Deemar Posted October 26, 2011 Posted October 26, 2011 I set it up and I can run it from MESSUI, plus I can run it from the command line if I'm inside the MESS directory. For some reason I can't run it from outside the MESS directory which means it won't run from Hyperspin. See below, why does this happen? C:\>"C:\Hyperspin\Emulators\MESS\mess64.exe" lynx -cart "C:\Hyperspin\Emulators\MESS\Atari Lynx\Ninja Gaiden (USA, Europe).zip" lynx.bin NOT FOUND ERROR: required files are missing, the system cannot be run. C:\>cd Hyperspin/Emulators/MESS C:\Hyperspin\Emulators\MESS>"mess64.exe" lynx -cart "C:\Hyperspin\Emulators\MESS\Atari Lynx\Ninja Gaiden (USA, Europe).zip" lynx.bin ROM NEEDS REDUMP WARNING: the system might not run correctly. Average speed: 100.00% (7 seconds) C:\Hyperspin\Emulators\MESS> Running from inside the MESS directory is fine. Running from outside specifies files are missing.
djvj Posted October 26, 2011 Posted October 26, 2011 I suggest using mednafen for Lynx. "Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."RocketLauncher's Official Home If you appreciate my work:My Apps:Window LoggerIdle Volume AdjusterExplorerRestorerRom Folder CleanerModule UpdaterMy Guides:How To Mod Guncons with Aimtrak
shateredsoul Posted October 26, 2011 Posted October 26, 2011 Looks like Mednafen is 32 bit only. what? no, I used it on two different 64 bit computers. retro-replay.com My arcade Build http://www.hyperspin-fe.com/forum/showthread.php?t=8904
Hypnoziz Posted October 26, 2011 Posted October 26, 2011 You can run a 32-bit based program from within a 64-bit Windows operating system. The support for the 32-bit architecture is included. <em class='bbc'>"But does one ever truly have a choice? One can only match, move by move, the machinations of Fate, and thus defy the tyrannous stars."</em>
Deemar Posted October 26, 2011 Author Posted October 26, 2011 When I double click the Mednafen executable, nothing happens.
Hypnoziz Posted October 26, 2011 Posted October 26, 2011 Try running it in compatibility mode for Windows XP SP2. EDIT: Oops! Disregard please. Forgot it was command-line only. <em class='bbc'>"But does one ever truly have a choice? One can only match, move by move, the machinations of Fate, and thus defy the tyrannous stars."</em>
bLAZER Posted October 26, 2011 Posted October 26, 2011 Mednafen works fine in 64-bit. Nothing should happen when you just click on it, it expects a rom file. Easiest way to start is to drag a rom file to mednafen.exe.
djvj Posted October 26, 2011 Posted October 26, 2011 When I double click the Mednafen executable, nothing happens. Mednafen has no gui, so running it directly will do nothing. Just run it through HS with the correct module. Sent from my Droid using Tapatalk "Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."RocketLauncher's Official Home If you appreciate my work:My Apps:Window LoggerIdle Volume AdjusterExplorerRestorerRom Folder CleanerModule UpdaterMy Guides:How To Mod Guncons with Aimtrak
HyphyCus Posted October 27, 2011 Posted October 27, 2011 Get MedGUI, set up your options. Then you should be able to use Mednafen no problem for Lynx. Works a lot better than MESS. I try to avoid MESS at all costs.
Deemar Posted October 27, 2011 Author Posted October 27, 2011 No, I figured it out. I needed to have LynxImage.iso (the BIOS) in the Mednafen root directory. Works perfect now for Lynx and TurboGrafx 16.
cmarion1024 Posted December 13, 2011 Posted December 13, 2011 I am also trying to get Lynx to function correctly and have read the above, with some understanding. I will admit I do not know everything, what I have accomplished is from lots of reading (and searching), plus trial and error. I went with the mednafen route as suggested, i also downloaded the medgui just in case. I downloaded all from the links supplied here. I used Clrmamepro to rename my rom set, set up HyperHQ just as I have done before. When I select a game in Hyperspin, it tells me "Atari Lynx is an invalid system name or mednafen.exe is not supported yet". Im not getting an error for the usual rom path, etc. What am I doing wrong?
djvj Posted December 13, 2011 Posted December 13, 2011 Switch to hyperlaunch v2.13. You won't have to deal with that error anymore. It uses modules instead that you get off HyperList. "Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."RocketLauncher's Official Home If you appreciate my work:My Apps:Window LoggerIdle Volume AdjusterExplorerRestorerRom Folder CleanerModule UpdaterMy Guides:How To Mod Guncons with Aimtrak
demonolith Posted December 13, 2011 Posted December 13, 2011 Switch to hyperlaunch v2.13. You won't have to deal with that error anymore. It uses modules instead that you get off HyperList. I second this. I recently made the switch. I admit that I was hesitant at first. I thought it would be a disaster setting everything up again. Even the hardest systems like PC Engine CD with Ootake were a breeze to set up and work flawlessly. It's as simple as drag, drop, and rename. Occasionally you'll need to tweek some settings in the module, but there are very detailed instructions to guide you through it. So far, the only problem I'm having is with the Daphne module making my badlands game lag when it wasn't lagging previously.
cmarion1024 Posted December 13, 2011 Posted December 13, 2011 I was, and still am, terrified of making the switch. Once I grasped the concept of my current setup I was able to do my other systems using HL1.0. It took many, many hours to get where I am now. Its like standing on a cliff, I really dont want to jump. If I do its supposed to make things easier, but I am still hesitant on not surviving.
djvj Posted December 13, 2011 Posted December 13, 2011 It's not a life or death situation. If you need to go back (attach a bungee cord before you jump) and backup your hyperlaunch.ahk and exe first. "Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."RocketLauncher's Official Home If you appreciate my work:My Apps:Window LoggerIdle Volume AdjusterExplorerRestorerRom Folder CleanerModule UpdaterMy Guides:How To Mod Guncons with Aimtrak
Hypnoziz Posted December 13, 2011 Posted December 13, 2011 I was, and still am, terrified of making the switch. Once I grasped the concept of my current setup I was able to do my other systems using HL1.0. It took many, many hours to get where I am now. Its like standing on a cliff, I really dont want to jump. If I do its supposed to make things easier, but I am still hesitant on not surviving. I know what you mean. I'm a close of follower of that saying: "If it aint broke, don't fix it". However, if it's reassuring at all, you can always just back up your Hyperlaunch 1.0 setup. You won't lose anything at all while you test out Hyperlaunch 2.X. <em class='bbc'>"But does one ever truly have a choice? One can only match, move by move, the machinations of Fate, and thus defy the tyrannous stars."</em>
cmarion1024 Posted December 13, 2011 Posted December 13, 2011 Your right, its not life or death. Its the same as Hypnoziz said.
djvj Posted December 14, 2011 Posted December 14, 2011 It will be broke when HS2 comes out. It's better to be proactive then reactive. "Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."RocketLauncher's Official Home If you appreciate my work:My Apps:Window LoggerIdle Volume AdjusterExplorerRestorerRom Folder CleanerModule UpdaterMy Guides:How To Mod Guncons with Aimtrak
cmarion1024 Posted December 14, 2011 Posted December 14, 2011 I just started switching about 30 minutes ago. Obviously MAME works since it was incorporated in the zip file of HL 2.13. Trying to read through 117 pages for a good tutorial is very frustrating. For someone like me who does not know all the lingo and programming/code writing jargon, I think a new HOW TO or TUTORIAL should be made for systems other than MAME. Atleast use more than one system when explaining the process. Im getting errors and I am trying to follow the short directions from BadBoyBills first post. All I have working is MAME, and thats because it came completed. I have a headache. NES came with the zip folder to, but it dont work. Keeps telling me it cant find the .AHK file thats in the directory it says its not. Like this: Step3. Make a new folder in you install director called Modules. Each module goes into a folder of the system name. So: Modules\MAME\MAME.ahk That is easy to understand. But for "system name", am I calling it the actual console make name or the emulator system name?
cmarion1024 Posted December 14, 2011 Posted December 14, 2011 Edit : Each system is asking for a different .AHK file than the ones you guys made. Atari gives me the error "Cant find C:\Hyperspin\Modules\Atari 5200\Atari 5200.ahk" If my trial and error is correct here, For Neo Geo I would add Modules\Neo Geo\MAME.ahk *BUT* I have to rename MAME.ahk to NEO GEO.ahk for it to work. Or atleast thats what I did to not get errors so far. If I can figure out how to do this correctly for every system, I would be more than happy to write a retard proof "how to" for people on this. I still cant get Mednafen to work for Atari Lynx. I run WIN7 64, I even tried changing it to run as XP SP2 & SP3 with no luck.
cmarion1024 Posted December 14, 2011 Posted December 14, 2011 ERROR Message when trying to use MedGUI to test outside of hyperspin. Trying HL does nothing. ==================== Microsoft .NET Framework Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately. File not found. ======= DETIALS ======= See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.IO.FileNotFoundException: File not found. at Microsoft.VisualBasic.Interaction.Shell(String PathName, AppWinStyle Style, Boolean Wait, Int32 Timeout) at MedGui.MedGui.avvio() at MedGui.MedGuiSimple.MedGuiSimple_Load(Object sender, EventArgs e) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5448 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll ---------------------------------------- MedGui Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Hyperspin/Emulators/Atari%20Lynx/MedGui.exe ---------------------------------------- Microsoft.VisualBasic Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5447 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5446 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Runtime.Remoting Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Hypnoziz Posted December 14, 2011 Posted December 14, 2011 All modules for each system are downloaded from Hyperlist (see that tab at the top of the site?) You only need to read the first post of that thread. It explains everything in the simplest of terms. When you add each new system, you'll need that system's module. Again, download it from Hyperlist. Each system has that green AHK button on the right and that will get you the modules. System name means the name you put in HyperHQ. So for something like Sega Genesis, the system name would be "Sega Genesis" and NOT "Fusion". Don't bother with MedGUI. You won't need it once you get the proper module for Mednafen to run Atari Lynx. <em class='bbc'>"But does one ever truly have a choice? One can only match, move by move, the machinations of Fate, and thus defy the tyrannous stars."</em>
cmarion1024 Posted December 14, 2011 Posted December 14, 2011 I downloaded every module I needed from the link in the original thread for each system, which gives multiple ahk files for which ever emulator your running. I got that stuff done and so far everything works correctly except Lynx. The part that is missing in the "simplest of terms" is renaming the .ahk file to the actual system name. Unless I am the only person who had to do that, that is what I had to do. c:\Hyperspin\Modules\Sega Master System\Sega Master System.ahk <=-formely known as fusion.ahk Some how, and I dont know how, after I added the Lynx wheel art I started Hyperspin. Went to Lynx to confirm the art was good to go. For giggles I clicked a game and it launched. However, it seems to launch the game at the ending credits. Like you beat the game. It just goes and goes and goes. Every game does this. I did this after I posted the error message. **EDIT** I shut my desktop down for the night and turned it back on this morning. I tested to see if a restart would fix a problem or an error somewhere. Some Lynx games are working, which is great, and I still dont know what was up with all the error messages. However, now when I click on a Lynx game in Hyperspin the Windows Persmission box pops up on if I am allowing this action. This is kind of odd. Should I just delete all the Mednafen files and reinstall it again?
mbelsis Posted December 21, 2012 Posted December 21, 2012 Hi All, I am really new to hyperspin. I am having the same issue. I am getting the same error message " Atary Lynx is an invalid...or mednafen is not supported" ... I have google everywhere for the LynxImage.iso refered abobut I cannot find it anywhere ?? please any help thx
