyperspin. Basically, all games have been audited, both a keyboard and an xbox 360 controller have been mapped. I can navigate the wheel using both keyboard and controller. After I press start and select a game to play, the intro video for the game plays but when I press start/enter again to actually start the game nothing happens, I just seen enter coins/free play on the opening screen. The same happens If I test a rom using hyperlaunchHQ.
gigapig Posted October 16, 2014 Posted October 16, 2014 Hi Mark welcome to the forum. Sounds like Hyperlaunch is already running, you might see the icon in the system tray. If the problem was just from within Hyperspin I would say something is wrong in HyperHQ and you may have set some sort of filtering.
djmarkhill Posted October 16, 2014 Author Posted October 16, 2014 Hi Thanks for your reply, I have tried it via some other software that tests the rom (can't remember the name) and it did the same, this is a fresh install as I had the same issue on a previous install.
djmarkhill Posted October 16, 2014 Author Posted October 16, 2014 I'm using windows 7 (not sure if that makes any difference)
gigapig Posted October 16, 2014 Posted October 16, 2014 You'll need to supply some more detail then. Post your Hyperspin and hyperlaunch Logs, the Hyperlaunch log needs to be set to troubleshooting level. What systems are you trying to run and did you follow any guides?
djmarkhill Posted October 16, 2014 Author Posted October 16, 2014 To be honest, when I first tried it was from a cloned hard drive that worked. I reinstalled using tehgeek on YouTube. I'll get the logs when I get home and I'll copy and paste. Thanks again
Agrajag Posted October 16, 2014 Posted October 16, 2014 Check the link in my sig for known bugs in case it's one of the usual culprits. HyperSpin behaving oddly? Read about known bugs here: http://www.hyperspin-fe.com/topic/4590-known-bugs-and-handy-hints-for-hyperspin/ The installer for HyperSpin now includes HyperLaunch 2. Go here for support: http://www.hyperspin-fe.com/forum/122-hyperlaunch-2/ HyperLaunch3 is now called RocketLauncher. Go here for support: http://www.rlauncher.com/forum/content.php Read this for ftp login info: http://www.hyperspin-fe.com/topic/2320-ftp-access-must-read/ Platinum members get 25% off an Emumovies subscription: http://www.hyperspin-fe.com/topic/1211-emumovies-code/
djmarkhill Posted October 16, 2014 Author Posted October 16, 2014 Hi guys I've sorted it, I hadn't setup a coin or start button in hyperspin. I do have a question though, do I have to configure inputs for each game (1 by 1) or can I do it all in one go?
gigapig Posted October 16, 2014 Posted October 16, 2014 I personally where possible set controls up in tbe emulator unless a game requires different keys.
